Rear Diff housing dimensions Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Shep |
Expert Posts: 3393 Location: Chestertown, NY ( near Lake George) | Probably already posted somewhere, but here we go. (Scan0003 (3).jpg) Attachments ---------------- Scan0003 (3).jpg (242KB - 263 downloads) | ||
59 in Calif |
Elite Veteran Posts: 1102 Location: Hayward, Calif | Hey Shep, Can you post the left side that shows the 'body type', as most of that info is not being shown. Thanks! I don't mean to be a PITA. Jerry | ||
Shep |
Expert Posts: 3393 Location: Chestertown, NY ( near Lake George) | Jerry, yeh I had trouble resizing this, in order top to bottom: 8-1/4 A body, 8-1/4 B body, 8 1/4 B & C body, 8-1/4 F body, 8 3/4 A body, 8 3/4 B body, 8 3/4 E body, 8 3/4 B body -71-74 only , 8 3/4 Sta. wgn. | ||
DeSotohead |
Board Moderator Posts: 3186 Location: The not-so-great, dirty-white North ( Michigan) | Shep... If you can email me this, I can resize and swap the photo for the one will all info included. | ||
dukeboy |
Expert 5K+ Posts: 6203 Location: Big pimpin' | A Side note, the A BODY 8 3/4 rear is ALWAYS the "Small bolt" pattern. (5 on 4" circle)....Didn't made an A-body 8 3/4 rear with big bolt pattern. Edited by dukeboy 2012-03-30 7:15 AM | ||
wayfarer |
Elite Veteran Posts: 888 Location: Peoples Republic of Oregon | Apparently some variations in printed literature exists. I have used these numbers for a very long time without much disagreement. If anyone has an assembled axle on the floor perhaps they could take a couple of measurements. Housing widths, flange to flange A BODY '66-'72= 52 5/8" B BODY '62-'63= 53 1/4" (And '64 Max Wedge) '64 = 55 5/8" (Exc. Max Wedge) '65-'67= 54 1/4"' 68-'70= 54 15/16"' 71-'74= 57 7/8"' 71-'73 wagon= 59 7/16" C BODY '65-'69= 56 3/4"' 70-'71= 57 7/8" (Chrysler & Fury) '70-'74= 59 7/16" (and '69 wagon) IMPERIAL '65-'66= 57"' 67-'69= 57 3/8"' 70-'71= 54 3/4"' 72-'73= 59 5/8" E BODY '70-'74= 56 31/64" A100 '65-'70= 56 3/4" D100 '65-'71= 58 5/16"' 72-'74= 59 7/16 Edited by wayfarer 2012-03-30 11:36 AM | ||
BigBlockMopar |
Expert Posts: 3575 Location: Netherlands | I recently narrowed a C-body housing to A-body width and using new axles. I have a few rear ends I can take measurements off. | ||
Expert Posts: 3768 Location: NorCal | As usual, like most rear end dimensions published on the web, those in the OP are wrong. Edited by 57chizler 2012-03-30 3:21 PM | ||
BigBlockMopar |
Expert Posts: 3575 Location: Netherlands | I've gathered a fair number of rear axle housing and axle measurements on my website as a reference. Gathered them from various sites and tried to weed out the wrong info, but I don't know if the info I have listed is still correct. If anyone sees anything wrong I would gladly ike to hear about it and make sure the info is correct. http://www.bigblockmopar.nl/tech/mopar-rearaxle-dimensions/ Edited by BigBlockMopar 2012-03-30 4:44 PM | ||
Shep |
Expert Posts: 3393 Location: Chestertown, NY ( near Lake George) | Drum to drum means outer edge of drum?, none of the dimensions match what I posted, of course the methodology is different. | ||
BigBlockMopar |
Expert Posts: 3575 Location: Netherlands | Measuring dimensions 'exactly' with a tape-measure is pretty much impossible if the 3rd member is still installed in the housing. This alone could give over .5" differences I guess. | ||
wayfarer |
Elite Veteran Posts: 888 Location: Peoples Republic of Oregon | The easy way to measure when working alone: Remove drums; clamp a bar against the face of each flange that will project beyond the usual obstructions; hook your tape to one of the bars and measure to the inside of the other bar then SUBTRACT the thickness of the first bar. | ||
Expert Posts: 3768 Location: NorCal | The dimensions noted by wayfarer and BBMopar are correct, I know because I compiled them and posted them for the Moparts site years ago. | ||
Expert 5K+ Posts: 5006 | this doesnt include any fwl cars... which is weak 57 Dodge is 59.5? anyone have a FWL list? | ||
Expert Posts: 3768 Location: NorCal | Dimensions for the '57-'61 full sized cars are: Housing width= 55 5/8" Overall width drum-to-drum= 60 7/8" Spring centers= 45 1/2" | ||
Expert 5K+ Posts: 9604 Location: So. Cal | For completeness: '55-'56 Dodge/Plymouth Drum-2-Drum: 59 15/16", spring perch centers: 41" | ||
Expert 5K+ Posts: 5006 | imperials had different housings in 1960-61-62
95+ ford Explorer V8's have disc brakes and 59.5 inch disc to disc. Think they are good till 2001 when they went IRS in 02... removed the v8 91-94 had drum brakes
Edited by mikes2nd 2020-10-18 6:34 PM | ||
Expert Posts: 3768 Location: NorCal | mikes2nd - 2020-10-18 3:24 PM imperials had different housings in 1960-61-62 Yes, about 1 3/4" wider overall. | ||
