What did you do to your FL car today?
Jump to page : < ... 51 52 53 54 55 56 57 58 59 60 61 62 ... >
Now viewing page 57 [50 messages per page]
Matthew Keij
Posted 2015-01-17 7:42 PM (#467902 - in reply to #467589)
Subject: RE: What did you do to your FL car today?
100100100100252525
Finally saw it and made a crate for it to ship!
Pic is too big can't post it from my phone
Edited by Matthew Keij 2015-01-17 7:43 PM
christine-lover
Posted 2015-01-17 7:51 PM (#467903 - in reply to #165059)
Subject: Re: What did you do to your FL car today?
20001000
Here's Matthew's new ride! Sweet!!!
(image.jpg)
Attachments image.jpg (227KB - 743 downloads)
jimntempe
Posted 2015-01-17 8:00 PM (#467904 - in reply to #165059)
2000100100100
Mathew's a big boy!
Matthew Keij
Posted 2015-01-17 8:26 PM (#467906 - in reply to #165059)
100100100100252525
Yes I am! Couldn't fit in.
Glad I've got the big version that I will fit in perfectly when it's fixed
d500neil
Posted 2015-02-11 5:10 PM (#469875 - in reply to #165059)
5000500050002000200010025
Well, today was a red-letter day for Horrie.
Decade(s) ago, read this mini-fix-it article, and realized that the annoying wind-leak-noise, due to the vent window's
loose-closure against the vent window frame's rubber surround gasket, was due to usage-warpage of the (-pot metal) lock-lever's pivot post.
The air-gap/wind noise is discernible by the front seat passenger (mostly) , when all the windows are 'up', so, the
annoyance is seasonally-related.
Well, tis the season for windows-up cruising, so decided to follow the directions, and (finally) FIX that wind leak
problem.
Rather than drill-out the lever-lock, and-install a steel pin into it (as described in the article) , decided, simply, to install a
small self-tapping screw into the lever-lock-body (which would provide for simple/easy fine-tuning of the extent of the
vent window's closure pressure.
And VOILA!
After 30+ years of custodianship, H.'s passenger side vent window no longer leaks air!
(And, if you look closely, you'll see my earlier effort to shim-shut the vent window (as per the fix-it article) , but, that extra layer [of Gary Goers'] vent window rubber-seal did not eliminate the wind-leak at the vent window.
And, BEST of all....this fix can be done with NO other labor operations being required onto the car body!
Edited by d500neil 2015-02-11 5:35 PM
(PICT3301.JPG)
(PICT3302.JPG)
(PICT3303.JPG)
(PICT3304.JPG)
(PICT3305.JPG)
(PICT3306.JPG)
(PICT3307.JPG)
(PICT3308.JPG)
(PICT3309.JPG)
(PICT3311.JPG)
(PICT3312.JPG)
Attachments PICT3301.JPG (76KB - 718 downloads)
Attachments PICT3302.JPG (102KB - 744 downloads)
Attachments PICT3303.JPG (108KB - 742 downloads)
Attachments PICT3304.JPG (73KB - 719 downloads)
Attachments PICT3305.JPG (72KB - 719 downloads)
Attachments PICT3306.JPG (91KB - 744 downloads)
Attachments PICT3307.JPG (69KB - 737 downloads)
Attachments PICT3308.JPG (68KB - 730 downloads)
Attachments PICT3309.JPG (102KB - 732 downloads)
Attachments PICT3311.JPG (85KB - 746 downloads)
Attachments PICT3312.JPG (70KB - 746 downloads)
JT Vincent
Posted 2015-02-11 5:26 PM (#469878 - in reply to #165059)
1000100100100100252525
Nice one!
d500neil
Posted 2015-02-17 2:02 AM (#470252 - in reply to #165059)
Went on a nice 60 mile mid-Winter cruise, up to/from Tom's Place, CA Resort/Restaurant, at 7K' elev.
No snow plows anywhere in sight.
Edited by d500neil 2015-02-17 12:02 PM
(PICT3348.JPG)
(PICT3351.JPG)
(PICT3352.JPG)
(PICT3353.JPG)
(PICT3356.JPG)
Attachments PICT3348.JPG (112KB - 747 downloads)
Attachments PICT3351.JPG (110KB - 715 downloads)
Attachments PICT3352.JPG (97KB - 722 downloads)
Attachments PICT3353.JPG (93KB - 712 downloads)
Attachments PICT3356.JPG (104KB - 713 downloads)
FwdLk56
Posted 2015-02-17 5:31 AM (#470259 - in reply to #165059)
20002525
i "bragged" (ie, went through the 'laundry list' of why i prefer Mopar and Studebaker over GM) about the Forward Look Era to the owner of a '66 'vette yesterday, does that count toward "what did you do to your FL car today?"...
had to be careful though since i'm working a short-term contract with GM at the moment...
FIN ME
Posted 2015-02-21 6:01 PM (#470609 - in reply to #165059)
2000500100100252525
Who is that handsome dude in the hat leaning on that mega-nice Dodge!?
Both looooooooookin' good!
Hope you had a nice drive; looks like fun!
jboymechanic
Posted 2015-03-07 2:32 PM (#471910 - in reply to #470609)
2000100100
Started assembly of the front clip, hope to have the rest done around Easter.
(Partial front clip 1.jpg)
(partial front clip 2.jpg)
(partial front clip 3.jpg)
Attachments Partial front clip 1.jpg (359KB - 760 downloads)
Attachments partial front clip 2.jpg (403KB - 739 downloads)
Attachments partial front clip 3.jpg (382KB - 741 downloads)
60crossram
Posted 2015-03-10 8:54 PM (#472180 - in reply to #165059)
50010010010025
I got the Newport Wagon out to go into the engine so I can see why it started running a bit rough and smoking a bit after a hard run on her last summer, plus I can reseal it and I may go through the trans at the same time. It still works good after 54 years and 35, 000 miles of pampered driving. Sure is a fun one to put around.
(20150310_184114.jpg)
(20150310_184137.jpg)
(20150310_184215.jpg)
(20150310_184224.jpg)
(20150310_184246.jpg)
(20150310_184300.jpg)
(20150310_184345.jpg)
Attachments 20150310_184114.jpg (114KB - 733 downloads)
Attachments 20150310_184137.jpg (150KB - 712 downloads)
Attachments 20150310_184215.jpg (188KB - 741 downloads)
Attachments 20150310_184224.jpg (149KB - 728 downloads)
Attachments 20150310_184246.jpg (150KB - 710 downloads)
Attachments 20150310_184300.jpg (156KB - 688 downloads)
Attachments 20150310_184345.jpg (165KB - 751 downloads)
60crossram
Posted 2015-03-12 12:41 AM (#472278 - in reply to #165059)
50010010010025
I pulled out the Trans and the engine tonight. Can't wait to pull them apart and check them out. Can you believe the exhaust system is still original and good. Another thing about this car that is unusual, when I had the dash speaker out it looked good so I put it back in, and it sounds just fine. Also the steering wheel has no cracks, but then again it sat in the chicken coop from 1975 til I got it, 35 years later. DeSoto (Chrysler) lives !!!
(20150311_201604.jpg)
(20150311_132110.jpg)
Attachments 20150311_201604.jpg (114KB - 706 downloads)
Attachments 20150311_132110.jpg (85KB - 695 downloads)
60crossram
Posted 2015-03-12 12:46 AM (#472279 - in reply to #165059)
50010010010025
Last picture is off one of my customers house. Dang !!!
60crossram
Posted 2015-03-12 3:11 PM (#472322 - in reply to #165059)
50010010010025
Just popped the engine out. I will tear it apart tonight. Mopar or no car !
(20150312_130714.jpg)
Attachments 20150312_130714.jpg (137KB - 702 downloads)
60crossram
Posted 2015-03-12 10:11 PM (#472347 - in reply to #165059)
50010010010025
Broken rocker. And the engine is not too happy inside. A good example of very low maintenance. I guess I'll be taking another route, Not sure what yet. You think your going to do a quick fix/repair, rarely happens that way. Chrysler lives !!!
(20150312_190143.jpg)
Attachments 20150312_190143.jpg (107KB - 684 downloads)
d500neil
Posted 2015-03-13 3:55 AM (#472361 - in reply to #165059)
At least 7 panels of that Unobtanium headliner hardboard, plus the sun visors....and yet, nobody, to date,
has realized the profit to be had, by the re-popping of the FWDLK-era headliner materials!!!!!
flattie45
Posted 2015-03-13 6:27 PM (#472400 - in reply to #165059)
100252525
60crossram, that is one heck of a lovely wagon you've got there.
Lucky you!
60crossram
Posted 2015-03-13 8:53 PM (#472414 - in reply to #165059)
50010010010025
I'm thinking about dropping a 440 in it to really get this wagon a scootin. What do you all think ?
Posted 2015-03-14 2:35 AM (#472444 - in reply to #165059)
Jon, the Imperial engine bay is looking good. I like what you did with the mounting of the alt and AC compressor, similar to what I did on my own Imperial. I am looking forward to seeing your car completed, I have been watching your progress for a long time, and like your style.
60 crossram, in my opinion you should stick with your first plan and freshen the original motor and box. A rocker shaft should be easy enough to find. Have you surveyed the rest of the engine yet? My own 413/TF is a great power-plant and with some work yours will be too. Might not take too much money/time to get it back to top form. Plus, you can say it is the original if someone asks. Bloody nice wagon by the way.
Steve.
Edited by 60 Imp 2015-03-14 2:37 AM
60crossram
Posted 2015-03-14 10:31 PM (#472504 - in reply to #165059)
50010010010025
Yes, the engine is shot. I have never seen a ring ridge in the cylinders this bad before. There is even a ridge on the cam bearings. And the timing chain was a loosey-goosey. I'm just not prepared to do a complete rebuild on this 361 right now. The car is obviously a low mileage car (original exhaust system, dash speaker still soft and works great, brake pedal has very little wear, drivers door hinge has zero play up and down) so whoever owned it did almost no maintenance on the engine I'm guessing. It came from Colorado and was last licensed in 1977. It would be nice to know the history of her. I'm going to tear down a 383 from a 60 Adventurer that I have been storing for 10+ years. May go this route if it's fairly clean inside or the 69 webbed block 440 pavement pounder. Chrysler lives !!!
Beltran
Posted 2015-03-14 11:20 PM (#472512 - in reply to #165059)
100050010010025
That vehicle is really valuable original. It will only get more valuable if you keep it that way. I would say you spend some bucks on rebuilding that engine and tune it so it runs better than new but you can still call it the original engine. What ever you do, don't get rid of it.
jimntempe
Posted 2015-03-15 7:59 PM (#472563 - in reply to #165059)
2000100100100
I took my PS pump to Benchworks for rebuild. Saw this on their shop wall.
(dodge brothers clock benchworks.jpg)
Attachments dodge brothers clock benchworks.jpg (77KB - 740 downloads)
soiouz
Posted 2015-03-15 8:08 PM (#472565 - in reply to #165059)
20001000100100100100252525
What did I do today? Well I bought another FL car!
Funny how things happen sometimes: I now own two 1958 Dodge Regent two door hardtop!
60crossram
Posted 2015-03-15 10:36 PM (#472570 - in reply to #165059)
50010010010025
Awesome David, what's the condition? Let's see some pictures. Is the Regent a Canadian model only ? I can't wait to start working on my 57 Plymouth 2 door plaza sedan. DeSoto, Chrysler, Plymouth lives !!!
soiouz
Posted 2015-03-16 9:23 AM (#472580 - in reply to #472570)
60crossram - 2015-03-15 10:36 PM
Yes, Regents are canadian equivalent to a Plymouth Savoy.
I don't have good pictures, but I'll take some when I pick it up in a couple of weeks. It is currently half disassembled so it looks like crap, but it is a solid, complete and actually running car!
(11018636_10152737330776938_6577548481275184449_o.jpg)
Attachments 11018636_10152737330776938_6577548481275184449_o.jpg (202KB - 704 downloads)
Posted 2015-03-16 2:50 PM (#472602 - in reply to #472347)
60crossram - 2015-03-12 10:11 PM
is that a broken rocker SHAFT?! never seen anything like that before. how can this happen?
60crossram
Posted 2015-03-16 8:08 PM (#472623 - in reply to #165059)
50010010010025
1960fury, The end rocker shaft bolt broke then it put stress on the shaft and broke it. The push rods were in the valley area. Luckily they didn't make it down to the crank/rods. 3 of the lifters came apart also and all their pieces were in the valley area and oil pan. Not sure if the valves are sticky which caused the bolt to break. I'm just going to set that engine aside for now and go another route because it needs everything. But I will keep it with the car for sure.
David, that looks like a solid Regent. And it's a Hardtop too. Cool !!!
soiouz
Posted 2015-03-16 8:13 PM (#472624 - in reply to #472623)
60crossram - 2015-03-16 8:08 PM
Yes It is a two door hardtop! I know of only five or six still in existence and I own two of them. Crazy!
60crossram
Posted 2015-03-26 9:42 PM (#473532 - in reply to #165059)
50010010010025
We'll, I hope people don't get too upset, but the 61 Wagon is getting the 69 440 and 62 trans. I pulled the great shape original exhaust and hangers to save. And the original engine & trans will be resting in my shed for safe keeping. The 440 is at the machine shop getting a 30 over bore and a head job. It will have a Mopar performance purple shaft 440-6 grind cam and new everything. I will not damage anything on the car that can't be undone and the engine will be painted up to look original. I will even modify a period air cleaner. I just wanted this wagon to have some nuts. I'm building the 62 trans now. So maybe another 2-3 weeks she'll be driving again. Hoping to drive her to Mopars at the Strip next year. Thought about it long and hard and this is the route I chose. She'll be cool and will sound and run like she always wanted to. Chrysler lives !!!
d500neil
Posted 2015-03-27 6:39 PM (#473605 - in reply to #165059)
After many years of service, replaced the aftermarket crankshaft idler-pulley ( 3 1/2" diameter; Gates:7803-2083;
NAPA: 38038), which has a sealed bearing in it.
It had been making a sort of 'chirping' sound, which was the only extraneous noise
from under the hood.
Direct no-brainer/bolt-on item, but it does require the use of one 1/2" inside-diameter steel
washer and a 11/16" box-head wrench.
Edited by d500neil 2015-03-27 8:06 PM
(PICT3848.JPG)
(PICT3849.JPG)
(PICT3850.JPG)
(PICT3851.JPG)
(PICT3852.JPG)
(PICT3853.JPG)
(PICT3854.JPG)
(PICT3869.JPG)
(PICT3870.JPG)
Attachments PICT3848.JPG (81KB - 690 downloads)
Attachments PICT3849.JPG (106KB - 671 downloads)
Attachments PICT3850.JPG (112KB - 658 downloads)
Attachments PICT3851.JPG (117KB - 666 downloads)
Attachments PICT3852.JPG (112KB - 734 downloads)
Attachments PICT3853.JPG (73KB - 691 downloads)
Attachments PICT3854.JPG (79KB - 702 downloads)
Attachments PICT3869.JPG (106KB - 684 downloads)
Attachments PICT3870.JPG (108KB - 720 downloads)
big m
Posted 2015-03-27 8:03 PM (#473616 - in reply to #165059)
5000200050010010010025
Nice warm day today, drove the '57 up into the Sierras to look at a collection of NOS Mopar parts and some late '40's, early '50's cars that were for sale, didn't make a deal on anything, but the car seemed to enjoy the trip.
---John
60crossram
Posted 2015-03-27 8:55 PM (#473625 - in reply to #165059)
50010010010025
d500neil. You can just press out the bearing on those pulleys and just buy a sealed bearing for a few bucks, then you can keep the original pulley. Nice looking engine you have there.
I am building the 62 aluminum torqueflite this weekend. It's all cleaned, buffed and servo bores polished. Getting a complete reseal, clutches and both bands. After 50 years the material starts coming off. This is a one year trans if you guys don't know. Still has the push button and the rear drum e-brake. And it allows you to bolt it to a later big block. (Different crank flange). I'm kind of surprised no one has ever made a conversion torque converter. That's all you would need to bolt a modern engine to the old cast iron torqueflite.
I don't know if you guys are aware of these old transmissions ability to start you engine by coast starting them. They have a front pump and a rear pump. If you coast it down a hill or have someone pull you, your engine will crank over at about 20-25 mph. Try it sometime it's way cool.
(20150327_165717.jpg)
(20150327_183309.jpg)
Attachments 20150327_165717.jpg (130KB - 711 downloads)
Attachments 20150327_183309.jpg (166KB - 708 downloads)
fenix
Posted 2015-03-27 9:42 PM (#473627 - in reply to #165059)
2000100
Started disassembling the RV-2 AC compressor, got as fsr as You see and then decided to remove the EPR valve and check it, walla, no screen, no valve, I went down to the shed to check another compressor, yep, it was missing also.
By the way, the Poly 318 P-600 3X2 intake will work with the later factory air, the compressor, idler, brackets, pullys,alt, all came from a 66 Poly 318 Fury. There was some minor T-stat clearance issue's, but turning around a through bolt solved it.
Edited by fenix 2015-03-27 9:46 PM
(1-DSCF1646.JPG)
Attachments 1-DSCF1646.JPG (176KB - 686 downloads)
60crossram
Posted 2015-03-28 11:43 AM (#473666 - in reply to #165059)
50010010010025
Rear pump on the 62 aluminum torqueflite. The cast iron torqueflite has a similar rear pump. I not sure if the 2 speed trans has one. I just think it's way cool that if your battery goes dead, you can pull start your car. Buildings the trans this weekend while and a few other things to get ready for the engine. DeSoto lives.
(20150328_093820.jpg)
Attachments 20150328_093820.jpg (148KB - 717 downloads)
60crossram
Posted 2015-03-28 7:39 PM (#473712 - in reply to #165059)
50010010010025
Got the torqueflite built today other than doing a couple minor tweaks to the valve body. Whoever thought up automatic transmissions was either super smart or he was on acid. So cool how they work. Some of today's new trannys are 5, 6, 7 and 8 speeds, all electronic and solenoid activated. All the seals in this trans were getting hard and a couple of the clutches in the direct drum we're coming apart. The material was just coming off the steels in chunks. After so long they just need refreshing. It's getting both new bands also. Not worth having to go back into it again. Mopar or no car !!! If you don't do it, It don't get done.
(20150328_172112.jpg)
Attachments 20150328_172112.jpg (150KB - 693 downloads)
Chumley
Posted 2015-04-01 8:30 PM (#474121 - in reply to #165059)
Well,
I got it registered and insured, and started driving around!
I put maybe 15 miles on it.
Nothing broke, but it's going to take awhile to get used to that clutch...
Paul
Chumley
Posted 2015-04-02 1:45 PM (#474168 - in reply to #165059)
Changed the engine oil and filter today. I have to say getting the cartridge type oil filter back on was a minor chore, trying to get the bolt lined up and threaded in while reaching around the center link, exhaust pipe, and torsion bar. But I endeavored to persevere, and got it on with only minor cursing.
The FSM calls for SAE 30, but also says that 20W-50 is OK to use, too. I have a half a drum of Cen-Pe-Co 15W-40 oil left over from my farming days, so I used that. I figure it's an old engine, I'll really only be running it in the warmer months, and hey, I got the oil anyways.
Oh, I got my car inspected today, too. The guy didn't know exactly where to put the sticker on the wraparound windshield...
Paul M.
jboymechanic
Posted 2015-04-03 10:04 PM (#474286 - in reply to #165059)
2000100100
Today was Good Friday indeed, a good Friday to roughly hang my front clip. Hope to complete the under hood wiring tomorrow.
(2015-04-03 06.12.19.jpg)
Attachments 2015-04-03 06.12.19.jpg (475KB - 691 downloads)
Chumley
Posted 2015-04-04 6:16 AM (#474301 - in reply to #165059)
I've been driving my '58 Plaza around for a 3-4 days. I've only gotten to changing the oil, with a tune up on my short list. Anyways, visited a friend last night, and the car wouldn't start. Tried this and that. Finally took off the air cleaner, it was getting gas. Took off the distributor cap, and the points weren't sparking! Yes! The old 'scratch-the-points-with-an-old-screwdriver' routine! I can't remember the last time I had to do that! Put it back together and she fired right up. Man, I love it...
Note to self: Please don't drop the little air cleaner clamp into the running fan blade again... That could have been nasty.
Ray
Posted 2015-04-04 10:14 AM (#474314 - in reply to #165059)
Getting ready for an engine update. Picked up a full engine gasket set, carb rebuild set and ignition recurve kit for 383 engine. Also built a small painting booth for engine parts.
I hope this goes as well as planned. We want to be ready for Mopars in the Park next month.
I plan to store the 361 so my son/grandson can put it back to stock in the future if they want to.
FIN ME
Posted 2015-04-04 11:55 AM (#474323 - in reply to #165059)
2000500100100252525
I delivered a lot of goodies that I got from Gary Goers to the shop for installation on my DeSoto. Happy dance!
di_ch_NY56
Posted 2015-04-04 2:32 PM (#474339 - in reply to #473666)
100050025
60crossram - 2015-03-27 5:43 PM Rear pump on the 62 aluminum torqueflite. The cast iron torqueflite has a similar rear pump. I not sure if the 2 speed trans has one. I just think it's way cool that if your battery goes dead, you can pull start your car. Buildings the trans this weekend while and a few other things to get ready for the engine. DeSoto lives.
Yes my Powerflite (2 speed automatic transmission) in my Beast ('56 New Yorker) has a rear pump as well. I assume there was no major change (e.g. drop of the rear pump) in the Powerflite until it was phased out.
Happy Motoring!
Dieter
hemidenis
Posted 2015-04-04 10:21 PM (#474386 - in reply to #165059)
20001000500100100100100
When for a long ride to a lake with the car, running perfect, zero problems. Pictures are not the best, even that scenery was beautiful, but I cant drive and take pictures at the same time, my camera girl kinda is not the best...
Edited by hemidenis 2015-04-04 10:35 PM
(maplake.jpg)
(20150328_123723.jpg)
(20150328_124808.jpg)
(20150328_124928.jpg)
(20150328_130711.jpg)
(20150328_130737.jpg)
(20150328_130817.jpg)
(11134041_10205310069304311_6927345172919802960_n.jpg)
(10407034_10205310070184333_6862552760530734053_n.jpg)
(11136736_10205310069464315_2752983024155471623_n.jpg)
Attachments maplake.jpg (151KB - 692 downloads)
Attachments 20150328_123723.jpg (155KB - 726 downloads)
Attachments 20150328_124808.jpg (250KB - 734 downloads)
Attachments 20150328_124928.jpg (264KB - 717 downloads)
Attachments 20150328_130711.jpg (138KB - 716 downloads)
Attachments 20150328_130737.jpg (170KB - 688 downloads)
Attachments 20150328_130817.jpg (165KB - 719 downloads)
Attachments 11134041_10205310069304311_6927345172919802960_n.jpg (124KB - 719 downloads)
Attachments 10407034_10205310070184333_6862552760530734053_n.jpg (154KB - 699 downloads)
Attachments 11136736_10205310069464315_2752983024155471623_n.jpg (131KB - 721 downloads)
60crossram
Posted 2015-04-05 12:06 AM (#474393 - in reply to #165059)
50010010010025
She did great with the pictures. Looks like a nice cruise in a sweet car. Chrysler lives !!!
d500neil
Posted 2015-04-05 12:55 AM (#474394 - in reply to #474393)
Regalissimo!
Posted 2015-04-05 1:08 AM (#474396 - in reply to #474394)
5000200010010025
Nice drive, Denis - you are back in the US, from South America then!
hemidenis
Posted 2015-04-05 12:49 PM (#474427 - in reply to #165059)
Thanks guys
Yes, was a nice drive, my 75 years old father in -law was with me all the way, great guy but disappointed that in my collection of music DVD videos has nothing with "Johnny" Cash in it. Yes Ian I'm back in the US since last September, glad to the spring is finally here. 12 miles per gallon on the consumption...
Posted 2015-04-05 1:16 PM (#474429 - in reply to #165059)
5000500020001000100100
Great Pictures Denis - the car looks really nice!!!
hemidenis
Posted 2015-04-07 4:09 PM (#474656 - in reply to #165059)
Thanks wiz!
Posted 2015-04-07 8:10 PM (#474688 - in reply to #474656)
beautiful weather in germany and cruised around and because i finally found a way to upload pictures again i'm posting one
(60fury1big.jpg)
Attachments 60fury1big.jpg (147KB - 703 downloads)
