1958 Belvedere heater control valve
jboymechanic
Posted 2012-05-14 11:22 PM (#321090)
Subject: 1958 Belvedere heater control valve
2000100100
Any one have a good, affordable source for these valves? The valve in my Belvedere just started leaking today.
sconut1
Posted 2012-05-22 12:07 AM (#322279 - in reply to #321090)
Subject: Re: 1958 Belvedere heater control valve
500100100252525
Try this guy: http://heatercontrolvalve.com/. The fellows name is Jim Tucker. He'll be able to rebuild your old valve for you for just under $100.00 I recently had him rebuild the valve from my Fury. I've not yet reinstalled it, but the work he did looks good. He's quite highly recommented on the Imperial website, and that's why I chose to deal with him. He's a little gruff over the phone, but he'll get the job done for you.
Christine'sRevenge
Posted 2012-05-22 7:02 AM (#322300 - in reply to #321090)
100100100100
I just bought an NOS Valve on Ebay in the original box. What a score!
57plymouth
Posted 2012-05-22 8:23 AM (#322314 - in reply to #321090)
20001000500100
There is a rebuild kit available at NAPA. (if they have it in stock, or else you get to pay shipping...) The control valve is mostly brass. It's not too bad to rebuild. There is a rubber gasket inside that goes hard and then tears and causes the leak. Once it's off the car it's pretty easy to figure out how to take it apart and rebuild it.
Chrome58
Posted 2012-05-22 8:34 AM (#322317 - in reply to #322314)
1000100100100
57plymouth - 2012-05-22 2:23 PM
I beg to differ ...
I bought that rubber gasket from NAPA and tried to replace it in my heater control valve ... No way !
Obviously, it was not the correct gasket for my valve. Maybe there are two different designs.
Anyway, I was unable to replace it ...
Posted 2012-05-22 9:42 AM (#322328 - in reply to #322317)
Chrome58 - 2012-05-22 8:34 AM
I beg to differ ...
yes, these were never designed to be rebuild. rebuilding means uncrimping and crimping the valve tabs that have been crimped before. and after 50+ years chances are it has been rebuild before. years ago i had one rebuild (not by me) valve come apart at high engine speed... it wasn't fun.
Edited by 1960fury 2012-05-22 9:43 AM
b5rt
Posted 2012-05-22 10:30 PM (#322439 - in reply to #321090)
JCAuto http://jcauto.com/ offers a rebuilding service. I've never used them so don't know how well they work out.
soiouz
Posted 2012-05-23 2:53 PM (#322510 - in reply to #321090)
Subject: RE: 1958 Belvedere heater control valve
20001000100100100100252525
I did rebuild mine myself with the NAPA kit. I took my time, took the valve apart, carefully changed the rubber gasket and rebuild it all. It works beautifully, has been working great from many months and many hundreds of miles of driving and I don't see why it wouldn't last another 25 years at least. Just take your time and work gently on the brass tabs holding the valve together.
big m
Posted 2012-05-23 9:10 PM (#322609 - in reply to #322510)
5000200050010010010025
soiouz - 2012-05-23 11:53 AM
I've also done many myself without trouble. If the valve has already been rebuilt once, though, the tabs will be fatigued and will break most likely, so start with a different, virgin, valve.
---John
Posted 2012-06-11 7:34 PM (#325228 - in reply to #322609)
not all oem valves are ranco heater valves. some are robertshaw valves. actually a better design with a base plate that does not stress the rubber seal as much as the ranco does but the brass tabs are much more fragile. if you try to unbend the tabs without heat they break. at least that is my experience. i would never try to rebuild them the usual way.
after that nightmare experience with a rebuild valve i bought i decided to do it myself the right way by modifying the valve seat and a new base plate with camfered valve opening in order to make it possible to BOLT the valve to the valve actuating mechanism. i rebuild many valves that way since 1994 so far no leaks but they can be easily rebuild again and again with a screwdriver in 5 minutes.
(0aheatervalve3ds.jpg)
(0aheatervale2ds.jpg)
(0aheatervalve6ds.jpg)
(0aheatervalve8ds.jpg)
Attachments 0aheatervalve3ds.jpg (37KB - 731 downloads)
Attachments 0aheatervale2ds.jpg (62KB - 716 downloads)
Attachments 0aheatervalve6ds.jpg (79KB - 725 downloads)
Attachments 0aheatervalve8ds.jpg (74KB - 727 downloads)
JT Newman
Posted 2012-06-12 1:47 AM (#325263 - in reply to #321090)
Nice design! I repaired my Ranco valve, it was straightforward job but still a pain in the ass. I even had to sacrifice some of my blood for Gods of Automotive Engineering.
It works fine now.
But, I read somewhere that heater valve on old Volvo PV is quite the same if you need to have similar design.
big m
Posted 2012-06-12 1:42 PM (#325321 - in reply to #325228)
1960fury - 2012-06-11 4:34 PM
Nice job on that heater valve, Sid! No need to worry about fatigued tabs breaking with your set up.
---John
jboymechanic
Posted 2012-06-12 10:33 PM (#325378 - in reply to #325228)
2000100100
1960fury - 2012-06-11 6:34 PM
I have two here that need rebuilding, any chance I can get you to make me a couple of those plates? Or do you have a mechanical drawing for the plates that you could share?
Posted 2012-06-19 4:50 PM (#326217 - in reply to #325378)
thanks big m. no jon i do not have a drawing but i can give you the dimensions. actually the pictures pretty much tell you what to do. the base plate measures 1.13/16" x 2.1/2" the opening is 5/8" (do not forget to camfer or drill a bigger hole the actual sealing surface is 13/16"+) the bolt pattern is 5 x 1.5/16" bolt size is 3mm. the plate is <1/8" thick. do not go bigger than 1/8" otherwise you could run out of thread when adjusting the valve for the thicker base plate so it still fully opens. there are no exact measurements for the valve actuating mechanism bolt holes due to production tolerances. best is to attach the valve first to the base plate and then connect the plunger rod to the lever and use the actuating mechanism as a template. that way the plunger rod is always perfectly centered.
sure i could sent you a couple of base plates and the valve fastener/bolts (all you would have to do is to grind down the tabs, install a new seal and attach the lever housing to the base plate) but the job is time consuming and actually not that hard to do with basic home tools... let me know.
below is a picture of a 59+ robertshaw valve i rebuild in 94 i just pulled. still looks like new and never leaked.
Edited by 1960fury 2012-06-19 7:04 PM
(0aheatervalve7ds.jpg)
Attachments 0aheatervalve7ds.jpg (40KB - 696 downloads)
jboymechanic
Posted 2012-06-20 5:27 PM (#326381 - in reply to #321090)
2000100100
Excellent, thanks for the info. I have access to a nice Bridgeport mill so I can get really carried away if I want.
James_Douglas
Posted 2022-11-19 12:14 AM (#625735 - in reply to #321090)
Sorry to resurrect such an old thread, but I need to rebuild one of these units, as I sent one out for rebuilding and what I got back was not to the quality level I want.
The one thing I cannot figure out how you did it, was the ring on the brass tube that the base screw into. How did you get it over the rolled lip where you ground the taps off of?
The sandwich of the brass base is what seals the thing...but I do not see how you got it over it. Unless it is not clear in the photo and you used two halves to do it.
I hope you spot this to provide an answer.
Thanks, James
Posted 2022-11-19 11:24 AM (#625740 - in reply to #625735)
5000500050010010010025
James_Douglas - 2022-11-18 9:14 PM
There are new Volvo Ranco valves on eBay for not that much money.
https://www.ebay.ca/itm/Heater-Control-Valve-673452-fits-Volvo-122-P...
Here is one rebuild link that might help you:
http://www.sw-em.com/Heater_Control_Valve.htm
Which I refound in this thread that I started:
http://www.forwardlook.net/forums/forums/thread-view.asp?tid=67959&...
I bought at installed one of the eBay Volvo Ranco valves which works great (once you have the hot inlet hose connected to the curved tube on the valve - I mixed my hoses up the first time - all good now)
http://www.forwardlook.net/forums/forums/thread-view.asp?tid=75720&...
Edited by 56D500boy 2022-11-19 4:50 PM
Posted 2022-11-19 6:42 PM (#625747 - in reply to #625735)
James_Douglas - 2022-11-19 12:14 AM
Thanks, James
You can cut the washer like a horseshoe and slide it over the brass tube or weld the washer together on the brass tube. Both works equally well. I did the latter, just because It looks nicer.
22mafeja
Posted 2022-11-26 9:01 AM (#625877 - in reply to #321090)
50010010025
That`s really a nice design Sid. I haven`t seen the old thread until now. A couple oh times I have welded on new tabs when they have fallen off.
Posted 2022-11-26 10:52 AM (#625880 - in reply to #321090)
500010005001002525
https://www.ebay.com/itm/364022525837?fits=Model%3A122%7CMake%3AVolv...
fupjUd4R&amdata=enc%3AAQAHAAAAsPuvQyVFwfEtkOBvnnisnogmc7oqlFW3tUEpRm2NCgdRVTCIjkX%2FtoFZGurSnO%2B4wSh7BQKI9Vk9UMHik6rIitN8hFU4fnmxRvB1HKHwZ7NKZio%2Ber
h7BQKI9Vk9UMHik6rIitN8hFU4fnmxRvB1HKHwZ7NKZio%2Berf%2Bo7R2pdKNtI%2BjHPQ6Nxozwkq69fTLdQNRYtOQSbje7vTrpUMtW6zwPI%2B7zIp44itPkXjf1wRbDLxiM9VRDF%2Btc5I3%2
pUMtW6zwPI%2B7zIp44itPkXjf1wRbDLxiM9VRDF%2Btc5I3%2BrAB%2FmSpWS4rNM2oHVDrL7TgPjIqs1u%2B%7Ctkp%3ABk9SR77hmcqWYQ
77hmcqWYQ
Posted 2025-07-02 10:50 PM (#640660 - in reply to #625880)
Old, old thread.... of course the best rebuild can't last with poor quality parts. This one I replaced about 10, max 15 years ago. Rare parts seal. On the plus side, there is a fabric in it, so they at least tried to deliver a quality seal and that fabrik kept the leak moderate. Fotunatly with my valves, replacement was a breeze.
(heater valve seal ranco.jpg)
Attachments heater valve seal ranco.jpg (11KB - 211 downloads)
