Steering Column Removal - What's Wrong? Jump to page : 1 2 Now viewing page 2 [50 messages per page] | View previous thread :: View next thread |
ttotired |
Expert 5K+ Posts: 8443 Location: Perth Australia | Could you take photos of all the firewall to column stuff please? I am missing all of it from my Plymouth and I am not entirely sure what I am missing or how it attaches to the floor ect My dodge was different having manual steering (IMG_0727[18200].jpg) (IMG_0726[18202].jpg) Attachments ---------------- IMG_0727[18200].jpg (105KB - 471 downloads) IMG_0726[18202].jpg (53KB - 467 downloads) | ||
1coolbanana |
Veteran Posts: 267 Location: Sydney | Well, I got the insulator done today and all I can say is that Im very disappointed, bummed out and frustrated.
1coolbanana |
Veteran Posts: 267 Location: Sydney | Update.... The insulator I fitted, although not much different to the one I took out has made a huge amount of difference. So it wasnt doom and gloom after all. My first proper drive with some extended motorway, about 200 km's and its a huge improvement. Im quite pleased that the effort was worth it. | ||
Board Moderator & Exner Expert 10K+ Posts: 13045 Location: Southern Sweden - Sturkö island | Now if you change the Power steering fluid to Red Line Synthetic you will be even more happy with the handling. https://www.redlineoil.com/power-steering-fluid | ||
1coolbanana |
Veteran Posts: 267 Location: Sydney | wizard - 2018-11-04 8:50 PM Now if you change the Power steering fluid to Red Line Synthetic you will be even more happy with the handling. https://www.redlineoil.com/power-steering-fluid Really? Ill get some, surprisingly its available here! Ok, heres my stupid question for the day :-) How do you drain the steering fluid? | ||
Board Moderator & Exner Expert 10K+ Posts: 13045 Location: Southern Sweden - Sturkö island | Draw up the fluid with a syringe or oil changing pump. Start the Engine very shortly and drain as much as possible. Pour some new fliud in, start the Engine briefly and suck out as much fluid as possible. Fill up the pump with new fluid, start the Engine and "bleed" the servo starting up the Engine and turn the steering Wheel full right and full left slowely several times - done. The synthetic fluid can mix with a Little of the old fluid without problems | ||
1coolbanana |
Veteran Posts: 267 Location: Sydney | Ok, thanks again | ||
Expert 5K+ Posts: 7393 Location: northern germany | I'm using the stuff Wizard recommended without any problems for years and I believe it added a bit more "road feel", but I've been using synthetic ATF in it before and changed to a hard pressure line at the same time. A power steering cooler would be another plus. | ||
1coolbanana |
Veteran Posts: 267 Location: Sydney | Why is everything so hard to get in this country??? I can get that Redline but its a 50 mile round trip for 1 quart of oil | ||
Board Moderator & Exner Expert 10K+ Posts: 13045 Location: Southern Sweden - Sturkö island | As Sid writes, a power steering cooler is the optimal thing! Can't you get the fluid shipped, even with kangoroo express | ||
Expert 5K+ Posts: 7393 Location: northern germany | 1coolbanana - 2018-11-04 3:31 PM Why is everything so hard to get in this country??? I can get that Redline but its a 50 mile round trip for 1 quart of oil :wince: Come to Germany, you can mail order a quart for only $30+ here..... | ||
DE SOTO AMIGO |
Member Posts: 18 | i have the same problem but now i know what to do, very helpful thank you guys.,, 58 plymouth, 59 desoto and 59 dodge crown royal owner. | ||
DE SOTO AMIGO |
Member Posts: 18 | |||
Expert 5K+ Posts: 7393 Location: northern germany | 1960fury - 2018-11-04 3:21 PM I'm using the stuff Wizard recommended without any problems for years and I believe it added a bit more "road feel", but I've been using synthetic ATF in it before and changed to a hard pressure line at the same time. A power steering cooler would be another plus. Because this thread popped up again, still no problems or leaks with a 60+ year old untouched, daily used box. Why can't they make seals that last 20+ years today? | ||
Apollo 61 |
Elite Veteran Posts: 768 | I'm currently pulling sub frames out of a 63 300 and 61 Windsor I have read through this thread a few times Forgive me for going through this step by step. 1 . Pull steering wheel 2 . Remove turn signal assembly 3. Behind signal assembly is a snap ring that needs to be removed 4. Remove colum to dash frame mount 5. Remove firewall rubber seal 6 remove clamp 7 Jacket or sleeve will then slide off shaft to expose roll pin at box. 8. Drive out roll pin. Remove shaft. Is this correct? | ||
