Power seat rebuild/test/clean
ram300
Posted 2011-06-10 7:33 PM (#276307)
Subject: Power seat rebuild/test/clean
1001001002525
I have a power seat assembly in front of me out of a '57 Chrysler that has been sitting idle for many years. Have never put power to it so don't know if it "runs" or not. Would be very keen on hearing any tips on what to look at, clean, lube, pull apart before I try powering it up. A "how it works" and description of parts would be good too.
Any info at all on the power seat unit would help 'cause I know nuthin'
Thanks
Owen
miquelonbrad
Posted 2011-06-11 1:13 PM (#276372 - in reply to #276307)
Subject: Re: Power seat rebuild/test/clean
100050010010025
HI Owen,
I posted schematics of the power seat electrics and switches a while back... see the posting in this discussion area under "power seat switch".
Also, here is a blow-up diagram, from the 1957 Chrysler master parts catalog. It is from Chrysler Canada, but I think that the power seats were all the same...
Personally, I would disassemble and clean out all the old hardened grease and grime from the parts before I power it up. Might save from putting too much strain on the motor or solinoids. Do you have a shop manual?? It goes through diagnoisis and disassembly/re-assembly of the complete seat assembly.
miquelonbrad
Posted 2011-06-11 1:14 PM (#276373 - in reply to #276307)
Subject: RE: Power seat rebuild/test/clean
100050010010025
Stupid computers!!
(power seat blow-up.JPG)
Attachments power seat blow-up.JPG (70KB - 177 downloads)
Posted 2011-06-11 4:00 PM (#276388 - in reply to #276307)
500050002000100025
As usually, the workshop manual is a good way to start with - read the chapter through and think before doing - nothing is really difficult with the power seats.
ram300
Posted 2011-06-11 7:46 PM (#276401 - in reply to #276307)
1001001002525
Thanks Brad,
I've pulled it down and found plently of loose change stuck in the tracks as well as being seized up. The slave units seem to be dry too. No way it would have ever moved.
The workshop manual can be a very handy tool but it's always nice to get other FWDLK's ideas/tips and practical experiences of how to attack a job like this before starting. It can save many hours frustration.
Thanks again
Owen
Phatton
Posted 2011-06-11 8:50 PM (#276405 - in reply to #276307)
1002525
When disassembling make sure you ID which drive cable goes where - saves a lot of time when assembling. I had to pull mine completely apart to free the tracks. There are 2 steel roller bearings in each track (my assembly is a 1960 I think they are the same design as yours) - don't loose them. When I freed mine up one of the bearings came out, rolled across the shop floor, and hid under a workbench in a pile of bolts. Spent 15 minutes looking for it. When you re-assemble make sure the master and slave are in the same position on the track and adjusting bars are engaged in the same relative position. I just counted the number of bar teeth showing in front of each drive unit. Don't power up the unit until you have the whole assembly reconnected - this keeps everything in the same relative position. If you don't have everything in the same relative position one side will run out of adjustment before the other side does. When I assembled my unit, I put the whole thing on a long table and clamped the tracks down before powering it up. Hope this helps. Good luck
d500neil
Posted 2011-06-11 10:00 PM (#276411 - in reply to #276405)
5000500050002000200010025
Owen: been-there-done-that!
What you want to do, FIRST (if you can)...is hook up 12V to the hot lead and ground the power seat (to your car)
so that you hopefully can get that device to operate.
You want to raise UP the seat track as much as possible, in order to field strip it down, and to reassemble it.
It's virtually impossible to get to all the gears and lifting levers without the seat mechanisms being raised up fully.
Did you get it up? Good...
Next thing is you want to get some paint and/or take CAREFUL diagram-measurements documenting the precise location
of the three lifting-levers' connections to the gear teeth, on each side's mechanism.
This can't be over-stressed, because you are, eventually, going to have to re-position those levers precisely as you find them,
or else the two seat mechanisms will not work together to move the seat up/down/back/forth uniformly.
So, counting-the-lever-teeth, and writing/recording/photographing, and placing a marking-paint daub on the levers' teeths' connection to the gears is critical.
Then, you have to write down, carefully, the order/orientation of the components that comprise the gears that will come
out of the gear-mechanisms. This is really important, too, because their installation-orientation is confusing.
Also, be SURE to record the order/orientation of the three gear-cables that you'll find.
Hopefully, their inner cables' wound-ends are still squared-off; be careful with them.
This project is VERY doable, but you must record EVERYTHING that you encounter, in disassembling the two sides of this guy,
so that you can reverse the process, after every component is cleaned/polished and lubed up and painted.
There are also some solenoids that you'll find, in this deal, but, again, write down/diagram/photo everything---when I overhauled
my car's power seat, digital photography didn't exist.
Do this right, and you'll never have to worry about 'it' again; do it wrong, and you'll be using colorful language on yourself and on that seat's mechanisms...until you eventually do get it right (and you will).
BUT, the absolutely critical issue is documenting the location of all six lifting arms' gear-attachment, because being-off by only
one 'tooth', on one arm, will mess up the seat's movement coordination!
AND: being able to move the seat mechanisms to their fully upright (opened-up) positions before you
try to disassemble the mechanisms.
Once you initially get the mechanisms fully-up (and maybe fully-back, too---this will give you an ABSOLUTE
position to (try to) replicate, upon re-assembly), you shouldn't have to apply any further electricity to
the system, until you test out the operation of the solenoids....they're fun to watch them operate the conduited cables.
Edited by d500neil 2011-06-11 10:20 PM
ram300
Posted 2011-06-11 10:39 PM (#276418 - in reply to #276307)
1001001002525
Great info guys, thanks. Neil what did you use as lube on the tracks, slaves etc? Would copper antisieze be a good idea on the tracks or just a standard lithium grease?
d500neil
Posted 2011-06-12 5:33 PM (#276468 - in reply to #276418)
I just used lithium grease; altho the electrical connections to/at the solenoids might appreciate a dielectric grease
application. I Forget their initiation operation, right now.
The 6 toothed lifting arms really don't need to have any grease applied to them, once they're cleaned.
Any grease, there, will only attract/hold dirt to that area, and be counter-productive; maybe just a dab of grease
on their concavities---nothing much is needed.
Doctors don't like to operate on their own families, so, I'd like to overhaul your seat; it is a bit of an intellectual/manual
challenge to record everything's position that you touch/move/adjust, but, it is, in the end, an almost a purely mechanical
exercise, but it is a bit like a Rubick's cube, since both sides of the mechanism operate independently, with also together in a coordinated action....kinda like a marching band or military formation.
Edited by d500neil 2011-06-12 6:17 PM
christine-lover
Posted 2011-06-12 9:43 PM (#276494 - in reply to #276418)
2000500100100100100252525
ram300 - 2011-06-11 10:39 PM
I wouldn't use anti seize, that stuff gets hard after some time. I'd go with a good white lithium grease.
d500neil
Posted 2011-06-13 2:24 PM (#276547 - in reply to #276307)
Y'know....what you probably should try doing (altho it is no where near as macho as doing both sides at the same time)
is overhauling the passenger's side first, just to get the 'hang' of the three lifting levers' positioning and operation.
When you're done cleaning/lubing/polishing/painting that half, you can ensure that it operates in conjunction with the
driver's side.
At that point, the two sides may still work poorly (depending upon the mechanical-electrical condition of the driver's side)
but, you can play with the adjustment of the passenger's side easier than you can with the driver's side, and the adjustment/
documentation lessons that you learn over on the passenger's side should carry over to the driver's side (where all of the 'fun'
work resides).
Posted 2011-06-13 2:47 PM (#276553 - in reply to #276307)
500050002000100025
(Resize of Demounted_master1.jpg)
(Resize of Demounting_of_master_reduction_gear_drive01.jpg)
(Resize of Demounting_of_master_reduction_gear_drive02.jpg)
(Resize of Demounting_of_master_reduction_gear_drive03.jpg)
(Resize of Demounting_of_master_reduction_gear_drive04.jpg)
(Resize of Demounting_of_master_reduction_gear_drive06.jpg)
(Resize of Demounting_of_master_reduction_gear_drive07.jpg)
(Resize of Demounting_of_master_reduction_gear_drive08.jpg)
(Resize of Demounting_of_master_reduction_gear_drive09.jpg)
(Resize of Demounting_of_master_reduction_gear_drive10.jpg)
(Resize of Demounting_of_slave_actuator.jpg)
(Resize of Demounting_of_slave_actuator1.jpg)
(Resize of Demounting_Slave.jpg)
Attachments Resize of Demounted_master1.jpg (56KB - 172 downloads)
Attachments Resize of Demounting_of_master_reduction_gear_drive01.jpg (50KB - 166 downloads)
Attachments Resize of Demounting_of_master_reduction_gear_drive02.jpg (37KB - 170 downloads)
Attachments Resize of Demounting_of_master_reduction_gear_drive03.jpg (50KB - 165 downloads)
Attachments Resize of Demounting_of_master_reduction_gear_drive04.jpg (49KB - 176 downloads)
Attachments Resize of Demounting_of_master_reduction_gear_drive06.jpg (44KB - 165 downloads)
Attachments Resize of Demounting_of_master_reduction_gear_drive07.jpg (46KB - 166 downloads)
Attachments Resize of Demounting_of_master_reduction_gear_drive08.jpg (43KB - 165 downloads)
Attachments Resize of Demounting_of_master_reduction_gear_drive09.jpg (43KB - 166 downloads)
Attachments Resize of Demounting_of_master_reduction_gear_drive10.jpg (55KB - 170 downloads)
Attachments Resize of Demounting_of_slave_actuator.jpg (62KB - 168 downloads)
Attachments Resize of Demounting_of_slave_actuator1.jpg (67KB - 166 downloads)
Attachments Resize of Demounting_Slave.jpg (55KB - 156 downloads)
d500neil
Posted 2011-06-13 3:56 PM (#276563 - in reply to #276307)
That's them--btw, all of those gears-and spacers, above, fall-apart from each other, and, unless Sven would
have very carefully recorded/documented the orientation of those gears and the three lifting levers, as they
engage the gears, he would have been in deep doo-doo, trying to guessstimate the levers' proper orientation
when he would have tried to reassemble the mechanism.
And, about the only way that an overhaul can be performed is when the mechanisms are raised up to their full height.
Edited by d500neil 2011-06-13 8:09 PM
d500neil
Posted 2011-06-13 4:02 PM (#276566 - in reply to #276307)
And, now/then, Sven, show everyone the motor-solenoids and the orientation of the three conduited wire cables
that run to the driver's side gear set.
What's really nice about this project is that no special tools or equipment are required.
Posted 2011-06-14 12:41 PM (#276686 - in reply to #276307)
500050002000100025
(Resize of IMG_1949.jpg)
(Resize of IMG_1954.jpg)
(Resize of Resize of IMG_1958.jpg)
(Resize of Motor_drive_unit.jpg)
Attachments Resize of IMG_1949.jpg (103KB - 154 downloads)
Attachments Resize of IMG_1954.jpg (114KB - 164 downloads)
Attachments Resize of Resize of IMG_1958.jpg (122KB - 163 downloads)
Attachments Resize of Motor_drive_unit.jpg (83KB - 156 downloads)
Posted 2011-06-14 12:49 PM (#276691 - in reply to #276307)
500050002000100025
(Resize of Master_L-side00.jpg)
(Resize of Master_L-side01.jpg)
(Resize of Master_L-side02.jpg)
(Resize of Master_L-side03.jpg)
(Resize of Master_L-side04.jpg)
(Resize of Master_L-side05.jpg)
(Resize of Mounted_Slave_Actuator.jpg)
(Resize of Mounted_Slave_Actuator1.jpg)
(Resize of Mounted_Slave_Actuator2.jpg)
(Resize of Mounted_Slave_Actuator3.jpg)
(Resize of Mounted_Slave_Actuator4.jpg)
(Resize of Mounted_master_slave.jpg)
Attachments Resize of Master_L-side00.jpg (72KB - 167 downloads)
Attachments Resize of Master_L-side01.jpg (109KB - 171 downloads)
Attachments Resize of Master_L-side02.jpg (111KB - 164 downloads)
Attachments Resize of Master_L-side03.jpg (146KB - 175 downloads)
Attachments Resize of Master_L-side04.jpg (135KB - 179 downloads)
Attachments Resize of Master_L-side05.jpg (174KB - 183 downloads)
Attachments Resize of Mounted_Slave_Actuator.jpg (106KB - 168 downloads)
Attachments Resize of Mounted_Slave_Actuator1.jpg (115KB - 154 downloads)
Attachments Resize of Mounted_Slave_Actuator2.jpg (92KB - 160 downloads)
Attachments Resize of Mounted_Slave_Actuator3.jpg (108KB - 166 downloads)
Attachments Resize of Mounted_Slave_Actuator4.jpg (121KB - 178 downloads)
Attachments Resize of Mounted_master_slave.jpg (71KB - 161 downloads)
Posted 2011-06-14 12:57 PM (#276693 - in reply to #276307)
500050002000100025
The wood frame is for to be able to move/transport the power seat without damaging the cable housings
d500neil
Posted 2011-06-14 9:45 PM (#276742 - in reply to #276693)
Very nice before-and-after; Sven, do you have any pics of the solenoids' overhaul?
When I did all this, at least I didn't have to open up the motor!---but everything else got the O/H work done
to it.
Note how Sven has marked those three cables; they come right out and it would be confusing to try to second-guess
their subsequent installation order, if not so-marked before their removal.
Posted 2011-06-15 12:31 AM (#276788 - in reply to #276307)
500050002000100025
The solenoids where in good working order, so I did not open them Neil. No pictures on them.
miquelonbrad
Posted 2011-06-15 9:43 AM (#276807 - in reply to #276307)
100050010010025
WOW!!!!! Hey, thanks guys!! I haven't done mine yet, so this is all great info!! I probably would'a screwed it up.
DieselJeep
Posted 2016-10-23 8:34 AM (#524125 - in reply to #276307)
Hey look, an EXCELLENT writeup, with plenty of pics, warnings, and advice buried in posts from 2011!!
Are sticky threads organized for reference not done here?
Edited by DieselJeep 2016-10-23 8:35 AM
