trunk light - 56 Chrysler
di_ch_NY56
Posted 2011-08-08 10:13 AM (#283858)
Subject: trunk light - 56 Chrysler
100050025
I guess every 56 Chrysler (De Soto, Imperial and Dodge/Plymouth as well) have a trunk light, that starts working when the lid opens. Where the heck is the switch? The mechanic mounted the bulb socket holder close to the open mechanism inside the lid. Before it was loose (hanging at one brace inside the lid). He complained that the light is on all the times and cut the wire
Happy Motoring!
Dieter
BTW: inside the brochure I got a picture with the mammoth size trunk is visible. Referring this picture I guess originally the trunk light was mounted where the mechnanic mounted it again...
finsruskw
Posted 2011-08-08 11:47 AM (#283872 - in reply to #283858)
Subject: RE: trunk light - 56 Chrysler
2000100100100252525
probably a mercury switch.
Have some one shut the lid while you are inside and see if it goes out.
I know the underhood lites are like that,
Dave S.
Shep
Posted 2011-08-08 12:29 PM (#283878 - in reply to #283872)
Subject: Re: trunk light - 56 Chrysler
20001000100100100100252525
Correct, another Dave S. LOL
GaryS
Posted 2011-08-08 2:27 PM (#283895 - in reply to #283858)
1000100100
The only older Mopar trunk light switches I recall were similar to door switches, and mounted on a clip near the upper lip of the trunk opening.
I've never owned, or spent much time around the more luxurious '56 DeSotos and Chryslers, but I never saw a trunk light on any '55 or '56 Plymouths, including my dad's loaded '56 Belvedere. Ditto for my uncle's loaded '55 Custom Royal. It's interesting that the service manual text refers to a trunk light, but the wiring diagram does not show one. If there was a light package available at the time, it must not have been a commonly ordered option.
di_ch_NY56
Posted 2011-08-08 2:41 PM (#283900 - in reply to #283872)
100050025
finsruskw - 2011-08-07 5:47 PM
Dave S.
I'm sorry, Sir. I didn't think about a mercury switch. There is a black tube with one wire at each side - I thought it's a connector. Personally I was not present - the mechanic told it to me afterwards. I was visiting him more or less every Saturday until my car passed the traffic administration. I plan to replace the wire for the trunk light as well. It's damaged at several locations. I gonna try it. I could use my mobile phone (video mode) and let it run during closing the lid. Then I should see if it switches off or not.
Happy Motoring!
Dieter
Beltran
Posted 2011-08-08 10:06 PM (#283956 - in reply to #283858)
100050010010025
Dieter,
It is definetely a Mercury switch. Have had mine apart once to study this myself. Could not figure out why I wasn't getting power on the bulb side of the socket when I had power on the wire side of the socket. My mercury switch is only kicks in when the lid is nearly all the way open. (if the socket is properly positioned in the lid) The light should go out with at least 12 inches of opening still left on the closing trunk lid. It should be easy to see. If it is still lit when you've almost closed the lid then you have 1 of 2 problems.
1) the socket is not positioned properly to let the mercury switch do it's job.
2) the mercury switch is sticking in some way. (I know that sounds wierd but I recall my switch to be sealed and it had something you could hear sliding back and forth inside, if I recall correctly. It in fact may not be a mercury switch, it may be a mechanical one of some sort.)
brdtee
Posted 2024-04-06 7:53 AM (#634578 - in reply to #283858)
1001002525
Old topic but I'll add a picture of a mercury switch if someone is searching for troubleshooting. This is from a 1957 Chrysler.
Switch is inside the trunk light socket.
At the bottom there is a spring, then a round plastic bit (A) where the wire goes trought to an end terminal (B). After that comes a black tube (C) that contains the mercury switch capsule. (D) And the last bit is the light bulb.
When you are pulling the switch apart, there is a small metal clip on the side which holds the black tube in place. You need a shallow screwdriver to push the clip back so the parts can slide out.
As you can see, my switch has the black tube bit broken, I'm planning to do a new one with 3D-printer.
Edited by brdtee 2024-04-06 7:57 AM
(mercury_switch.jpg)
(trunklight_sideview.jpg)
Attachments mercury_switch.jpg (179KB - 403 downloads)
Attachments trunklight_sideview.jpg (19KB - 399 downloads)
Posted 2024-04-06 1:07 PM (#634580 - in reply to #283858)
50005000100100100100252525
Cool! I had no idea those were installed inside there.
brdtee
Posted 2024-04-06 3:59 PM (#634583 - in reply to #283858)
1001002525
3D-printing went well and after assembling the trunk light works fine with mercury switch.
(27C74F17-BFA9-4986-963D-6C00C4934D57.jpg)
Attachments 27C74F17-BFA9-4986-963D-6C00C4934D57.jpg (125KB - 400 downloads)
