What did you do to your FL car today?
Jump to page : < ... 36 37 38 39 40 41 42 43 44 45 46 47 ... >
Now viewing page 42 [50 messages per page]
Chrome58
Posted 2012-05-19 4:58 AM (#321862 - in reply to #321768)
Subject: Re: What did you do to your FL car today?
1000100100100
wizard - 2012-05-18 8:59 PM
Looks really nice Vincent, keep up the good work and keep us posted! - Oh by the way, are you sleeping in your car now? - well I get on the nerves of my wife sometimes too :)
Thanks Sven !
I really hope the car will be finished for this fall.
And no I don't sleep in my car
It's just a bean bag I use to work inside the car ...
I must say I have a very cooperative wife on that subject.
She urges me to finish the car so she can ride in it ... And she does help me a lot.
ttotired
Posted 2012-05-19 6:14 AM (#321869 - in reply to #165059)
5000200010001001001001002525
I did this
(dodge front clip 046 small.JPG)
Attachments dodge front clip 046 small.JPG (94KB - 642 downloads)
D500Jim
Posted 2012-05-19 1:55 PM (#321908 - in reply to #165059)
Subject: RE: What did you do to your FL car today?
10001001001002525
Nothing much, but I woke Mr. Greene up again, for this year's Summer.
I had some worries, because we've had a pretty severe winter, with below minus 4, and I was kinda afraid something would not have survived in the remote little garage box I have.
Amazing. No dead battery and it started after the normal several tries!
I took him for a drive to the annual European World of Bluegrass Festival, some 20 miles from here. No problem!
Took the accompanying picture, at an amazing looking bus stop along the way.
Now I'm zippin' on a little Maker's Mark I found in some dark cavern. Neil teached me well!
(20120519_Short_Story.jpg)
Attachments 20120519_Short_Story.jpg (187KB - 658 downloads)
di_ch_NY56
Posted 2012-05-19 3:17 PM (#321920 - in reply to #165059)
100050025
Today I went to my Chrysli again to have a look for the pass side front brake. The picture shows the brake shoes prior I worked at it with sand paper. I spent about half an hour to find the best adjusting after assembling again. Now when I push the brake very hard both sides dives a little bit (at the front end). But the drivers side is more aggressive than the pass side when I apply only slight pressure at the brake pedal. It tends to lock.
Happy Motoring!
Dieter
(IMG_0630resized.jpg)
(IMG_0633resized.jpg)
Attachments IMG_0630resized.jpg (126KB - 645 downloads)
Attachments IMG_0633resized.jpg (113KB - 636 downloads)
Posted 2012-05-19 7:36 PM (#321942 - in reply to #321782)
5000200010010025
I finished the inside of my trunk today. I removed all the panels, the floor carpet, spare tire and everything inside. The rail supports below the weatherstrip rail had not been painted body color when the car was painted. In fact they had been painted black over top of sprayed on tar type undercoat that covered a lot of the area and it was not pretty. I ended up scraping off the tar with a scraper and then a razor blade. then sanded, cleaned, primed and painted the supports, and also the area where the trunk latch is mounted. The floor, wheel housings and inside of the quarter panels are painted in tremclad black but those areas are all covered with carpet and carpeted panels. This completes the trunk job, though I still want to get a carpeted spare tire cover. I think I'll have to get one made up as I can't seem to locate one anywhere.
I'm heading off to a cruise-in shortly!
Edited by imopar380 2012-05-19 7:46 PM
(IMG_1506.JPG)
(IMG_1507.JPG)
(IMG_1508.JPG)
Attachments IMG_1506.JPG (110KB - 622 downloads)
Attachments IMG_1507.JPG (97KB - 629 downloads)
Attachments IMG_1508.JPG (98KB - 633 downloads)
Chrome58
Posted 2012-05-20 12:39 PM (#322028 - in reply to #321942)
1000100100100
I put the dashpad in ...
It still misses the lower fixtures at the molding, but it's already secured by the speaker and its grille.
Not so easy, as the correct position had to be found before putting everything in.
I assembled and disassembled the speaker and its grille 5 times before getting it right.
I also sorted out the mess of wires behind the dashboard.
Everything is tidy now, and the main harness is now on the other side of the firewall.
(P1020107b.jpg)
Attachments P1020107b.jpg (155KB - 608 downloads)
di_ch_NY56
Posted 2012-05-20 3:17 PM (#322054 - in reply to #165059)
100050025
Today I went to an old car meeting with my Chrysli as dirty as it is... At the journey back I noticed very long drop outs of power when I pulled the pedal low to medium during acceleration. When I applied more power the engine ran fine like it does when I only apply very low load.
Happy Motoring!
Dieter
Posted 2012-05-20 3:30 PM (#322061 - in reply to #165059)
5000500020001000100100
@ Dieter - you have dirt or gum residue in your carburator - I remember that you had issues with your fuel filter. Check your manual and do a real good carburator cleaning/check-up.
floyd066
Posted 2012-05-21 12:57 AM (#322140 - in reply to #165059)
10010010025
Worked in the trunk area on the condition of it. I find I do not have to replace the whole pan. Thank God!! The fuel tank support strips on the top side will work with a little cleaning up. The drivers side of the trunk area is swiss cheese while the spare tire hole is rust free. Could someone explain this to me because my car doesn't want to tell me. It has very little to say. I think its because she is completely apart, and she's not happy with this.
di_ch_NY56
Posted 2012-05-21 3:38 PM (#322226 - in reply to #322061)
100050025
wizard - 2012-05-19 9:30 PM
Thank you very much Sven. I'll buy a bottle of brake cleaner (Wuerth). Then I'll disassemble and clean the carburetor again. Last time I did it last fall. Then I used degreaser (Marine Clean) and installed new gaskets (CK36 set). Prior assembling the parts I dried it with compressed air. The result was never close to perfect... I noticed a heavily worn primary shaft, throttle body or both. I could wiggle it very much.
Happy Motoring!
Dieter
d500neil
Posted 2012-05-21 8:00 PM (#322264 - in reply to #165059)
5000500050002000200010025
Dieter, your distributor's vacuum advance may be inoperative.
You can try removing the V.A. and sucking on its orifice, to hear/feel if its internal diaphram is moving.
Also, what IBP part-number does your dissie have?
And, if you continue to have a slight pull-differential in the brakes, you might consider buying new
brake drums--even if they are made in China.
Edited by d500neil 2012-05-21 8:02 PM
Posted 2012-05-22 1:54 AM (#322285 - in reply to #165059)
@ Dieter - Aha, you'll need to get the primary shaft checked and fixed. Hopefully it's the shaft that is damaged. Try to smear some thick grease around the shaft in both ends and test drive the car - the grease will be sucked it and seal up for a short while. That way you understand if it is the leaking shaft that cause your problems.
DeMopar
Posted 2012-05-22 3:12 AM (#322294 - in reply to #165059)
I test drove my '61 Newport today for the first time in the year and a half I've owned it! A LOT of work to get it to this point! I would venture to say that it hasn't been driven in at least 20, maybe 30 years!
di_ch_NY56
Posted 2012-05-22 4:50 PM (#322392 - in reply to #322285)
100050025
wizard - 2012-05-21 7:54 AM
I applied some grease around the shaft (pass side) last week and today. Today I tried to apply some grease at the drivers side as well. There's no difference in the running behavior. I guess the shaft is worn for years now. So I assume it must be something different, e.g. like you addressed earlier on.
Here's a video about the test ride of today...
http://www.youtube.com/watch?v=YOulqpQ1GHs
Happy Motoring!
Dieter
di_ch_NY56
Posted 2012-05-22 4:53 PM (#322393 - in reply to #322264)
100050025
d500neil - 2012-05-21 2:00 AM
Thanks Neil, this evening I'm afraid I forgot to check the dist. I'll do it next time. The brakes are better now, but quite far away from perfect. The pass side front drum is little bit out of round, but withing the specification.
Happy Motoring!
Dieter
di_ch_NY56
Posted 2012-05-24 9:56 AM (#322670 - in reply to #322264)
100050025
Neil, I tried the Mityvac pump at the vacuum hose and removed the dist cap. The vacuum advance is working from one mechanical end to the other and back. Nowhere is an air sucking noise. It seems the diaphragm is okay. At the distributor I only could read the Chrysler parts number (the upper line) as long as it's mounted. According the number 1642 392 it's a IBK 4301A (double breaker). The Service Manual adddresses the same parts number and IBK- number.
BTW at that time I noticed that not all high voltage wires were hooked perfectly or shaked out of the sockets.
Kind regards
Dieter
JT Vincent
Posted 2012-05-24 3:42 PM (#322713 - in reply to #165059)
1000100100100100252525
I started putting things back together instead of tearing them apart. Right side floor and under braces all stitched in. Now, on to the other half.
(right floor.JPG)
Attachments right floor.JPG (242KB - 601 downloads)
Knighty
Posted 2012-05-27 6:30 AM (#323081 - in reply to #165425)
Fitted a 284/484 camshaft also on Friday night, Ran the cam in Saturday then
Fitted the Heater core and fan motor today ( sunday ) and ran the water pipes.
Also fitted the gas pedal and linkages. first time in ages I was able to press the gas pedal and hear somthing.
Car is going to painter next week so have to finish off a few more things in the engine bay
then its good to drive onto the trailer.
Edited by Knighty 2012-05-27 6:48 AM
(plym1.jpg)
(plym2.jpg)
(plym3.jpg)
(plym4.jpg)
Attachments plym1.jpg (171KB - 681 downloads)
Attachments plym2.jpg (161KB - 623 downloads)
Attachments plym3.jpg (169KB - 728 downloads)
Attachments plym4.jpg (150KB - 638 downloads)
Windsor59
Posted 2012-05-28 12:05 PM (#323236 - in reply to #318917)
2000500100
57plymouth - 2012-04-29 3:54 PM
Windsor59 - 2012-04-25 8:52 AM
Have developed my 59 AFB carburetors that I bought the Big M in January (Turn of the self from an Imperial 59) Will blasted (glass or nut shells??), and all the rods and screws to electric galvanized. Have a good carter carburetor at Windsorn but not the right model.
If any know how I blasted the carburetors with glass or nut shells?
I wouldn't use glass bead. I usually soak them in carb cleaner. If you want to blast the surface, I would use soda or walnut shells, but nothing more coarse than that.
Thanks for the tip.
Has sandblasted now, and submitted all his pieces on the surface treatment of gold and silver. What more can you do to get the final gloss on the carburetor, it is a bit "black" marks still. Something polish?
(DSC_0076.jpg)
Attachments DSC_0076.jpg (63KB - 610 downloads)
Posted 2012-05-28 12:42 PM (#323242 - in reply to #165059)
Hopefully, you mean that its blasted with glassbeads and not sandblasted - glassbeads will not do so big damage as the sand.
Since you didn't like the ideas above with soda or walnut shells, there's another method which I have used on other parts. Take a bamboo barbeque stick of 3mm diameter (grillpinne) and wrap number 0 or 00 steel wool around the stick - put it in a Dremel machine and clean away everything darkish with that. WARNING, the sttel wool will break up in many tiny pieces - the parts must be extremely well cleand and the carburator washed out several times with gasoline. It looks like someone also sandblasted the primary and secondary shafts - they will now eat your bushings very fast.
Further more, since the throttle valves have been removed (hopefully marked so you can get them back in position) the throttle valve clearance/centering must be performed according to the "book" - otherwise the carburator will not perform correctly.
Windsor59
Posted 2012-05-28 1:27 PM (#323246 - in reply to #323242)
2000500100
Hi Sven!
Yes glassblastet (not with sand).
And that bee good with grillpinnar, very good tip.
Yes I must be carfuly when I put it back, or if it go hell I mail the questing here.
1958 Plymouth Infina
Posted 2012-05-28 3:02 PM (#323262 - in reply to #323246)
I put the dash in back in my fury today!
d500neil
Posted 2012-05-28 7:33 PM (#323285 - in reply to #323262)
Dieter, the IBK 4301A (double-breaker) dissie was the OEM guy for the 1956 single-4 D500's and was used on the 'early'
1957 single-4 D500's.
Probably due to the questionable quality gas in the 50's, Chrysler did not specify that high performance mechanical-advancements
be created within the sub-contracted Autolite distributors.
Altho that 4301A has dual points breaker plate in it, and therefore, is suitable for the installation pf Pertronix's "Ignitor 1383" unit,
the OEM performance specifications on that dissie are not good: 2 Initial Advancement (recommended, on engine) + 19 Mechanical
Advancement (in the dissie) = 21 Total M.A. (lousy) + 23 vacuum Advance (check yours for a "11.5" stamping on its lever-arm) =
44 degrees total advancement at (only-) 3000 RPM.
A 56 D500-friend found and installed a "16" V.A. , so that he could dial-in 10 I.A. + 19 M.A. = 29 (not great T.M.A.) + 16 V.A. = 45
Total Advancement.
He also replaced the 4301A's (VERY-heavy-weight) OEM 'light' spring with another (4003 G ) dissie's (very-) 'light' spring, and trans-
ferred the 4301A's (not-light-weight) 'light' spring over, to replace its 'heavy' secondary spring (altho using another 'light' spring
there would probably be preferable).
So, you can certainly "use" the 4301A in your car, but as-is, that dissie is strangling your car's performance (and, even, its MPG,
because the engine is not being allowed to consume its gas efficiently).
Edited by d500neil 2012-05-28 8:10 PM
d500neil
Posted 2012-05-28 7:46 PM (#323287 - in reply to #165059)
...Above 50 degrees of Total Advancement, your car would probably ping, at 70 MPH cruise mode.
Premium grade gas will be a 'must', at sea level, to prevent engine 'knocking', with Total Advancement greater than
50 degrees.
So, if you do nothing else to hot-rod your 4301A, you could dial-in about 7-8 degrees of I.A. so: 7+19(=26 T.M.A.)+23= 49 and
8+19(=27 T.M.A.)+23= 50
Ideally, you want your T.M.A. to calculate to about 34-36 degrees, so, at 26/27 degrees you are well short of maxing-out your
dissie's hard-acceleration performance, and, its OEM very-heavy 'light' spring will also retard the dissie's advancement rate,
in even getting up to the 26/27 degrees of T.M.A.
But, the car will cruise around town nicely, as-is...
Edited by d500neil 2012-05-28 8:11 PM
JT Vincent
Posted 2012-06-01 3:12 PM (#323971 - in reply to #165059)
Floors all stitched in, reassembly stage. Just a tiny nod to rat rods with 66 Charger bucket seats, a 300 style console and black interior. No worries, I kept the stock stuff in case I have second thoughts.
(inside.JPG)
Attachments inside.JPG (271KB - 612 downloads)
D500Jim
Posted 2012-06-01 3:36 PM (#323976 - in reply to #165059)
10001001001002525
I drove a few nice girls to their school prom today. Had them in my travel trailer and my 57 Dodge did just fine!
(IMG_2658.jpg)
Attachments IMG_2658.jpg (214KB - 585 downloads)
di_ch_NY56
Posted 2012-06-02 12:36 PM (#324052 - in reply to #165059)
100050025
Wow, nice Jim. Thanks a lot for this picture.
I'll say big thank you to Sven (Wizard) and Neil (D500Neil) for your assistance and emotional help to bring my Chrysli back to a normal running state. Today prior to do a test ride I tightened the inner screw at the distributor to tighten the connector of the lead wire to the point. Together with the cleaned carb my Chryli purred like a cat and never had a flat spot during acceleration.
It was a pleasure to ride my Chrysli today. It brought me back with no problems. The ambient temperature was around 80 F (27 C degrees). The picture with the gauges I took after the test run. The engine was at idle. When the oil's hot (normal temperature) the pointer shows around 50%. The amp meter's low because I was on the brake. When the engine speed's higher the needle is at 50% (in the middle).
Happy Motoring!
Dieter
BTW: Yes Neil, I know - the IBK-4301A is the double breaker dissi with the most conservative advance of all dissies. That I read on a site of a D500 owner who described all the modifications he did at his engine. Here in Switzerland no lower than 95 octane (European measurement system) is available. It's what I'm running.
Edited by di_ch_NY56 2012-06-02 12:57 PM
(DSC01607detail.JPG)
(IMG_0673resized.jpg)
Attachments DSC01607detail.JPG (119KB - 647 downloads)
Attachments IMG_0673resized.jpg (159KB - 638 downloads)
Posted 2012-06-02 12:53 PM (#324055 - in reply to #165059)
Dieter, your temp is a little low - please check the temperature with for instance IR-instrument @ the thermostat housing and tell us the actual working temp. Oil pressure seems good, a single grade SAE 30 with ZDDP additive will save your engine and maybe even get more milage out of it too.
di_ch_NY56
Posted 2012-06-02 1:07 PM (#324056 - in reply to #165059)
100050025
Hi Sven
Thank you very much for your response. I know - the gauge doesn't show more - even though there's a new temp sensor mounted. --> the same value. It looks like the needle would stick. At a rough surfaced rural road the needle swings a little bit to the left side and never above that position.
Actually I'm running 20W50 oldtimer oil it should have more zddt. At Panolin I ordered another 10L to replace the oil in the engine. After a short time it turned dark black (from what I saw /w the disaster /w the canister oil filter - last year).
The radiator is so hot I only touch it for a very short instant. Next time I'll take the IR temp meter /w me.
Happy Motoring!
Dieter
Posted 2012-06-02 1:46 PM (#324060 - in reply to #165059)
I'm running a 195 Fahrenheit (90 celcius) thermostat and the thermostat housing is approximate @ 87 C. The black oil is most probably sludge and residue that are dissolved by the new oil. You need to change oil at short intervals in the beginning Dieter, like maximum 500 km.
I had the same situation with my car - the oil level actually increased with the blackish oil - the only explanation must be sludge that dissolved. Now my oil is not discolored, no more than normal. I change the oil at 500 - 1000 km though. I reason like this - old engine, never renovated - stick to the old ways I run Pennzoil straight grade SAE 30 (because I don't drive in the winter, hence no need for thinner oil) + extra ZDDP additive - looks like honey and the engine runs smooth as silk
di_ch_NY56
Posted 2012-06-02 4:32 PM (#324071 - in reply to #324060)
100050025
wizard - 2012-06-01 7:46 PM
I had the same situation with my car - the oil level actually increased with the blackish oil - the only explanation must be sludge that dissolved. Now my oil is not discolored, no more than normal. I change the oil at 500 - 1000 km though. I reason like this - old engine, never renovated - stick to the old ways I run Pennzoil straight grade SAE 30 (because I don't drive in the winter, hence no need for thinner oil) + extra ZDDP additive - looks like honey and the engine runs smooth as silk :)
Hello Sven
Thanks a lot for your quick response. Again I went back to my Chrysli to do another about half an hour ride. First I had to do an emergency stop because a bike rider (small bike) didn't turn his head to the rh side - just drove into my trace... good luck I could stop and he looked puzzled... (prior the emergency break my speed was about 40 to 45 mph)
After returning I let the engine running while measuring: 91 at the rear, 85 at the front (wind from the rotating fan). Engine stopped 89 rear, 88 front, 88 around the sensor.
So I guess either the wiring, the gauge or the characteristic of the sensor is the problem. Where do I find extra ZDDP additive? What's the name /brand?
I'll appreciate your answer very much. Thank you.
Happy Motoring!
Dieter
Posted 2012-06-02 4:56 PM (#324073 - in reply to #165059)
Good Dieter - the temperature seems just good. It's your sender that has the wrong characteristic, or the the voltage limiter (if there was one in 56?) not giving the right voltage. Have a friend to very shortly ground the sender cable when you look at the gauge - it should move towards "HI".
PM sent.....
BigBlockMopar
Posted 2012-06-02 5:22 PM (#324076 - in reply to #165059)
20001000500252525
Took my '60-NY to our monthly Saturday Night Cruise/Meet in town here.
Here's a pic for the purists...
(20120602-60NY-SNCweb.jpg)
Attachments 20120602-60NY-SNCweb.jpg (144KB - 623 downloads)
d500neil
Posted 2012-06-02 9:46 PM (#324101 - in reply to #165059)
Went Olde Skool and used a brand new chamois to wipe off H. after his weekly exercise (prefer cotton turkish-towels,
however).
Posted 2012-06-02 10:41 PM (#324116 - in reply to #165059)
I installed a original power seats I found in a yard ( Got it Reupholstered of course ) in my beloved belvedere!
Beltran
Posted 2012-06-03 3:14 PM (#324178 - in reply to #165059)
100050010010025
I'm sorry but these text updates don't count unless you post a picture. :P Sheesh... anyone can type text... but a picture says a thousand words!
Take that extremely nice picture above showing all those nice models (err a prom queens) obscurring the view of that very nice Dodge.... not that I am complaining mind you... just sighting an example.
57plymouth
Posted 2012-06-03 3:22 PM (#324180 - in reply to #324178)
2000100050010025
Took the radiator out again, to get the top tank fixed again. Seems like a never ending cycle. Once every other year or so the top tank springs a leak again.
oldwood
Posted 2012-06-03 3:27 PM (#324181 - in reply to #324116)
2000500100100100100
1958 Plymouth Infina - 2012-06-02 10:41 PM
I don't believe you. Pictures are worth a THOUSAND words. You spend ALL that $$$ to get a seat and recover and then HIDE it from us. Shame Shame The FL Gods will set you straight!!! Before and after pics.
Edited by oldwood 2012-06-03 3:28 PM
big m
Posted 2012-06-04 7:02 PM (#324347 - in reply to #324180)
5000200050010010010025
57plymouth - 2012-06-03 12:22 PM
Try a seven pound pressure cap, Brian.
I had a '58 Merc hardtop wagon that had the same problem, the metal was fatigued and expanded too much, stressing the solder seam. mThe lower pressure cap eliminated the problem.
---John
big m
Posted 2012-06-04 7:08 PM (#324348 - in reply to #165059)
While driving the Fury today, the engine suddenly died, and a cloud of white electrical smoke poured from under the hood and dash. I turned the ignition off, and pulled over to disconnect the battery, and found the primary ignition wire had rubbed through on the distributor shaft, causing a short circuit. By cutting the ignition quickly, it did little damage except to the one wire. Decided to use the '59 Dodge until I have time to inspect the electrical system further.
---John
57plymouth
Posted 2012-06-05 7:05 AM (#324413 - in reply to #165059)
2000100050010025
Will do. Thanks John!
di_ch_NY56
Posted 2012-06-09 2:17 PM (#324937 - in reply to #165059)
100050025
Today I wanted to open the oil pan drain plug. But it resisted.
Happy Motoring!
Dieter
Windsor59
Posted 2012-06-09 4:19 PM (#324968 - in reply to #324937)
2000500100
Begun to assemble the carburetor, it is fortunate that we took pictures before but unscrew it. Difficult one time.
(DSC_0561.jpg)
(DSC_0568.jpg)
Attachments DSC_0561.jpg (62KB - 619 downloads)
Attachments DSC_0568.jpg (64KB - 610 downloads)
57DodgeD100
Posted 2012-06-10 12:04 AM (#325019 - in reply to #165059)
Today, I drove my FL truck to a local cruise in. Only 3 others decided to cruise in. ?? Oh well, I enjoyed driving it and appreciated several thumb ups from those passing me.
57plymouth
Posted 2012-06-10 7:23 AM (#325035 - in reply to #165059)
2000100050010025
Put the radiator in the 57 this morning. I found a 7 pound cap thanks to this site. We'll see how she does after church...
jboymechanic
Posted 2012-06-11 11:13 PM (#325255 - in reply to #165059)
2000100100
Insulated the floor with FatMat in the '56 Imperial. Working on the wiring harness currently and going in next week for a new head liner.
http://i1016.photobucket.com/albums/af286/jboymechanic/1956%20Imper...
Edited by jboymechanic 2012-06-11 11:17 PM
Posted 2012-06-11 11:57 PM (#325257 - in reply to #165059)
5000200010010025
Took my grille and top support out, brackets, hood latch etc. Am sanding and repainting the font of the core support and lower inner valance panel in front of the core support behind the grille. Forgot to take a photo before I put the car back in the garage, maybe tomorrow evening.
d500neil
Posted 2012-06-12 12:18 AM (#325258 - in reply to #165059)
Installed Horace D. Dodge's FIFTH car cover, since 1981.
Congratulations, H.
(PICT5118.JPG)
Attachments PICT5118.JPG (108KB - 589 downloads)
D500Jim
Posted 2012-06-12 2:07 AM (#325264 - in reply to #325258)
10001001001002525
d500neil - 2012-06-12 6:18 AM Installed Horace D. Dodge's FIFTH car cover, since 1981. Congratulations, H.
Looks good! Tell me more about it when I visit you.
Heake1978
Posted 2012-06-12 2:40 AM (#325266 - in reply to #325019)
New User
57DodgeD100 - 2012-06-10 12:04 AM
glad to hear that. but in me not much done unique.
