RCA AP-1 Record Changer Renovation Jump to page : 1 2 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | I finally got myself the much wanted RCA record changer. The price was fair, but the state was kind of poor. Here's some pictures of the process. (Resize of IMG_5931.JPG) (Resize of IMG_5945.JPG) (Resize of IMG_5965.JPG) (Resize of IMG_5969.JPG) Attachments ---------------- Resize of IMG_5931.JPG (78KB - 589 downloads) Resize of IMG_5945.JPG (103KB - 454 downloads) Resize of IMG_5965.JPG (51KB - 439 downloads) Resize of IMG_5969.JPG (69KB - 456 downloads) | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | After cleaning all the parts with citric acid, I coated them with a light coat of silver paint. I couldn't risk to send all the parts away for proper threatment due to the BIG risk of loosing parts. (Resize of IMG_5942.JPG) (Resize of IMG_5944.JPG) (Resize of IMG_5977.JPG) (Resize of IMG_5978.JPG) Attachments ---------------- Resize of IMG_5942.JPG (38KB - 445 downloads) Resize of IMG_5944.JPG (28KB - 438 downloads) Resize of IMG_5977.JPG (28KB - 443 downloads) Resize of IMG_5978.JPG (31KB - 436 downloads) | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | The progress goes slowly, here's some more parts ready for assembly. I think that I've got a lead on the stylus now - the Pfanstiehl 911-D7 should fit, according to the rumor - I'll find out in good time. The rubber bellows with the spring inside is the worst challenge yet - I have no leads for them yet, sent a couple of mails, but still no reply's. (Resize of IMG_5984.JPG) Attachments ---------------- Resize of IMG_5984.JPG (29KB - 440 downloads) | ||
miquelonbrad |
Expert Posts: 1737 Location: Hay Lakes, Alberta, Canada | Wow! Looks good! I've restored radios that looked that rusty too... quite a challenge! | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | Today I built a stand for the player, so that I can get good access from all sides. The stand has a swivel function, using the original transportation safety brackets and bolts. So far so good, the kinetics is really nice, ingenious and lightweight. Now all the tripping function works again mechanically. (Resize of IMG_6001.JPG) (Resize of IMG_6002.JPG) (Resize of IMG_6003.JPG) (Resize of IMG_6004.JPG) (Resize of IMG_6005.JPG) (Resize of IMG_6006.JPG) (Resize of IMG_6007.JPG) (Resize of IMG_6008.JPG) (Resize of IMG_6009.JPG) Attachments ---------------- Resize of IMG_6001.JPG (38KB - 538 downloads) Resize of IMG_6002.JPG (37KB - 565 downloads) Resize of IMG_6003.JPG (36KB - 437 downloads) Resize of IMG_6004.JPG (32KB - 467 downloads) Resize of IMG_6005.JPG (33KB - 442 downloads) Resize of IMG_6006.JPG (40KB - 447 downloads) Resize of IMG_6007.JPG (45KB - 457 downloads) Resize of IMG_6008.JPG (42KB - 453 downloads) Resize of IMG_6009.JPG (45KB - 502 downloads) | ||
catman |
Elite Veteran Posts: 781 Location: Montreal, Canada | Wiz, As always very well done and informative. You will always amaze me. But................... I have one sugestion for you. You should use an old Johnny Cash 45's from the fifties or some rockabilly instead of the one you are using. You are lucky your car is not Christine, otherwise you'd be in trouble....... Bara ett skämt, min vän. Again good job, keep us posted. | ||
agirlandher58 |
Extreme Veteran Posts: 369 Location: buchanan,Ga. | hey Wiz looking good on that repair!Have to got a lead on those rubber bellows-buchings yet?If not I'm pretty sure i have found a supplier off e bay.They are being sold in a set of nine. | ||
agirlandher58 |
Extreme Veteran Posts: 369 Location: buchanan,Ga. | have you got a lead on those bushing.... sorry for the typos. | ||
hemidenis |
Expert Posts: 3887 Location: Northen Virginia | Always amazing wiz | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | No Teffany, I only have JC-Auto and they do not have the "correct" ones, theirs are made from foam rubber and should use the original springs. I could make foamrubber ones by myself, so I'm interested to know about your lead. Thanks Denis - and to you! | ||
agirlandher58 |
Extreme Veteran Posts: 369 Location: buchanan,Ga. | I think these will work but you'll have to keep the springs from the old ones ....he also carries the rebuild idler wheels. (record player bushings.jpg) (record player bushings 001.jpg) Attachments ---------------- record player bushings.jpg (44KB - 485 downloads) record player bushings 001.jpg (78KB - 463 downloads) | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | Thanks Teffany, I'll check it up with him. The ones he shows are motor grommets, but I'm also search for the rubber (balloon) cushions with a spring inside them. | ||
mstrug |
Expert 5K+ Posts: 6500 Location: Newark, Texas (Fort Worth) | http://cgi.ebay.com/ebaymotors/ARC-2500-Car-12V-Underdash-Record-Pl... QQhashZitem3f04d64100QQitemZ270664089856QQptZVintageQ5fCarQ5fTruckQ5fPartsQ5fAccessories | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | wizard - 2010-11-20 8:44 PM Thanks Teffany, I'll check it up with him. The ones he shows are motor grommets, but I'm also search for the rubber (balloon) cushions with a spring inside them. Those motor grommets does not fit the automotive record changers. They have a external diameter of 0,500", while the ones in "our" record changers is 0,380". I guess it will be home made motor grommets then. Edited by wizard 2010-11-24 10:41 AM | ||
Royal |
Extreme Veteran Posts: 444 Location: Sweden Vansbro | Wow, Sven, It looks very good o far. This must be a very tricky job, but at the same time, interesting one. Good luck. | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | Nice to have you back posting on the forum Bengt! Thank's - I have not been able to do so much lately, I've been working with translation of the manual, so that I could fully understand how everything should be adjusted. I made some new motorgrommets out of cable grommets. Now the recordchanger works just fine. Only thing left is to renovate the switches. Edited by wizard 2010-12-04 1:50 PM (Resize of IMG_6011.JPG) (Resize of IMG_6020.JPG) (Resize of IMG_6021.JPG) (Resize of IMG_6022.JPG) Attachments ---------------- Resize of IMG_6011.JPG (38KB - 463 downloads) Resize of IMG_6020.JPG (54KB - 463 downloads) Resize of IMG_6021.JPG (58KB - 442 downloads) Resize of IMG_6022.JPG (48KB - 588 downloads) | ||
hemidenis |
Expert Posts: 3887 Location: Northen Virginia | exellent wiz, i worked with the switches, they are restorable. | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | Thank's Denis - now I have the record changer in working condition! The switches works as they should and all connections are ready. Now mechanically, remains only to fabricate a new idler roller and the rubber/ballon/spring cushions. Electrically remains to solve how to get the record player hooked up to a modern radio/CD/MP3 player, but they never seems to have any aux input?! Edited by wizard 2010-12-06 4:03 PM (Resize of IMG_6024.JPG) Attachments ---------------- Resize of IMG_6024.JPG (76KB - 611 downloads) | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | Today I managed to mount the casing in car on foamrubber and wood pieces, so that I could take measurements for to make the support brackets. The brackets are made out of stainless steel. (Resize of IMG_6030.JPG) (Resize of IMG_6031.JPG) (Resize of IMG_6032.JPG) Attachments ---------------- Resize of IMG_6030.JPG (25KB - 466 downloads) Resize of IMG_6031.JPG (24KB - 606 downloads) Resize of IMG_6032.JPG (26KB - 437 downloads) | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | The measurements (Resize of Bracket.jpg) Attachments ---------------- Resize of Bracket.jpg (32KB - 446 downloads) | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | Today I test mounted the record changer in the car. The brackets came out nicely, with a snug fit to clear the ash receiver and the glove compartment door. I'll try to post some measurements when I do the final mounting. (Resize of IMG_6033.JPG) (Resize of IMG_6036.JPG) (Resize of IMG_6038.JPG) (Resize of IMG_6040.JPG) Attachments ---------------- Resize of IMG_6033.JPG (68KB - 523 downloads) Resize of IMG_6036.JPG (110KB - 424 downloads) Resize of IMG_6038.JPG (73KB - 463 downloads) Resize of IMG_6040.JPG (77KB - 424 downloads) | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | Yesterday, I fabricated a new idler roller out of a block of plastic. i tried to match the orginal weight as close as possible. The idler has a groove for an ordinary O-ring, the O-ring is carefully grinded to a more square profile for better grip. (Resize of IMG_6049.JPG) (Resize of IMG_6050.JPG) (Resize of IMG_6051.JPG) Attachments ---------------- Resize of IMG_6049.JPG (53KB - 438 downloads) Resize of IMG_6050.JPG (73KB - 438 downloads) Resize of IMG_6051.JPG (42KB - 448 downloads) | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | Here are some pictures of one of the replacement stylus - Zenith. There are others from Pfanstiehl for example. (Resize of IMG_6047.JPG) (Resize of IMG_6048.JPG) Attachments ---------------- Resize of IMG_6047.JPG (28KB - 436 downloads) Resize of IMG_6048.JPG (54KB - 573 downloads) | ||
ttotired |
Expert 5K+ Posts: 8443 Location: Perth Australia | Man your good!!!!! | ||
catman |
Elite Veteran Posts: 781 Location: Montreal, Canada | Really impress with your work. | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | Thanks friends, I hope that my work can inspire and help our other FL'rs. | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | It's always a great pleasure to follow your perfect job you are doing. - SERGE - Edited by sermey 2010-12-14 3:31 PM | ||
61forfun |
Extreme Veteran Posts: 466 Location: Vancouver, Washington | Outstanding work.. you really brought that sucker back form the dea. Love your innovation and attention to detail. You don't mess around!! | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | Great progress tonight friends! I finally hooked up the record changer mechanism to my stereo - first nothing, then I discovered that the NOS pickup hade some verdigris and oxidation on the contacts. Some silver polish cured that. Then I got sound, but with heavy hum due to no screened cables. Found some TV antenna cable on the attic, and..... after who knows how many years, 20, 30 or more - there was sound again from the record changer. It's totally cool to play the old singles on the bench set-up and watch the movements of the slide during the tripping cycle. I'm very tired but happy - I'm gonna crash in bed now. | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | Here's the drawing for the final idler wheel I made. Takes some time to produce, but it's not very difficult. (Resize of RCA-ARC_idler.jpg) Attachments ---------------- Resize of RCA-ARC_idler.jpg (36KB - 436 downloads) | ||
Greg P. |
Elite Veteran Posts: 769 Location: Oley, PA | Wow that's just incredible Wizard! You are an inspiration. Congrats on getting that machine to make music again! | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | Thank's Greg! Today I fabricated my prototype rubber cushions out of 1/4" special foam rubber (no, I don't know yet, but it's almost like silicone, but it's possible to glue). All the parts are glued together on a teflon dime (also used for to grind them round). I made my cushions hollow for to try to get a good softness but at the same time good sideway support agains the centrifugal forces and brake forces while driving. (Resize of IMG_6060.JPG) (Resize of IMG_6062.JPG) (Resize of IMG_6063.JPG) (Resize of IMG_6065.JPG) (Resize of IMG_6067.JPG) (Resize of IMG_6068.JPG) (Resize of IMG_6069.JPG) (Resize of IMG_6070.JPG) Attachments ---------------- Resize of IMG_6060.JPG (68KB - 545 downloads) Resize of IMG_6062.JPG (70KB - 423 downloads) Resize of IMG_6063.JPG (36KB - 464 downloads) Resize of IMG_6065.JPG (25KB - 422 downloads) Resize of IMG_6067.JPG (61KB - 475 downloads) Resize of IMG_6068.JPG (52KB - 427 downloads) Resize of IMG_6069.JPG (37KB - 425 downloads) Resize of IMG_6070.JPG (40KB - 417 downloads) | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | Here is more progress on my prototype rubber cushions. First picture shows the sad remains of the original ones. Note the small hole on the top washer - this is the original air escape. Now I need to understand the differences between the original cushions. It seems like that the same spring was used for all three, but the springs where stretched out on the front one and the left rear one, while the one close to the motor was left unstretched. My cushions could have been more cosmeticall done, but they're prototypes and I want to test my idea in practical use first of all. Edited by wizard 2011-01-01 11:18 AM (Resize of IMG_6075.JPG) (Resize of IMG_6081.JPG) (Resize of IMG_6082.JPG) (Resize of IMG_6083.JPG) (Resize of IMG_6085.JPG) Attachments ---------------- Resize of IMG_6075.JPG (28KB - 624 downloads) Resize of IMG_6081.JPG (27KB - 450 downloads) Resize of IMG_6082.JPG (39KB - 437 downloads) Resize of IMG_6083.JPG (32KB - 575 downloads) Resize of IMG_6085.JPG (75KB - 411 downloads) | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | Update and new progress, due to using NOS ceramic cartridges, I misunderstood everything and the preamplifier is not needed at all!!! The new Pfansteihl cartridges has an output of up to 1,5 volts and does not need anything. Today I played for hours on my record changer with very good sound. | ||
Bart_59_Dodge |
Expert Posts: 1443 Location: Oconomowoc Wi | How about tossing up a YouTube of you playing a record... Lets hear the sound quality, and see this baby in action. | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | I actually don't know how to do it Bart?! I'll be out working this week, I'll try to inform myself how its done and eventually try to upload something next weekend. | ||
agirlandher58 |
Extreme Veteran Posts: 369 Location: buchanan,Ga. | So Wiz am i understanding you right that you can get this unit to produce sound by just hooking up a 12 volt hot and a good known ground then simply out to speakers and it plays???If so i misunderstood too i allways thought that they had to be hooked up to the radio so that the low voltage signal from the player needle cart. to be amplfied, then out to the speakers.In fact just to keep the radio and record player apart i bought a preamp to run it apart from the radio.... | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | No Teff, you dont need a preamplifier for to connect the recordchanger to a modern (no phono) input. Modern CD/radio/mp3 units dont have a phono in, some have an AUX in and I thought that the ouput from the record changer would be too low (based on bad NOS needles). | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | Ok, I think I managed to upload a Youtube clip now?! http://www.youtube.com/watch?v=VMcrMFop8Io Let's see if it works. | ||
agirlandher58 |
Extreme Veteran Posts: 369 Location: buchanan,Ga. | Wiz you got that player working just like new...way to go! I was really looking at the photos that you have posted here of your car ,geez your car is simply gorgeous!! I could only hope that mine comes out looking half as good as yours!!! How are those bushing working out that you made for the player? I made some out of a more hard setting up rtv with the springs inpreganted into them...these have a very slight give to them made this way but but still seem to have enough holding power not to have a whole lotta bounce to them either...kinda like a shock works.... | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | Thank's Teff, well I still have to test the homemade foamrubber cushions in the car. When I carry around the recordchanger while it plays, they work very well - the player never skips a groove. Mine are soft and giving, so the chassi can "float" around inside the casing. | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | Finally, today I mounted the record changer mechanism inside the casing and tested it with proper music. This has been a really interesting project and I've learned a lot about the record changers. http://www.youtube.com/watch?v=F3nczKy34V0 | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | Thanks to Teffany Moore (agirlandher58) and Dan Pawlak (dcpawlak) for supplying the documentation that made my renovation much more easier. | ||
61plymy |
Expert Posts: 2824 Location: Snohomish, WA. | Wiz man, I thought the main job of the pre-amp was to maintain RIAA equalization. It is different for Records VS taped recordings, for example. The roll-off per octave is different. Won't you loose this without a pre-amp (actually should be called an equalized buffer amplifier)? You do very good work Wiz. It's nice to see real craftsman at work. Mike | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | That's what I thought too Mike, but as the record changers has a ceramic pick-up they dont need anything at all. If you have a magnetic pick-up, then you need the RIAA equalization. I have a preamplifier for sale Edited by wizard 2011-02-06 2:49 PM | ||
Bryan1960Windsor |
Elite Veteran Posts: 689 Location: Santa Barbara, California | Dude, AWEsome work~!!! bryan | ||
sonoramicconvert |
Veteran Posts: 258 | wizard - 2010-11-16 3:35 AM I finally got myself the much wanted RCA record changer. The price was fair, but the state was kind of poor. Here's some pictures of the process. I have two players to get working, this thread will be VERY helpful..... Nice work | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | Thank's guys! I'm happy if someone can use my hints. | ||
61forfun |
Extreme Veteran Posts: 466 Location: Vancouver, Washington | This one goes in my " How To" file. Splendid engineering and resourcfullness. Thanks for sharing and being such an active member Mr. Wizard! | ||
polara61 |
Extreme Veteran Posts: 417 Location: Bräcke,Sweden | Wonderful thread and renovation.Can´t wait for your next project, how I wonder what it will be. Edited by polara61 2011-02-11 1:05 PM | ||
