What did you do to your FL car today?
Jump to page : < ... 44 45 46 47 48 49 50 51 52 53 54 55 ... >
Now viewing page 50 [50 messages per page]
FIN ME
Posted 2013-12-09 3:32 PM (#415325 - in reply to #165059)
Subject: Re: What did you do to your FL car today?
2000500100100252525
Congratulations, Dave!
That is one great Dodge.
Glad you and Mrs. Dave had a good time!
DepsilonD
Posted 2013-12-09 3:56 PM (#415329 - in reply to #165059)
500100100252525
Thank Fin Me. I love the "Mrs. Dave" thing, you really did make me laugh out loud.
fenix
Posted 2013-12-09 5:53 PM (#415361 - in reply to #165059)
2000100
I went out and made some aweful faces at my car, later I went back and aplogized when I realized it wasn't the cars fault it ain't on the road. Now that I'm all hyped and raring to go the damm weather screws me. sheeeeeeesh !
Edited by fenix 2013-12-09 5:54 PM
d500neil
Posted 2013-12-13 6:05 PM (#416152 - in reply to #165059)
Subject: RE: What did you do to your FL car today?
5000500050002000200010025
Finally got around to doing something that's needed being done for a couple few years, now.
Had bought a new front fender antenna, but its under-fender mounting plate didn't conform well to
the fender, which allowed the antenna to move around, across the fender, because the lock-nut couldn't
screw down far enough so as to jam the upper chrome base tightly against the fender.
Slow news day, so, got out a 1 /1/4" washer and drilled-out its center (carefully) to 3/4", to slide
over the internal threads of the antenna, so that the lock-nut could exert proper pressure
against the antenna's fender base.
(PICT4291.JPG)
(PICT4292.JPG)
(PICT4294.JPG)
(PICT4295.JPG)
(PICT4297.JPG)
Attachments PICT4291.JPG (47KB - 585 downloads)
Attachments PICT4292.JPG (98KB - 609 downloads)
Attachments PICT4294.JPG (52KB - 552 downloads)
Attachments PICT4295.JPG (49KB - 550 downloads)
Attachments PICT4297.JPG (58KB - 556 downloads)
1961plymouthfury
Posted 2013-12-13 10:03 PM (#416195 - in reply to #165059)
2000500100252525
My Fowardlook went into hibernation today.
FIN ME
Posted 2013-12-14 8:09 AM (#416267 - in reply to #165059)
2000500100100252525
Great solution to that antenna problem, Neil!
jimntempe
Posted 2013-12-16 9:37 PM (#416776 - in reply to #165059)
2000100100100
Put my recast steering wheel back on... sparkly...
(IMG_1050 s.jpg)
Attachments IMG_1050 s.jpg (216KB - 574 downloads)
FIN ME
Posted 2013-12-17 9:20 AM (#416853 - in reply to #165059)
2000500100100252525
Ooooooooh...that's NICE!
lownslow
Posted 2013-12-17 9:33 AM (#416857 - in reply to #165059)
10010010010025
Nice steering wheel!
Posted 2013-12-17 11:01 AM (#416867 - in reply to #165059)
50005000200010001002525
Aaarghhh - totally awesome - my friend will be green of envy. Who did the work and what was the costs (more or less)
henricthornsund
Posted 2013-12-17 1:22 PM (#416899 - in reply to #165059)
50010025
Feels like beeing in a showroom in 1960
Posted 2013-12-17 2:18 PM (#416911 - in reply to #416899)
500050001001001001002525
Those guys sure are expensive, but when you see the final product, the sparkle and shine makes it all worth it. Nice.
jimntempe
Posted 2013-12-17 2:34 PM (#416916 - in reply to #416867)
2000100100100
wizard - 2013-12-17 8:01 AM
Quality restorations http://www.qualityrestorations.com/ did the work. Cost is more or less about halfway between the numbers 1 and 2.
Posted 2013-12-17 2:34 PM (#416917 - in reply to #165059)
200010005001001001002525
Well, today I gave my FL a shiny new TKO 600 5-speed transmission...mated to the 360 LA engine.
(BH Inst.JPG)
(TKO RH.JPG)
(TKO Top Rear.JPG)
Attachments BH Inst.JPG (272KB - 558 downloads)
Attachments TKO RH.JPG (281KB - 589 downloads)
Attachments TKO Top Rear.JPG (225KB - 554 downloads)
Posted 2013-12-17 4:09 PM (#416940 - in reply to #416917)
Is that setup from Keisler? I take it they still don't have the highly advertised SS700 trans ready yet that was supposed to be done 3 years ago? If I had a manual trans setup, I would probably go for that too. 5 on the floor is a lot better than 3 on the tree. This is for your '56 Plymouth right? Which floor shifter location did you use - the B-body or A-body version?
Edited by Powerflite 2013-12-17 4:10 PM
empeg9000
Posted 2013-12-17 4:11 PM (#416941 - in reply to #416917)
57chizler - 2013-12-17 2:34 PM
Nice!
DIF-RNT
Posted 2013-12-17 4:26 PM (#416946 - in reply to #165059)
200010005002525
Cool Beans
Posted 2013-12-18 1:35 PM (#417094 - in reply to #416940)
Powerflite - 2013-12-17 1:09 PM
Is that setup from Keisler? This is for your '56 Plymouth right? Which floor shifter location did you use - the B-body or A-body version?
I pieced the conversion together using parts from numerous sources. I used the middle shifter location because it lined up with the hole in the tunnel from the previous installation.
(AC Evaporator.JPG)
Attachments AC Evaporator.JPG (218KB - 555 downloads)
Posted 2013-12-18 2:30 PM (#417111 - in reply to #417094)
5000500050005000200050025
Tell us about your choice of 5-speed manuals and what else you shopped and why you
went with what you did.
I have a looming same-decision for the DeSoto and feel tech has changed a lot since I
researched this. At the time, a Richmond Gears unit seemed the ultimate choice.
Posted 2013-12-18 3:38 PM (#417123 - in reply to #417111)
Also, where did you get the bellhousing?
Posted 2013-12-19 3:48 PM (#417347 - in reply to #417111)
Comparing the existing in-car measurements of my old setup (NV2500) and the TKO engineering drawings, I placed the shifter location 1/2" further forward in the existing 4" hole in the floor so that was a determining factor. I chose the TKO 600 because the gear ratios best suited my needs and the centerline shifter position was better for me than having to hack up my carpet/floors for a side-shifter model like the Richmond.
The bellhousing is a Hurst #OMW-1414SB and it dialed in .005" TIR. (.0025" off center) right out of the box. I used a Wilwood external pull-type slave cylinder to actuate the factory throwout fork. I considered using a hydraulic clutch release bearing but heard too many stories of them leaking.
Most projects like this don't go smoothly for me but every aspect of this one went so smooth I was waiting for an aw-s**t that never came.
(Slave_02.JPG)
Attachments Slave_02.JPG (213KB - 553 downloads)
Posted 2013-12-19 4:02 PM (#417353 - in reply to #417111)
20001000500100100100100252525
Did a quick mockup to see if the bumper fits as it should. Yep...
(57_test_fit.jpg)
Attachments 57_test_fit.jpg (110KB - 527 downloads)
Posted 2013-12-19 4:29 PM (#417357 - in reply to #417353)
Is this your New Yorker? What are you planning?
di_ch_NY56
Posted 2013-12-19 5:31 PM (#417377 - in reply to #165059)
100050025
I removed the steering pump, opened it and got two new o rings (a big diameter and a small diameter) for the place between both parts of the main body. The diameter of the rope is slightly bigger than the original one.
At the desk in the shop of a o ring producing company nearby I told to the sales guy I'm applying hot synthetic oil. I got both rings for free. But I put some big coins into their coffee cash box.
Then I torqued the screws to 17 lbs ft as addressed in the service bulletin 95.
Tomorrow I want to install the modified steering pump again. If it's still leaking I'm going to replace the o rings at the output and the input flange. The shaft seal looks like new and doesn't leak.
Happy Motoring!
Dieter
Posted 2013-12-19 5:42 PM (#417379 - in reply to #417357)
Powerflite - 2013-12-19 3:29 PM
Yes it is. Here's where it's headed.
Posted 2013-12-19 5:52 PM (#417381 - in reply to #417353)
57burb - 2013-12-20 1:02 PM
Interesting. I knew it should bolt up without a hitch, but don't think I have ever tried it.
Looks funny. The 57 Chrysler and 57-58 DeSoto rank in the top 3 spots of favorite Forward Look
cars, so I keep them mentally "separated", even if I know they are a direct swap. I guess I just
don't "see" them intermixing.
The more I look at those directional/parking lights, the more I want to pit them in my 58, whose
inexplicable little round floating versions are just plain pointless to the overall design.
Posted 2013-12-19 5:55 PM (#417382 - in reply to #417347)
57chizler - 2013-12-20 12:48 PM
Doesn't TKO offer choices in your gear ratio selection ?
The TKO is a toploader ? Hmmm .... I guess I wasn't paying that close of attention to your photo above !
Posted 2013-12-19 6:58 PM (#417398 - in reply to #417381)
Doctor DeSoto - 2013-12-19 4:52 PM
Don't, that would "look funny."
I'm putting a Tremec TR-4250 in the Chrysler. It was a short-lived variant of the TR-3500 that came about before the TKO series.
Brent, you're going to put a stick in your convertible??
Posted 2013-12-19 8:27 PM (#417415 - in reply to #417398)
That is the plan. Use a modern, side-loader 5-speed with the 1960 floor shifter
above the floor for "period" appearance.
The trans will be chosen based on whatever meets the performance needs/demands
of the other build specs .... basically laid out:
383 M-block with 906 heads, 8.5:1 compression, a special cam whose numbers I cannot
remember off the top of my head, windage tray, and whatever "ease of operation" details
I can add to squeeze more miles and less drag out of it.
Rear end will be 2.76 for max fuel economy, so the remaining numbers to be dialed in are
the rpm power curves to give good lift-off in lower gears, climbing out into some long legs
at the top for highway driving. I will F/I this car in the process as well.
The basic idea being to make a strong runner with good fuel economy that runs on pump
gas, and to do it in a way that still looks like it might be 1960 without close examination. I
want to drive the wheels off this thing !
Posted 2013-12-20 10:36 AM (#417529 - in reply to #417415)
Fuel economy? Seems like a strange goal with a 2-ton, big block '50s convertible!
IMO I would take that compression ratio up about a point to gain back some mechanical efficiency.
Modern gas is actually better than ever at controlling detonation, but the ethanol content
is still a problem for our old fuel systems regardless of the engine being fed.
Funny how some things we're doing are paralleling each other.
I have a chrome early '60s Hurst floor shifter with a plain white shift knob that I'll be using.
My pedal assembly is from a '58 V8 Suburban. And I have a Hilborn mechanical EFI that will
eventually make its way to the 392. The goal isn't fuel economy though, this one is a bit of a hot rod.
Which I'm sure you'll agree is a funny goal for a 2-ton, big block '50s coupe, heh.
Speaking of EFI, have you ever decided what to do about those Fuel Injection badges?
Every time they're mentioned, there's a bunch of dust stirred up about
getting a batch made, but nothing ever seems to come of it.
Edited by 57burb 2013-12-20 10:38 AM
Posted 2013-12-20 10:51 AM (#417532 - in reply to #417529)
Well, since it moves along pretty good as built, I am only trying to lean it out, performance-wise
for road tripping. There is a lot of "slop" in the power-to-wheels efficiency of these that can be
winnowed out. The 8.5:1 compression ratio was suggested per my builder friends. That was 10
years ago. Perhaps tech will change before I actually do it. That is why I am asking about the
latest and greatest 5-speed opinions ..... maybe something better has come along since I looked
into it ???
The F/I badges will be repopped when the time comes. Again, by the time I need them, someone
may beat me to it. If I poured my energies into it now, they'd just sit in a box with the Adventurer
Powered tags and all my other junk, you know ? As it sits, I need a little warmed weather and to
get on my body panel fab and welding.
What I really need is a stable job, so I can start spending money on finishing the shop. But as it is,
I am holding my $$ close to the vest until something comes along.
Posted 2013-12-20 2:09 PM (#417561 - in reply to #417382)
Doctor DeSoto - 2013-12-19 2:55 PM
Each of the Tremec TKO transmissions has a limited range of ratios to select from, the TKO 500 would have been cheaper and would handle the power I'm making but it has a "granny" 3.27 1st gear and a .68 5th gear. The TKO 600 has a 2.87 1st gear and a .64 5th gear.
Here's a pic of the TKO with the shifter in the middle location.
(mid_shift_kit_02.jpg)
Attachments mid_shift_kit_02.jpg (59KB - 572 downloads)
Posted 2013-12-20 4:09 PM (#417575 - in reply to #417561)
The toploader is certainly a better way to go, in terms of cabin comfort and use.
The old sideloader T-85 DeSoto was not too intrusive, but the A-833 in my Coronet really sticks
into the "OPS" area and is a workout to operate. I find I have to stop every 100 miles or so and
walk around, as the shifter causes me to hold my right knee at an odd side angle that starts to get
painful and spasm.
I only want to use a sideloader as a matter of "period" correct appearance, o/w I'd jump on a
toploader. /
1961plymouthfury
Posted 2013-12-20 6:40 PM (#417602 - in reply to #165059)
2000500100252525
Nothing right now my fowardlook is hibernating for the winter and its under a car cover
Edited by 1961plymouthfury 2013-12-20 6:55 PM
jimntempe
Posted 2013-12-20 8:19 PM (#417608 - in reply to #165059)
2000100100100
I replaced the tail/stop light bulbs with bright halogen ones that have twice the wattage. Looks much better, esp in daylight. Tried some supposedly bright LEDs and they were no better than stock bulbs.
FIN ME
Posted 2013-12-20 9:38 PM (#417624 - in reply to #165059)
2000500100100252525
Starting to work on a couple of the more tedious, but necessary jobs: epoxy repair of the headliner bows, and trying to Dremel out what's left of the old donor car's rusty roof from the inside surfaces of my "new" stainless drip rails.
What fun!
jimntempe
Posted 2013-12-22 8:29 PM (#417907 - in reply to #165059)
2000100100100
I had my 20+ year old tires replaced. They still had plenty of tread left and no sidewall cracks but every time I drove on the freeway I was worried they would fly apart. So got some $50 each replacements at Discount. Total cost out the door was $290 with mounting and tax and I'll be getting a $30 gift card in the mail for using my Discount Tire Club/Credit card. Wished I could afford wider whitewalls but just can't justify it. The difference on the freeway amazed me. Even though the old tires really didn't seem "bad", nothing obviously out of balance or anything, the car just feels much better on the freeway. With the old tires it really didn't feel very good to be going over 60ish. WIth the new ones I was up to 70ish without even noticing I was going that fast. Well worth the money.
soiouz
Posted 2013-12-23 7:26 PM (#418082 - in reply to #165059)
20001000100100100100252525
-10 degrees celcius tonight, I cranked her up, just for the fun of it, and took this pic:
(Fumes.jpg)
Attachments Fumes.jpg (94KB - 555 downloads)
58sportsuburban
Posted 2013-12-23 9:16 PM (#418099 - in reply to #165059)
10010010010025
Dropped off the block and heads to the machine shop so he can start on my 526 stroker!
Posted 2013-12-23 11:48 PM (#418106 - in reply to #418082)
5000200010010025
soiouz - 2013-12-23 4:26 PM
Is your garage insulated and heated?
FIN ME
Posted 2013-12-24 1:11 PM (#418181 - in reply to #165059)
2000500100100252525
Soiouz, great photo.
Makes your car look very menacing!
d500neil
Posted 2013-12-24 6:04 PM (#418258 - in reply to #165059)
Checked the air pressures (to check for the bogeyman radial-tire cracking of the wheels)
and went for an Xmas-Eve drive, in honor of those who can't, right now.
(PICT4392.JPG)
(PICT4394.JPG)
(PICT4395.JPG)
(PICT4396.JPG)
Attachments PICT4392.JPG (103KB - 556 downloads)
Attachments PICT4394.JPG (104KB - 538 downloads)
Attachments PICT4395.JPG (104KB - 582 downloads)
Attachments PICT4396.JPG (93KB - 552 downloads)
bel5758
Posted 2013-12-29 10:31 AM (#419058 - in reply to #418258)
500100100
Took Kate for a spin yesterday.
Then knocked some of the years off one of her scripts I got from Big M.
The one in the bottom of the photo is the one I worked on.
Hopefully will get to the other one today.
(Bel script 2.jpg)
Attachments Bel script 2.jpg (68KB - 568 downloads)
miquelonbrad
Posted 2013-12-29 3:18 PM (#419109 - in reply to #418258)
100050010010025
d500neil - 2013-12-24 4:04 PM
No fair!!!!
Weather looks good there. Nice car!
BigBlockMopar
Posted 2013-12-29 4:08 PM (#419121 - in reply to #165059)
20001000500252525
Doc, I would strongly advise against that smogger 8.5:1 CR you're planning.
Fuel-economy comes from engines with good power down low in the rpm range. Low cr-engine are inefficient.
High cr creates more torque and makes a car 'nimble' to drive.
As far as making FI emblems, just wait long enough you can have them 3D printed for a small price.
I've been finetuning the audio system in my '57 Chrysler. Installed new speakers in the package tray.
At first I had created simple speaker boxes which laid on the rearseat. In combination with the subwoofer in the trunk they still worked OK but they were actually ment for use in my daily '73 Dart.
Now with the new speakers in the '57 the sound is very 'full'.
soiouz
Posted 2014-01-11 5:04 PM (#421539 - in reply to #165059)
Finally installed the last piece of trim on the dashboard, to replace the overpolished one (I'm only missing the ash tray part, now.. anyone?). I also replaced the ignition switch ring with a correct 58 one, and installed the clock winder button.
Before and after:
(IMG_1487.JPG)
(After.jpg)
Attachments IMG_1487.JPG (146KB - 477 downloads)
Attachments After.jpg (155KB - 494 downloads)
jimntempe
Posted 2014-01-11 8:25 PM (#421559 - in reply to #165059)
2000100100100
Looks nice. What's the new switch for under the IP pod?
soiouz
Posted 2014-01-11 8:38 PM (#421562 - in reply to #421559)
jimntempe - 2014-01-11 8:25 PM
That switch is the next thing I want to remove.. From what I understood of what Jeff, the former owner told me, it's supposed to act as an "accessory" switch for when this car had a stereo amp in the trunk and because the ignition didn't have an accessory position...? But it does! So, it has no purpose at all anymore.
soiouz
Posted 2014-01-25 12:02 PM (#423949 - in reply to #165059)
Working on my door panels, saving the original vinyl and reinstalling it on new backing panels.
A before and after shot. The rest of the story will be in my album.
I still have to protect the hardboard backing against humidity before I permanently reinstall the vinyl.
(Portes1.jpg)
(Portes3.jpg)
Attachments Portes1.jpg (136KB - 522 downloads)
Attachments Portes3.jpg (129KB - 516 downloads)
jimntempe
Posted 2014-01-25 1:32 PM (#423971 - in reply to #421562)
2000100100100
soiouz - 2014-01-11 5:38 PM
Are you talking about the switch with the red light next to it? I was looking at the one farther up and to the left, looks like it's a turn-me type switch like a speaker fader.
