What did you do to your FL car today?Jump to page : < ... 53 54 55 56 57 58 59 60 61 62 63 64 ... > Now viewing page 59 [50 messages per page] | View previous thread :: View next thread |
| Forward Look NON-Technical Discussions -> 1955-1961 Forward Look MoPar General Discussion | Message format |
| d500neil |
Exner Expert 19,174 posts. Neil passed away 18 Sep 2015. You will be missed, Neil! Posts: 19146 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: bishop, ca | You might want to re-position your radiator hose's upper "Corben Clip's" connection a little-more nearer to the thermostat, to increase the sealing/contact area of that hose, against/to the T-stat housing. A couple months ago, I replaced my car's upper radiator hose "just because" it was getting old(er), and because the existing upper radiator hose appeared to have been originally-cut about 1/4" - 1/2" too short, because the upper hose was tending to leak coolant from the bottom-area of its upper-hose connection. On this site, I was told that the 'best' upper radiator hose to use is : NAPA 7240 7240 is WAY...too long, but its middle-section can be cut to fit, well, between the radiator and the T-stat. So...bought-and-cut and installed 7240, only to find that its connection to the T-stat housing (and which connection surface I DID clean-up/prep, ahead of 'time'...) ...only to discover that the interior, and the general over-all condition of that 'old' hose was....FINE, but, what frosts my cake...is that the new hose leaks, much as the old hose had done. The existing (-old) Corben Clamp appears, still, to maintain a very tight grip against the T-stat neck....but, since its connection is still leaking/weepng, it appears that I'll need to replace that Corben Clamp in the near future. UNLESS... there is a commercial 'ointment' that I can apply to the T-stat's neck, that will seal its connection to/with the upper hose's connection to it??? I'd rather try applying a sealant to the upper radiator connection, than finding/buying another Corben clamp. DOES anyone have a spare-parts upper radiator hose clamp that they could sell to me??? [I guess that could try moving-relocating the Corben clamp's connection to/with the radiator hose, but, the fact that both 'hoses' leak similarly indicates that the leakage source may reside with the T-stat housing's neck configuration.....which goes 'back' to the application of some sort of liquid sealing agent, to the T-stat.] Edited by d500neil 2015-05-25 5:59 AM (PICT3569.JPG) (PICT3570.JPG) (PICT4563.JPG) (PICT4564.JPG) (PICT4565.JPG) Attachments ---------------- PICT3569.JPG (109KB - 770 downloads) PICT3570.JPG (106KB - 798 downloads) PICT4563.JPG (165KB - 772 downloads) PICT4564.JPG (164KB - 741 downloads) PICT4565.JPG (125KB - 761 downloads) | ||
| LD3 Greg |
Expert Posts: 1906 ![]() ![]() ![]() ![]() ![]() ![]() Location: Ontario, Canada | Neil, I'll check my stock tomorrow. I have all kinds of "Corbin" clamps left over. There, I put a note on my booze box to remind me!! Greg | ||
| LD3 Greg |
Expert Posts: 1906 ![]() ![]() ![]() ![]() ![]() ![]() Location: Ontario, Canada | In case you are wondering, my old booze box is rather respectable!! Greg (image.jpg) (image.jpg) Attachments ---------------- image.jpg (161KB - 788 downloads) image.jpg (190KB - 765 downloads) | ||
| d500neil |
Exner Expert 19,174 posts. Neil passed away 18 Sep 2015. You will be missed, Neil! Posts: 19146 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: bishop, ca | I dunno; can't see nothing but a (former-?) wine bottle, there! THANKS! | ||
| 60crossram |
Elite Veteran Posts: 836 ![]() ![]() ![]() ![]() ![]() Location: Layton, Utah | Is your t-stat housing pitted ? This is usually the cause of leakage. DeSoto lives !!! | ||
| jimntempe |
Expert Posts: 2312 ![]() ![]() ![]() ![]() Location: Arizona | Permatex #2 | ||
| christine-lover |
Expert Posts: 3002 ![]() ![]() Location: Sept. 1958 | I use GM Teflon PTFE for areas like this with coolant. But perhaps the clamp isn't squeezing properly, and or pits. I had the same concern on my daily driver several years ago and use it and it worked. | ||
| d500neil |
Exner Expert 19,174 posts. Neil passed away 18 Sep 2015. You will be missed, Neil! Posts: 19146 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: bishop, ca | Permatex #2 sounds good...but what is Teflon PTFE? The Permatex would be applied all-around the inside of the radiator hose (and, probably helps to slide the end of the hose over the T-stat housing, too? | ||
| fenix |
Expert Posts: 2121 ![]() ![]() Location: atlanta | Not a damm thing, spent the day in several cemetery's stickin' ol' glory in true patriot's final resting places, after all it is their day, and because of them i have the privilege and honor of stickin' ol' glory in sovereign American soil. And some of these countries can stick it also. France, 1945 Norway (?) Japan, 1946 Philippines, 1946 Greece, 1946 Italy, 1947 Belgium - ? Netherlands, 1945 (reinstated constitution after WWII?) Republic of China (Taiwan) (year ?) Denmark, 1953 (?) Republic of [South] Korea, 1948 Federal Republic of Germany, 1949 Hawaii, 1959 (admission to USA as 50th state) Guam, 1970 American Samoa, 1978 (elected Governor) Grenada, 1984 Republic of Poland, 1989 German Democratic Republic (East Germany), 1990 Republic of Hungary, 1990 Republic of Bulgaria, 1991 Kuwait, 1991 Iraqi Kurdistan, 1991 (date?) Lithuania, 1992 Czech Republic, 1992 Republic of Slovakia, 1992 Latvia, 1994 Kosovo, 2000 Afghanistan, 2001 Edited by fenix 2015-05-25 5:12 PM | ||
| christine-lover |
Expert Posts: 3002 ![]() ![]() Location: Sept. 1958 | d500neil - 2015-05-25 4:35 PM Permatex #2 sounds good...but what is Teflon PTFE? The Permatex would be applied all-around the inside of the radiator hose (and, probably helps to slide the end of the hose over the T-stat housing, too? Yeah, put it there on the hose. Looks like this. (image.jpg) Attachments ---------------- image.jpg (12KB - 809 downloads) | ||
| LD3 Greg |
Expert Posts: 1906 ![]() ![]() ![]() ![]() ![]() ![]() Location: Ontario, Canada | LD3 Greg - 2015-05-24 11:19 PM Neil, I'll check my stock tomorrow. I have all kinds of "Corbin" clamps left over. There, I put a note on my booze box to remind me!! Greg My upper rad hose is 1 7/8" in OD. The clamps I have are approx. 1 1/2" at rest and I can't squeeze them to the required size. Close, but they are too small. Greg | ||
| d500neil |
Exner Expert 19,174 posts. Neil passed away 18 Sep 2015. You will be missed, Neil! Posts: 19146 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: bishop, ca | Well, looks like Permatex to the rescue. It gets 'smeared' onto the hose's inner surface-connection with the Thermostat housing. THANKS! | ||
| 60crossram |
Elite Veteran Posts: 836 ![]() ![]() ![]() ![]() ![]() Location: Layton, Utah | I'm hopeing to have her running tomorrow. Today I put on the manifolds. Plug wires. Speedo cable. E-brake asy. Driveshaft. So close. There is always so many little things that need detailing. I have a really good muffler shop that is waiting to put duals on her. If anyone has a 60-61 air cleaner asy I am very interested in buying it from you. Chrysler lives !!! (20150530_201931.jpg) (20150530_201912.jpg) Attachments ---------------- 20150530_201931.jpg (156KB - 734 downloads) 20150530_201912.jpg (158KB - 704 downloads) | ||
| BigBlockMopar |
Expert Posts: 3579 ![]() ![]() ![]() ![]() ![]() ![]() Location: Netherlands | Appointed the wagon for a week of daily driver duty while my normal daily '73 Dart is in the garage for some sorely needed rust repairs. | ||
| fenix |
Expert Posts: 2121 ![]() ![]() Location: atlanta | Worked on the motor, trying to keep it running for the break in, the new starter started acting up yesterday and was making a hell of a noise, didn't want to mess up the flywheel so called it a day, today we dropped the left header and exhaust, removed the starter, i had another new one here and we compared the bendix movement and determined the starter wasn't extending far enough to engage the flywheel correctly, the new starter solved that problem. I could get the motor to run, but only by priming and filling the fuel bowl, today we took the line loose and had no gas past the regulator, next we filled a container with gas and it sucked some into the pump, but still no gas,i'm thinking bad regulator, removed the input line to the regulator, nothing, went a got a new fuel pump, fixed the problem, tomorrow, re-install the exhaust, and try to break the motor in. Gotta admit the motor sounds pretty good for a ballpark dial in, haven't set the timing or played with the jetting, and the first motor i've built in many moons. The way things are going, i may be cruising by Christmas, and i mean Christmas this year. | ||
| 60crossram |
Elite Veteran Posts: 836 ![]() ![]() ![]() ![]() ![]() Location: Layton, Utah | Finally got the engine and all the hook ups and detailing done. Fired her up and broke the cam in for 25 minutes. Sounds strong and throaty. A few more details and I'll have her on the road. Chrysler lives !!! (20150606_182917.jpg) Attachments ---------------- 20150606_182917.jpg (170KB - 785 downloads) | ||
| Windsor59 |
Expert Posts: 2608 ![]() ![]() ![]() Location: Upplands Väsby, Sweden | 60crossram - 2015-06-06 8:38 PM Finally got the engine and all the hook ups and detailing done. Fired her up and broke the cam in for 25 minutes. Sounds strong and throaty. A few more details and I'll have her on the road. Chrysler lives !!! Very nice work, I like it. | ||
| Windsor59 |
Expert Posts: 2608 ![]() ![]() ![]() Location: Upplands Väsby, Sweden | Many people here make their nice cars better, good to see .. The warmest day of the year (Sweden), take the opportunity to change places with the cars. Got help from friends. Heavy pulling Buick cradle of gravel. And had time to install the luggage light (bought it from Big M) and start with luggage pages that I purchased. (DSC_2328.JPG) (DSC_2337.JPG) Attachments ---------------- DSC_2328.JPG (130KB - 767 downloads) DSC_2337.JPG (58KB - 730 downloads) | ||
| christine-lover |
Expert Posts: 3002 ![]() ![]() Location: Sept. 1958 | Joakim, your Windsor is such a wonderful car! Beautiful! | ||
| Windsor59 |
Expert Posts: 2608 ![]() ![]() ![]() Location: Upplands Väsby, Sweden | christine-lover - 2015-06-13 3:51 PM Joakim, your Windsor is such a wonderful car! Beautiful! Thanks Matt. | ||
| wizard |
Board Moderator & Exner Expert 10K+ Posts: 13211 ![]() ![]() ![]() ![]() ![]() ![]() Location: Southern Sweden - Sturkö island | Aah, you should'nt have told Jocke that his car is nice - Now he will be impossible to deal with We all know that his car is nice and well done, but don't tell him that...................... | ||
| 60crossram |
Elite Veteran Posts: 836 ![]() ![]() ![]() ![]() ![]() Location: Layton, Utah | New dual exhaust with flow master mufflers. Sound good but not loud. I'm still looking for a correct year air cleaner. I've been out cruising her today, she's running very nice. I had to bypass the heater core because it started to leak. I swear you can drive something and never do anything to it, but the second you start fixing things everything else starts failing. It's so nice to cruise around in a forward look car again, something about them they just time warp you back to pastel and fin dreamland. (20150613_171333.jpg) (20150613_171351.jpg) (20150613_171410.jpg) Attachments ---------------- 20150613_171333.jpg (154KB - 797 downloads) 20150613_171351.jpg (161KB - 732 downloads) 20150613_171410.jpg (129KB - 709 downloads) | ||
| Windsor59 |
Expert Posts: 2608 ![]() ![]() ![]() Location: Upplands Väsby, Sweden | Wow super nice 61 STW. Good work. | ||
| Windsor59 |
Expert Posts: 2608 ![]() ![]() ![]() Location: Upplands Väsby, Sweden | Had not the original inside cobv moulding (looted) I have 2dr / ht moldings (not correct to a conv). When I was in the United States of Bo MalleFors I ordered 2st conv strips as they did to me. Got them in the spring. Was not entirely happy job considering the price, Took my strips and cut and stitch on. It was good. (DSC_2463.JPG) (DSC_2464.JPG) (DSC_2472.JPG) (DSC_2496.JPG) Attachments ---------------- DSC_2463.JPG (84KB - 734 downloads) DSC_2464.JPG (94KB - 764 downloads) DSC_2472.JPG (106KB - 754 downloads) DSC_2496.JPG (49KB - 779 downloads) | ||
| imopar380 |
Expert 5K+ Posts: 7229 ![]() ![]() ![]() ![]() ![]() Location: Victoria, BC, on Vancouver Island, Canada | I had to bypass the heater core because it started to leak. I swear you can drive something and never do anything to it, but the second you start fixing things everything else starts failing. Throw some stop-leak into your radiator, and it will probably cure the heater core leak. It did on mine, and it's been 7 years now. Edited by imopar380 2015-06-18 3:20 PM | ||
| wizard |
Board Moderator & Exner Expert 10K+ Posts: 13211 ![]() ![]() ![]() ![]() ![]() ![]() Location: Southern Sweden - Sturkö island | Windsor59 - 2015-06-18 9:13 PM Had not the original inside cobv moulding (looted) I have 2dr / ht moldings (not correct to a conv). When I was in the United States of Bo MalleFors I ordered 2st conv strips as they did to me. Got them in the spring. Was not entirely happy job considering the price, Took my strips and cut and stitch on. It was good. Looks really nice now Jocke - all those special parts for the convertibles can kill even the thickest wallet!!! | ||
| Windsor59 |
Expert Posts: 2608 ![]() ![]() ![]() Location: Upplands Väsby, Sweden | Thanks Sven, and have a nice midsummer | ||
| big m |
Expert 5K+ Posts: 7831 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: Williams California | I drove the '59 convert 50 miles over to the upholsterer in Marysville, where they are installing the convertible top. Hopefully they don't keep it too long. The car seemed to run out good on the highway. ---John | ||
| Windsor59 |
Expert Posts: 2608 ![]() ![]() ![]() Location: Upplands Väsby, Sweden | big m - 2015-06-19 12:10 PM I drove the '59 convert 50 miles over to the upholsterer in Marysville, where they are installing the convertible top. Hopefully they don't keep it too long. The car seemed to run out good on the highway. ---John Hi John Nice ( New top on) What color and vinyl or canvas ? | ||
| Windsor59 |
| big m |
Expert 5K+ Posts: 7831 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: Williams California | Windsor59 - 2015-06-19 11:27 AM big m - 2015-06-19 12:10 PM I drove the '59 convert 50 miles over to the upholsterer in Marysville, where they are installing the convertible top. Hopefully they don't keep it too long. The car seemed to run out good on the highway. ---John Hi John Nice ( New top on) What color and vinyl or canvas ? The top will be vinyl, and black, Joakim. | ||
| 60crossram |
Elite Veteran Posts: 836 ![]() ![]() ![]() ![]() ![]() Location: Layton, Utah | I put the wagon in the bountiful coats for kids car show today. Nice show. Its the only forward look car here obviously. There were quite a few mopar muscle cars here. I had one guy tell about a 58 Plymouth 2 door Belvedere with the sport tone sitting, he even had pictures on his phone of it. I'll have to go hunt it down. Chrysler lives !!! (20150620_132934.jpg) Attachments ---------------- 20150620_132934.jpg (183KB - 694 downloads) | ||
| Viper Guy |
Expert Posts: 2009 ![]() Location: Branson, MO | Good evening, I just returned from a 300 mile round trip driving my '59 DeSoto Firesweep 4 door sedan to the Show-Me Mopars car show in Columbia, MO. I was entered in the antique class from 1914 to 1961 model year of any "stock" MoPar. I wound up with first place with a judged score of 96.1 out of 100. And the best part is my DeSoto beat out a gorgeous 1958 Dodge Coronet D500 2 door HT that is a trailer queen. Gosh, that made my day - winning over an unlicensed non driven trailer queen! Just goes to show that it boils down to what others think of your car that makes the difference. "It's delightful, it's delovely, it's DeSoto" | ||
| soiouz |
Expert Posts: 3490 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: Montreal, Canada | Put the original dealership tag back at its original location. (image.jpg) (image.jpg) (image.jpg) Attachments ---------------- image.jpg (120KB - 740 downloads) image.jpg (130KB - 749 downloads) image.jpg (172KB - 752 downloads) | ||
| wizard |
Board Moderator & Exner Expert 10K+ Posts: 13211 ![]() ![]() ![]() ![]() ![]() ![]() Location: Southern Sweden - Sturkö island | Another piece of the puzzle David - did you find it just now or was it in/on the car? | ||
| soiouz |
Expert Posts: 3490 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: Montreal, Canada | wizard - 2015-06-24 4:48 PM Another piece of the puzzle David - did you find it just now or was it in/on the car? It came with the car, but had not been reinstalled by the former owner when he painted the car. I like the original dealer tags so for me it had to go back where it belonged. (image.jpg) Attachments ---------------- image.jpg (92KB - 756 downloads) | ||
| macedon |
Elite Veteran Posts: 964 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: San Antonio, TX | Quick wipe down of the dash to see what I have. (quick.JPG) Attachments ---------------- quick.JPG (97KB - 741 downloads) | ||
| wizard |
Board Moderator & Exner Expert 10K+ Posts: 13211 ![]() ![]() ![]() ![]() ![]() ![]() Location: Southern Sweden - Sturkö island | soiouz - 2015-06-25 2:19 AM wizard - 2015-06-24 4:48 PM Another piece of the puzzle David - did you find it just now or was it in/on the car? It came with the car, but had not been reinstalled by the former owner when he painted the car. I like the original dealer tags so for me it had to go back where it belonged. I would have mounted it to David, they're so cool and period correct - your car looks really good and there's always some improvement going on. | ||
| soiouz |
Expert Posts: 3490 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: Montreal, Canada | wizard - 2015-06-25 1:58 AM soiouz - 2015-06-25 2:19 AM wizard - 2015-06-24 4:48 PM Another piece of the puzzle David - did you find it just now or was it in/on the car? It came with the car, but had not been reinstalled by the former owner when he painted the car. I like the original dealer tags so for me it had to go back where it belonged. I would have mounted it to David, they're so cool and period correct - your car looks really good and there's always some improvement going on. Thanks a lot! Little by little, I am bringing this back to how it was when it was sold in 58. I actually did a lot more than the dealer tag on it yesterday, but that's the only part that really shows. In a month or two, there will be a whole lot more to report, as the car will be getting ready for a repaint in its original Willow Green and Sunshine Yellow livery! | ||
| ronbo97 |
Expert Posts: 4248 ![]() ![]() ![]() ![]() ![]() Location: Connecticut | David - It's great that you have a vintage photo of the dealership that sold your car. That's something I'd like to find for my 59 Dodge. Interesting that on your Dodge, there is no long, thin aluminum moulding between the left and right taillights, like you would find on the 58 Plymouth Belvedere. Ron | ||
| soiouz |
Expert Posts: 3490 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: Montreal, Canada | ronbo97 - 2015-06-25 9:56 AM David - It's great that you have a vintage photo of the dealership that sold your car. That's something I'd like to find for my 59 Dodge. Interesting that on your Dodge, there is no long, thin aluminum moulding between the left and right taillights, like you would find on the 58 Plymouth Belvedere. Ron The car is a Plodge equivalent to the Plymouth Savoy, so it has the same moulding confirguration as a Savoy in every respect, including that lack of trim under the trunk. I got the photo of the dealership by writing a request to some local archives in the town where the garage stood. The nice lady there had no difficulty finding a picture of it. | ||
| 1961plymouthfury |
Expert Posts: 2682 ![]() ![]() ![]() ![]() ![]() ![]() Location: Rogersville, Alabama | Nothing I am done with the block and air sanding , I even cleaned and polished the trimming. I learned my power brake booster needs to be rebuilt. I also need to remove the front bumper and passenger tail light and the 1 head light that is still there. | ||
| macedon |
Elite Veteran Posts: 964 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: San Antonio, TX | Still finding out what I have with this 57 DeSoto Sedan. Pulled the carpet out. Floors are solid... nothing too scary. I'll have some work for sure, but I don't see any metal needing replacement. So far so good. Trunk mat cleaned up nice. (driverfloor.JPG) (passfloor.JPG) (rear1.JPG) (rear2.JPG) (matclean.JPG) Attachments ---------------- driverfloor.JPG (198KB - 750 downloads) passfloor.JPG (163KB - 730 downloads) rear1.JPG (52KB - 724 downloads) rear2.JPG (67KB - 737 downloads) matclean.JPG (262KB - 750 downloads) | ||
| d500neil |
Exner Expert 19,174 posts. Neil passed away 18 Sep 2015. You will be missed, Neil! Posts: 19146 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: bishop, ca | And, you have a most excellent condition accelerator and brake pedal, too! Their condition bodes well for the non-abusive prior usage/operation of your ride. | ||
| big m |
Expert 5K+ Posts: 7831 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: Williams California | That trunk mat is in excellent shape!!!!! | ||
| KcImperial |
Expert Posts: 2501 ![]() ![]() Location: Kansas City, KS | Finally got brake lights working today. Had been struggling with them on and off for months. I changed the headlight switch, installed new bulbs, and today I got the brake light switch converted to a mechanical type mounted to the pedal. Tomorrow, I get to figure out what I messed up in the process to make the instrument lights stop working. | ||
| ttotired |
Expert 5K+ Posts: 8456 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: Perth Australia | Got the dodge licensed, now its road legal | ||
| JT Vincent |
Expert Posts: 1493 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: Jamaica Plain, MA | Dave, in keeping with Neil's comment, I'd also note that your car's former owner apparently used two feet to drive-- one on brake, one on accelerator. An inadvisable practice, but it didn't seem to talk a toll on your ride. | ||
| Powerflite |
Exner Expert 10K+ Posts: 10568 ![]() ![]() ![]() ![]() ![]() Location: So. Cal | I have always driven like that and I'm sure it comes from learning to drive with a clutch & manual trans. But I have tried it both ways on an automatic and the 2 feet method seems quite a bit safer because you have less reaction time to brake. Your foot is already there, waiting to be used instead of having to come up off the accel pedal, stop, and go down to the brake. Much slower reaction time. In an emergency, your other foot can certainly come off the accelerator and help push on the brakes too, but the car doesn't have to wait for it to get there to begin stopping so I don't really see a downside. | ||
| wizard |
Board Moderator & Exner Expert 10K+ Posts: 13211 ![]() ![]() ![]() ![]() ![]() ![]() Location: Southern Sweden - Sturkö island | I always use both feet to drive an automatic - it's the natural thing to do and once you've learn it you won't have any problem switching between manual and automatic cars. | ||
