Modeling my 59 Dodge in 3D-CAD Jump to page : 1 2 3 Now viewing page 3 [50 messages per page] | View previous thread :: View next thread |
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | Fantastic work by the master! | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | 1962 Chrysler New Yorker Emblem: Out of the line I present how to model an emblem. As I like the 1962 Chrysler New Yorker Emblem I purchased once a time ago just for modeling, as it is easy to create. This as well to motivate others for doing the same when fascinated. First a sample in hand is needed! Then take a picture exact from front view. In Photoshop (PS) open the picture, set the canvas size according the emblem size: 177 x 64.8mm, and position/scale/rotate it to fit exact in height, width and horizontal with the help of some guide lines (001). Cut-out all around the emblem, create a contour line with the border selection tool (002), and save the two pictures as JPG. In the attachment add .JPG on the names to get the picture in real size, or too big here on screen! These pictures insert in separate sketches (sketch tool, SW2016). Now draw the lines along the parts and dimension to fix them. All this will be the MasterSketch to be used for position and create the 5 parts: Center letter C. Generated by “Swept Boss” to get rounded faces, along 4 contour guide lines and 3 intersections (start-mid-end). Only one quarter is needed, the others are mirrored horizontal and vertical. Then cut-out to get a “C” from the “O” (03). Upper Ornament. Use as well the contour, the borders are all done by sweeping to avoid any flat face. Left side done, the right side simply bay mirror (04). Lower Ornament. All similar to the upper ornament (05). Center Bar. All again, but swept in one and then cut-out in the center (06). Rear Black Base. Extrude the base contour in the original thickness (07). The Final Emblem. Apply some fillets where needed according the sample, check all dimensions (point to point with the measurement tool) and modify them to be correct.
Now the 1962 Chrysler New Yorker Emblem is ready. Merged all parts to a single Solid Body it can be used for 3D-Printing!
Good Luck - SERGE -
Edited by sermey 2020-04-06 6:26 AM (01 Picture PS inserted.jpg) (02 Contour PS inserted.jpg) (03 Center Letter C modeled.jpg) (04 Upper Ornament modeled.jpg) (05 Lower Ornament modeled.jpg) (06 Center Bar modeled.jpg) (07 Rear Black Base modeled.jpg) (08 Final Emblem - no RealView.jpg) (09 Final Emblem - RealView.jpg) Attachments ---------------- 01 Picture PS inserted.jpg (115KB - 371 downloads) 02 Contour PS inserted.jpg (65KB - 375 downloads) 03 Center Letter C modeled.jpg (76KB - 345 downloads) 04 Upper Ornament modeled.jpg (114KB - 361 downloads) 05 Lower Ornament modeled.jpg (125KB - 360 downloads) 06 Center Bar modeled.jpg (121KB - 344 downloads) 07 Rear Black Base modeled.jpg (122KB - 359 downloads) 08 Final Emblem - no RealView.jpg (85KB - 333 downloads) 09 Final Emblem - RealView.jpg (124KB - 368 downloads) 001 Picture 1962 Chrysler New Yorker Emblem 177x64.8mm (179KB - 375 downloads) 002 Contour 1962 Chrysler New Yorker Emblem 177x64.8mm (176KB - 349 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | For download EPRT-File: 1962 Chrysler New Yorker Emblem This for those who like play on the computer. As the file has 402kB I split it in two files so as can be uploaded: 1962 Chrysler New Yorker Emblem.001 (256kB) 1962 Chrysler New Yorker Emblem.002 (146kB) Then for merge the batch file: Merge 1962 Chrysler New Yorker Emblem.bat (1kB)
Download the 3 files in a new folder (named EPRT). Double-click on the batch file and you will get the eDrawing file: 1962 Chrysler New Yorker Emblem.EPRT (402kB) If you don’t have the program already, download “eDrawings” version for free and install (need Version 2016 or newer). This free version doesn't support RealView, you will see as standard. Just open the EPRT File (Password: sermey), then you can turn, zoom, resize and animate automatic the emblem (01) (02) (03). You will encounter a tremendous quality and resolution.
Enjoy! - SERGE - Edited by sermey 2020-04-06 6:25 AM (01 1962 Chrysler New Yorker Emblem Front View.jpg) (02 1962 Chrysler New Yorker Emblem Rear View.jpg) (03 1962 Chrysler New Yorker Emblem.jpg) Attachments ---------------- 01 1962 Chrysler New Yorker Emblem Front View.jpg (92KB - 334 downloads) 02 1962 Chrysler New Yorker Emblem Rear View.jpg (94KB - 374 downloads) 03 1962 Chrysler New Yorker Emblem.jpg (119KB - 333 downloads) 1962 Chrysler New Yorker Emblem.001 (256KB - 343 downloads) 1962 Chrysler New Yorker Emblem.002 (145KB - 344 downloads) Merge 1962 Chrysler New Yorker Emblem.bat (0KB - 344 downloads) | ||
Ev's62Chrysler |
Veteran Posts: 210 Location: Suwanee, GA | Serge, Nice work, but you missed the recesses at the top and bottom of the "C". I struggled with it and had to get help adding the upper recess to mine. Haven't done the lower one yet. Robert (MLC Sample of Car Logo.JPG) Attachments ---------------- MLC Sample of Car Logo.JPG (125KB - 378 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Modification on Letter “C: According the comment of Robert I did minor changes on the Letter “C”. As the emblem was done just quickly, not like the 1959 Dodge parts, some details not have been checked seriously. The upper oval guidelines I found on a too high position. When lofted the top, the “recession” then became bigger. Thanks Robert. As there should be no flat faces at all to appear authentic, no boss/extrude operations have been applied, as done on the presented model of Robert. Instead, all the bodies were created by multiple lofts. Here using 4 spline guidelines (in blue) and tree section profiles (in red) to generate the first quarter (01). This quarter mirrored vertical (02), and then horizontal. All fillets are variable and elliptical as is the emblem (03). Not forget that the top of the letter is curved (04), and that all emblem parts are joined to the backplane (D=2.5mm).
The final letter “C” (05) is attached as eDrawing file. Another challenging “game”. – SERGE - Edited by sermey 2020-04-12 4:43 AM (01 Loft Profile.jpg) (02 Quarter Mirrored.jpg) (03 Variable Elliptical Fillet.jpg) (04 Curved Top.jpg) (05 Final Letter C.jpg) Attachments ---------------- 01 Loft Profile.jpg (102KB - 355 downloads) 02 Quarter Mirrored.jpg (92KB - 332 downloads) 03 Variable Elliptical Fillet.jpg (115KB - 335 downloads) 04 Curved Top.jpg (79KB - 328 downloads) 05 Final Letter C.jpg (94KB - 363 downloads) 2020-04-11 SW16 Letter C 1962 Emblem.EPRT (181KB - 356 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | License Plate 1959 FLORIDA: For a Convertible I had the choice between a state where it “never rains” (. . . in California) or where is always “sunshine” (...in Florida). Being many times in Miami for business and holidays, obviously I preferred the Sunshine State. I found some nice original 1959 FLORIDA License Plates, especially to get all numbers and the various layouts. A flatbed color scan of the plate produces undistorted pictures in real size for the layout, and the colors of the paint then could exactly be detected. Of course after cleaning the surface to get the color combo as new. The size 303 x 150mm and the thickness I measured 0.8mm. Here my various original plates in isometric view (01)(02)(03)(04). Then two mounted plates including all numbers (05)(06), for those who like create their own configuration, by selecting, copying and paste. Thus I added a blank plate, front and rear view , keeping the background in black for easy cutout (07)(08). Finally the rear view of the first license plate (09). Now the hobby can go on – with clean hands. – SERGE – Edited by sermey 2020-04-14 8:39 AM (01 FLORIDA 27-3999.jpg) (02 FLORIDA 26w-3214.jpg) (03 FLORIDA 16-567.jpg) (04 FLORIDA 7-45361.jpg) (05 FLORIDA 12-34567.jpg) (06 FLORIDA 45w67890.jpg) (07 Blank Plate Front View.jpg) (08 Blank Plate Rear View.jpg) (09 FLORIDA 27-3999 Rear View.jpg) Attachments ---------------- 01 FLORIDA 27-3999.jpg (113KB - 349 downloads) 02 FLORIDA 26w-3214.jpg (115KB - 367 downloads) 03 FLORIDA 16-567.jpg (108KB - 333 downloads) 04 FLORIDA 7-45361.jpg (112KB - 358 downloads) 05 FLORIDA 12-34567.jpg (91KB - 326 downloads) 06 FLORIDA 45w67890.jpg (95KB - 316 downloads) 07 Blank Plate Front View.jpg (64KB - 332 downloads) 08 Blank Plate Rear View.jpg (58KB - 326 downloads) 09 FLORIDA 27-3999 Rear View.jpg (90KB - 364 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | The 1959 DODGE Lost Emblem: another Emblem . . . . . again and again (no comment). - SERGE - Basto - Again and Again (Official Music Video) [HD] - YouTube Edited by sermey 2020-05-01 10:15 PM (01 1959 Dodge The Unique Emblem.jpg) (02 1959 Dodge The Lost Emblem.jpg) (03 1959 Dodge The Lost Emblem.jpg) (04 1959 Dodge The Lost Emblem SP.jpg) Attachments ---------------- 01 1959 Dodge The Unique Emblem.jpg (87KB - 352 downloads) 02 1959 Dodge The Lost Emblem.jpg (66KB - 357 downloads) 03 1959 Dodge The Lost Emblem.jpg (65KB - 330 downloads) 04 1959 Dodge The Lost Emblem SP.jpg (70KB - 321 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Golden Knight Emblem - King Size: Meanwhile the Knight Emblem was optimized to fit best to the front grille of all 1959 DODGEs, and now is ready for 3D printing. Here some CAD RealView pictures. The Knight was non-linear resized for a harmonic appearance (01). The face is bent according the center angle of the grille, 170deg (02). The length of the studs are cut to match the surface and keep a fixed distance (03). Finally, the surface of the resized Knight will be electro-plated in glossy gold (or chrome) (04). Mounted on the front grille it seems this emblem was always there (05). – SERGE –
N.B. The realized Knight Emblem is shown in the thread “Make-up your Car” (to come). Edited by sermey 2020-09-03 5:17 AM (01 CAD Resine Front - Rear View.jpg) (02 CAD Top - Bottom View.jpg) (03 CAD Rear View.jpg) (04 CAD Front View Glossy Golden Plated.jpg) (05 CAD Mounted on the Grille.jpg) Attachments ---------------- 01 CAD Resine Front - Rear View.jpg (93KB - 296 downloads) 02 CAD Top - Bottom View.jpg (72KB - 295 downloads) 03 CAD Rear View.jpg (78KB - 285 downloads) 04 CAD Front View Glossy Golden Plated.jpg (91KB - 283 downloads) 05 CAD Mounted on the Grille.jpg (184KB - 292 downloads) | ||
22mafeja |
Elite Veteran Posts: 654 Location: Finland | Serge ,your skills are beyond fantastic...the words are not enough....incomprehensive for me... | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | 3D-Printed Rear Antenna Base: Multiple samples in material and colors, for identify, have been built for functional and mechanical tests (01) (02). The stress test without the antenna tube inside shows the weakest part of the base and gives a magnitude of the maximum load (03). Then the sheetmetal of the car will be somewhat bent! For functional test the Power Antenna Set is mounted on the car (04). The top end can be set according the original length of the original mast, here somewhat shorter (05). As the Antenna Base is black, the rubber looks as intergrated in one. Anyway, a compact and harmonic assembly. The final antenna base then will be glossy chrome electro plated. - SERGE -
Edited by sermey 2020-09-17 1:57 PM (01 Various 3D-Printed Antenna Bases.jpg) (02 Antenna Bases Top View.jpg) (03 Crash Test.jpg) (04 Mounted Assembly.jpg) (05 Top End.jpg) (06 Mounted View.jpg) Attachments ---------------- 01 Various 3D-Printed Antenna Bases.jpg (116KB - 238 downloads) 02 Antenna Bases Top View.jpg (103KB - 244 downloads) 03 Crash Test.jpg (90KB - 230 downloads) 04 Mounted Assembly.jpg (123KB - 226 downloads) 05 Top End.jpg (106KB - 228 downloads) 06 Mounted View.jpg (131KB - 242 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Rear Antenna Base Glossy Chrome Plated: The most critical check of a surface is when it is glossy chrome plated. Any unevenness is reflected, also the roughness of the ceiling in my garage. All pairs, left and right, view from various angles, are identical (01). Here another dual side view (02). Beside an original antenna base on my car, a difference is hardly visible (03). The top nut will be relaced by a black TopFix, as the base is designed for. Can say, this is another perfect job! Not for puritans – they prefer originals, in pot metal and some minor pits! - SERGE - :laugh: Edited by sermey 2020-09-21 6:24 AM (01 Base Glossy Chrome Plated.jpg) (02 Base Glossy Chrome Plated.jpg) (03 Antenna Base Comparison.jpg) Attachments ---------------- 01 Base Glossy Chrome Plated.jpg (114KB - 231 downloads) 02 Base Glossy Chrome Plated.jpg (132KB - 234 downloads) 03 Antenna Base Comparison.jpg (155KB - 244 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Cap MIRROR CONTROL: For beginners detailed proceeding, works on any 3D-CAD software.
01 Sketch section and “Revolve” 360deg on axis red. 02 Add some fillets. 03 New surface for set letters along arc, next “Surface-Offset” deep -0.25mm = depht of engravement (left), “Split Line” letters to this surface-offset. 04 Start “Cut-Thicken” each letter separate, from surface-offset up to >0.25mm. 05 All letters cut, “Boss” cam for centering and “CirPattern” 3x 120deg 06 “Edit Appearance” body black, letters surface white Done “Italic” = SolidWorks Commands Good Luck! - SERGE -
Edited by sermey 2022-10-09 11:57 AM (01 Revolve Section 360deg.jpg) (02 Add some Fillets.jpg) (03 Letters on new Surface along Arc.jpg) (04 Start Cut Letters from Surface-Offset up.jpg) (05 Cut Cap Done for Check.jpg) (06 Cap MIRROR CONTROL .jpg) Attachments ---------------- 01 Revolve Section 360deg.jpg (104KB - 82 downloads) 02 Add some Fillets.jpg (102KB - 75 downloads) 03 Letters on new Surface along Arc.jpg (110KB - 78 downloads) 04 Start Cut Letters from Surface-Offset up.jpg (124KB - 93 downloads) 05 Cut Cap Done for Check.jpg (123KB - 78 downloads) 06 Cap MIRROR CONTROL .jpg (85KB - 80 downloads) | ||
57Fireflite |
Regular Posts: 59 | Makes a grown man weep with joy… What are the chances you would be willing to hold and record a tutorial session so we can all start doing this — or at least give it a shot? | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Thanks James for your kind comment. There are many tutorials available in the internet. With some applied samples of FWL-parts I try to provide some variety in this mostly mechanical oriented site. For me this is just as another game. As you may observe in my threads, there are minor interested guys to participate in this direction. Always pleased to read some encouraging words like yours. - SERGE - | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Door Stop: The mechanical function of the door stop is the same for 1957 – 1959 Plymouth / Dodge, may-be as well for other mopars. They all don’t have an intermediate door catch. To find solutions for this option, the disposable space and the function should be analysed by 3D-Modelling. The main part is the bracket unit (01). Built-in parts the bracket, a damping grommet, a retaining washer, and two stop springs fixed with a rivet (02). The bracket unit, inserted from rear, is lateral guided and free movable along the slot (03)(04). At fully open door, the damping grommet marks the end stop (05), can see the springs to trap the door (06). Not shown the hinge with the pin, entering partly in the door. Left and right door are identical, just mirrored. These CAD-views of a white painted car visualize the function, and helps for design a much-needed option - an intermediate door catch (07). - SERGE - Edited by sermey 2022-11-21 5:01 PM (01 Bracket Unit.jpg) (02 Bracket Unit Disassembled.jpg) (03 Bracket Unit Mounted.jpg) (04 Top View Unit Mounted.jpg) (05 Top View Door Fully Open.jpg) (06 Front View Door Fully Open.jpg) (07 Overview Door.jpg) Attachments ---------------- 01 Bracket Unit.jpg (53KB - 65 downloads) 02 Bracket Unit Disassembled.jpg (60KB - 61 downloads) 03 Bracket Unit Mounted.jpg (65KB - 64 downloads) 04 Top View Unit Mounted.jpg (67KB - 67 downloads) 05 Top View Door Fully Open.jpg (97KB - 67 downloads) 06 Front View Door Fully Open.jpg (72KB - 60 downloads) 07 Overview Door.jpg (55KB - 67 downloads) | ||
