"Make-Up" your Car! Jump to page : < 1 2 3 4 5 6 7 > Now viewing page 2 [50 messages per page] | View previous thread :: View next thread |
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Automatic Beam-Changer: This Option was not on my Car when purchased. One day I found solely the Original Sensor Module, and I thought: “Why not?” I designed a Transistor Trigger Circuit, soldered on a Board and mount under the Dashboard for direct access. A Printed Circuit Board (PCB) would have a quarter of Size. To eliminate the often discussed Flashing in Operate Mode, I set a higher Hysteresis (= Difference between ON – OFF Transition) and a longer ON Time-Constant (10 millisec for Beam OFF, +2 sec for Beam ON), as a manual Switching. The preset of the Sensitivity is done by the Trimmer on the Circuit Board (not visible), directing in the Garage a Pocket Lamp to the Beamer Unit to simulate the Light of an oncoming Car. The fine Adjustment when driving by turning the rear Knob on the Sensor Unit. Now, the Automatic Headlight Control works excellently, but still remains critical in some Light Conditions due to the limited Viewing Angle of the Photo-Cell. Another Optional Equipment, not necessarily needed, but always nice to have. :) To know: the Automatic Inside Mirror - MirrorMatic uses the same basic circuit, both use the same Vacuum Tube 12k5. A PCB Transistor Circuit would fit in this Housing, or the Tube could simply be substituted by adequate Transistors, directly plug in the Tube Socket (12V Operation). Edited by sermey 2009-01-29 9:51 AM (1 Ross Roy - Automatic Beam-Changer L.jpg) (2 DSC03002L Transistor Circuit & Relais.jpg) (3 DSC02982L Beamer Unit .jpg) (4 DSC03000L Beamer OverView.jpg) Attachments ---------------- 1 Ross Roy - Automatic Beam-Changer L.jpg (54KB - 653 downloads) 2 DSC03002L Transistor Circuit & Relais.jpg (89KB - 628 downloads) 3 DSC02982L Beamer Unit .jpg (47KB - 651 downloads) 4 DSC03000L Beamer OverView.jpg (81KB - 668 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Dimmer Switch: Even when not directly visible, this Switch can easy be upgraded just by putting a Rubber Cap (not Plastic, Bore Dia. 22mm x 20), as used for Chairs. Now, the covered Knob not only looks more discreet and similar to the Windshield Washer Pad, applying the Dimmer Switch feels much more comfortable. Comparing both Pictures it even seems, without the Rubber Cap something is missing. A quite simply improvement for any Oldtimer! Edited by sermey 2009-01-31 4:39 AM (DSC03036L Rubber Cap.jpg) (DSC03051L Original Dimmer Switch.jpg) (DSC03050L Dimmer Switch with Rubber Cap.jpg) Attachments ---------------- DSC03036L Rubber Cap.jpg (39KB - 629 downloads) DSC03051L Original Dimmer Switch.jpg (67KB - 660 downloads) DSC03050L Dimmer Switch with Rubber Cap.jpg (67KB - 655 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Sun Visors: On a Convertible the Sun Visors have an additional Function. In slightly higher than in horizontal Position they can reduce the Turbulences at open Top, acting as a virtual Extension of the Windshield. Then they are additionally exposed to a displacement. To tighten a hanging Sun Visor, pull it out (may need some force), put in a parallel vice between two plane planks, protect it as illustrated, then squeeze a little bit in several steps until fixed enough. Now, the Sun Visors remain in any circumstances at the preset Position. Edited by sermey 2009-01-31 3:04 PM (DSC03074L Removed Sun Visor.jpg) (DSC03069L Retense The Sun Visor.jpg) (DSC03068L Sun Visor Up.jpg) Attachments ---------------- DSC03074L Removed Sun Visor.jpg (49KB - 632 downloads) DSC03069L Retense The Sun Visor.jpg (71KB - 634 downloads) DSC03068L Sun Visor Up.jpg (78KB - 627 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | 15” Wheels and Tires: I always found, 14” Wheels on my Car are relatively too small and look poor in Proportion to the Body and its Wheelhouse. Must say, this was the Style at this time. The other Point, bigger and wider Tires have much better Adhesion on the Street, the 235/70/15 Radial Tires about +25% in Comparison to the Original 14” Diagonal ones. This improvement is necessarily needed for a full Advantage of Disk Brakes. Thus, I decided in favor of 15” Wheels and the corresponding WWW Tires, still keeping the Original 14” Wheel Set including the Spinner Hubcaps. In order to keep the Original Appearance, the Original HubCaps should fit to the 15” Rims. I bought 15” decorative stainless Rings, cut out the Border around, and soldered it inside the Wheel Cover. For a stronger Fixing on the rechromed Wheels I increased the Clamp Pression by putting a soft round PVC Profile under the Clamps. Now, the Hubcaps fit perfectly to the 15” Rims, their Edges are even protected from Curbstones due to the inner Position, and the Air Valve is perfectly centered as well. According my personal feeling, this Wheel Size gives the Car its settled Proportions. Another improvement of the Outfit, for the Drivers Security, and as an additional Benefit the Wheel Cover Edge Protection. (can see, my HubCaps are not perfect, but polished and with the sticked Black they look as) Edited by sermey 2009-02-01 12:24 PM (Original Wheel and Parking Lamp.jpg) (1 DSC00001L Coker Tires 235-70-15.jpg) (2 DSC03078L 15 Inch Decorative Stainless Rings.jpg) (3 DSC00051L Soldered 15 Inch Ring.jpg) (4 DSC03081L Inner Border of HubCap.jpg) (5 DSCN0012L 15 Inch Wheel Assembled.jpg) Attachments ---------------- Original Wheel and Parking Lamp.jpg (73KB - 651 downloads) 1 DSC00001L Coker Tires 235-70-15.jpg (101KB - 643 downloads) 2 DSC03078L 15 Inch Decorative Stainless Rings.jpg (67KB - 620 downloads) 3 DSC00051L Soldered 15 Inch Ring.jpg (68KB - 592 downloads) 4 DSC03081L Inner Border of HubCap.jpg (89KB - 619 downloads) 5 DSCN0012L 15 Inch Wheel Assembled.jpg (97KB - 617 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | obsolete Edited by sermey 2009-12-04 5:07 PM | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Dome Nuts and Caps: These devices remove optically bad nuts, covers them or even protect them. Dome Nuts in polished stainless steel may appear as small diamonds. A low-cost "Jewel+ for your car! - SERGE - :laugh: (01 Dome Nuts - Caps DSC03156.jpg) (02 DomeCap DSC03154.jpg) (03 DomeNuts Connector DSC00632a.jpg) (04 DomeNuts Induction Coil.jpg) Attachments ---------------- 01 Dome Nuts - Caps DSC03156.jpg (48KB - 630 downloads) 02 DomeCap DSC03154.jpg (53KB - 626 downloads) 03 DomeNuts Connector DSC00632a.jpg (55KB - 610 downloads) 04 DomeNuts Induction Coil.jpg (79KB - 600 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Plugged Instruments and Speedometer Units: Working on this Units, what ever the brand of the car, was always a mess for not scratching the painted surrounding, interrupt unintentionally a connection, produce accidentally a short-circuit (when battery unplugged) and even to fix them when working. On newer cars the Units can be removed by unplugging many cables. On our FL-cars, except for the lamps, most cables are fixed.
Edited by sermey 2009-12-06 11:00 AM (2009-04-23 DSC03212 Speedometer Unit.jpg) (2009-04-23 DSC03206 Front Instruments Panel.jpg) (2009-04-23 DSC03205 Rear Instruments Panel.jpg) (2009-04-23 DSC03204 View Under Dashboard.jpg) Attachments ---------------- 2009-04-23 DSC03212 Speedometer Unit.jpg (58KB - 582 downloads) 2009-04-23 DSC03206 Front Instruments Panel.jpg (82KB - 594 downloads) 2009-04-23 DSC03205 Rear Instruments Panel.jpg (88KB - 610 downloads) 2009-04-23 DSC03204 View Under Dashboard.jpg (129KB - 616 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Rechromed Substitute Parts: On the market there are many rechromed parts available as substitutes, additional eye-catchers. Here two samples. The Generator Bracket. Fits directly. For a nicer look can be shortened for best match, as I did here. The Oil DipStick with the Tube. I bent the tube according the position I liked. Then, unfortunately the Oil DipStick couldn't be inserted anymore in the tube. Easy trick: Just twist it! :laugh: - SERGE - (Rechromed Generator Braket LL.jpg) (Rechromed Distributor HoldDown LL.jpg) (Rechromed Oil DipStick LL.jpg) (Rechromed Oil DipStick Twisted LL.jpg) (Rechromed DipStick in Tube LL.jpg) Attachments ---------------- Rechromed Generator Braket LL.jpg (92KB - 605 downloads) Rechromed Distributor HoldDown LL.jpg (75KB - 614 downloads) Rechromed Oil DipStick LL.jpg (64KB - 593 downloads) Rechromed Oil DipStick Twisted LL.jpg (40KB - 608 downloads) Rechromed DipStick in Tube LL.jpg (97KB - 581 downloads) | ||
1959 Belvedere Conv |
Elite Veteran Posts: 1107 Location: Arvada, Colorado (NW Denver Metro Area) | Serge, You have a beautiful well detailed car. You should go back in time an be a stylist for Chrysler back in the Forward Look days. Though my 59 Plymouth convert is not at your higher trim level, I will use a lot of the detail points to bring out the best in my instrument panel. PS I have never seen here in the States Dupli-color in the RAL color system. I am in the electrical business now (20 years )and we use the RAL paint system for coloring large electrical enclosures. I will have to see if they market these RAL colors in the US of A. It would help me a lot in getting touch up paint. | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | 1959 Belvedere Conv - 2010-02-14 2:49 AM Serge, You have a beautiful well detailed car. You should go back in time an be a stylist for Chrysler back in the Forward Look days. Though my 59 Plymouth convert is not at your higher trim level, I will use a lot of the detail points to bring out the best in my instrument panel. PS I have never seen here in the States Dupli-color in the RAL color system. I am in the electrical business now (20 years )and we use the RAL paint system for coloring large electrical enclosures. I will have to see if they market these RAL colors in the US of A. It would help me a lot in getting touch up paint. Thank you, John. Every one has his own talents. We all have got them for free. The ones uses them more, the others less. I think, most owner of an oldtimer will find and trim his car to a higher level, as soon he has done all needed restorations. Owning just one car is much easier. The RAL Colors are well defined Color Standards and available on a CD, indicating the RGB (Red-Green-Blue) percents, awell known by Photoshop-Users. Thus, any RAL Color can be mixed accordingly, and get exactly the same tone. Edited by sermey 2010-02-15 10:49 AM | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Oil Cap on Valve Cover: This is another part that can be directly replaced by a similar rechromed one, also available on the market. Here I preferred to keep the Original Cap of the 1959 DODGE with the script "OIL" on top. Bevor rechroming, the steel filter preventing oil to leak on the valve cover, has to be removed. It can be replaced by a rough stainless steel wool, as used for cleaning pans, inserted with a long-nosed plier. A fine steel Wool would clog when oily and prevent the needed air breathing. Valve Cover: There are as well rechromed valve covers available, What you see are the rechromed originals. To rechrome with polishing costs more than than a replacement. - SERGE - Edited by sermey 2010-02-15 1:14 PM (1959 Original Rechromed Oil Cap LL.jpg) (Oil Cap Stainless Steel Wool LL.jpg) (361 Oil Cap on Valve Cover LL.jpg) Attachments ---------------- 1959 Original Rechromed Oil Cap LL.jpg (55KB - 710 downloads) Oil Cap Stainless Steel Wool LL.jpg (66KB - 741 downloads) 361 Oil Cap on Valve Cover LL.jpg (126KB - 744 downloads) | ||
1959Dodge |
Expert Posts: 2244 Location: Yorba Linda, Ca | Nice job on the car "Make up". Maybe when you are done, we can switch cars for a while and you can do mine. Or you could come out here, weather is great today, probably be close to 30C so come here, I give ya free room and board, while you update the makeup on ny car!!! Gary | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | 1959 Belvedere Conv - 2010-02-14 2:49 AM Serge, You have a beautiful well detailed car. You should go back in time an be a stylist for Chrysler back in the Forward Look days. John, I have done some small stylist modifications, Virgil Exner would even be happy about - but not the purists. | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | 1959Dodge - 2010-02-15 7:22 PM Nice job on the car "Make up". Maybe when you are done . . . Sorry, Gary, it is never done. The show goes on! A never ending process. - SERGE - | ||
Board Moderator & Exner Expert 10K+ Posts: 13045 Location: Southern Sweden - Sturkö island | sermey - 2010-02-15 4:39 PM Here I preferred to keep the Original Cap of the 1959 DODGE with the script "OIL" on top. Bevor rechroming, the steel filter preventing oil to leak on the valve cover, has to be removed. It can be replaced by a rough stainless steel wool, as used for cleaning pans, inserted with a long-nosed plier. A fine steel Wool would clog when oily and prevent the needed air breathing. - SERGE - I used exactly the same material and method with Oil Cap - mine is painted black though. | ||
Windsor59 |
Expert Posts: 2596 Location: Upplands Väsby, Sweden | wizard - 2010-02-17 12:00 PM sermey - 2010-02-15 4:39 PM Here I preferred to keep the Original Cap of the 1959 DODGE with the script "OIL" on top. Bevor rechroming, the steel filter preventing oil to leak on the valve cover, has to be removed. It can be replaced by a rough stainless steel wool, as used for cleaning pans, inserted with a long-nosed plier. A fine steel Wool would clog when oily and prevent the needed air breathing. - SERGE - I used exactly the same material and method with Oil Cap - mine is painted black though. OK! thanks for this tips: It can be replaced by a rough stainless steel wool, as used for cleaning pans, inserted with a long-nosed plier I must changes the stainless steel wool in my oil cap. | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Constant Voltage Regulator: This is a thermo-mechanical contact breaker, and cannot be repaired (metallic sealed). It's output is a pulsing 12V, resulting in an average output of 5Volt. This voltage can only be measured with a long-time integrating instrument. A connected 12V instruments bulb will flash correspondingly. The regulator is used to operate both, the fuel level and the temperature gauges. The readings for two Input Voltages of 9 and 18 Volt, and the water temperature gauge loaded for "normal" reading (sensor simulation R = 22 Ohm, see Pic) have been tested. The output of the device shows a constant value of 4.90 Volt. The original voltage regulator can be left there as is, but unconnected, or it can be removed as shown. On the illustrations the device is not connected (demo on a spare instruments panel), best should be soldered. Another invisible new technology for a better performance and a higher reliability of your car. - SERGE - :laugh: To know: I have purchased some additional devices for interested FWLs and can offer them at cost price: USD 5.00/piece plus shipment by letter (PAYPAL sermey@bluewin.ch). Edited by sermey 2010-02-24 1:48 PM (1 - Dodge59 Constant Voltage Regulator LL.jpg) (2 - Electronic Regulator Pin Connection LL.jpg) (3 - Reading at 9 Volt Input LL.jpg) (4 - Reading at 18 Volt Input LL.jpg) (5- Both 5 Volt Regulators Mounted LL.jpg) (6 - Only Electronic 5 Volt Regulator Mounted LL.jpg) Attachments ---------------- 1 - Dodge59 Constant Voltage Regulator LL.jpg (92KB - 633 downloads) 2 - Electronic Regulator Pin Connection LL.jpg (64KB - 678 downloads) 3 - Reading at 9 Volt Input LL.jpg (81KB - 664 downloads) 4 - Reading at 18 Volt Input LL.jpg (90KB - 703 downloads) 5- Both 5 Volt Regulators Mounted LL.jpg (80KB - 636 downloads) 6 - Only Electronic 5 Volt Regulator Mounted LL.jpg (93KB - 648 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Remote Hood Lock: Most cars at this era didn't had this option. Everyone could open the hood from front, the ones for curiousity, the others just for steal the battery as experienced many years ago. Thus, I had not a good feeling with an "open" hood on my Dodge. I found a "HOOD" remote cable (must be from a 1960 Mopar?), purchased later a NOS hood lock on eBay, and now it is mounted. The hood lock arm had to be cut and bent upward for a functional operation, and for preventing from manual open. Then the end of the arm got a thread (M5) with a groove for easy connecting and the fine adjustment of the cable length. The remote hood lock handle is mounted on the drivers left side, under the dashboard. Now, the battery (and the oval air filters!) are safe, and not anymore opened hood by curious people. - SERGE - Edited by sermey 2010-02-25 4:28 PM (1 - Hood Lock - Arm Cut LL.jpg) (2 - Prepared Lock Arm LL.jpg) (3 - Remote Cabel End LL.jpg) (4 - Control Cabel Connection LL.jpg) (5 - Connected Remote Control LL.jpg) (6 - Remote Hood Lock Handle LL.jpg) Attachments ---------------- 1 - Hood Lock - Arm Cut LL.jpg (60KB - 667 downloads) 2 - Prepared Lock Arm LL.jpg (59KB - 659 downloads) 3 - Remote Cabel End LL.jpg (43KB - 651 downloads) 4 - Control Cabel Connection LL.jpg (75KB - 680 downloads) 5 - Connected Remote Control LL.jpg (85KB - 669 downloads) 6 - Remote Hood Lock Handle LL.jpg (75KB - 673 downloads) | ||
DeSotohead |
Board Moderator Posts: 3186 Location: The not-so-great, dirty-white North ( Michigan) | sermey - 2010-02-24 11:07 AM Constant Voltage Regulator: This is a thermo-mechanical contact breaker, and cannot be repaired (metallic sealed). It's output is a pulsing 12V, resulting in an average output of 5Volt. This voltage can only be measured with a long-time integrating instrument. A connected 12V instruments bulb will flash correspondingly. The regulator is used to operate both, the fuel level and the temperature gauges. The readings for two Input Voltages of 9 and 18 Volt, and the water temperature gauge loaded for "normal" reading (sensor simulation R = 22 Ohm, see Pic) have been tested. The output of the device shows a constant value of 4.90 Volt. The original voltage regulator can be left there as is, but unconnected, or it can be removed as shown. On the illustrations the device is not connected (demo on a spare instruments panel), best should be soldered. Another invisible new technology for a better performance and a higher reliability of your car. - SERGE - :laugh: To know: I have purchased some additional devices for interested FWLs and can offer them at cost price: USD 5.00/piece plus shipment by letter (PAYPAL sermey@bluewin.ch). Serge..... If you really want to make it look "original", you can mount the 5V regulator on a PC board inside the old regulator housing. That is what I have done with the Lucas equivalent on my Lotus Europa........ | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | DeSotohead: ..... If you really want to make it look "original", you can mount the 5V regulator on a PC board inside the old regulator housing. This is a good idea, Hank. Then the integrated circuit can directly be soldered inside on the existing pins. It will need a screw for the heat sink, and on the Dodge, the metallic housing of the regulator is bent all around and must be opened (?). I don't know if the other Mopars use the same regulator. Edited by sermey 2010-02-25 10:31 AM | ||
DeSotohead |
Board Moderator Posts: 3186 Location: The not-so-great, dirty-white North ( Michigan) | Here is how its done for the Europas..... (5vregulator.gif) Attachments ---------------- 5vregulator.gif (57KB - 660 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | This is the same Mopar Regulator. But this one has only two bent edges. The one in my car (see above Pic 5) is bent all around. The electronic regulator is a similar one, may-be an earlier product. There are many available, from various manufacturers and for different applications. The one I selected is best for our application and, according the datasheet, doesn't need any components at all (internally compensated), and cannot be destroyed (temperature and current protected). This security is a big advantage, thinking the regulator is located behind the instruments panel and not directly accessible. Not needed, but the output accuracy in respect to the input range as tested is impressive (4.90V). Too precise for cars of the fifties! Edited by sermey 2010-02-25 11:18 AM | ||
DeSotohead |
Board Moderator Posts: 3186 Location: The not-so-great, dirty-white North ( Michigan) | THe actual 5V regulator is really not an issue. As you point out, several companies make them, including the infamous adjustible "LM317" regulator from National. As for your housing, I think it is quite possible to bend the four corners up and away. You might try heating the metal with a small butane torch as you pry, or use a large tip on a soldering iron. Once removed, you can finish the bent up taba with a small hammer and a piece of steel as a backer to straighten the metal. Recrimping can be done with a small anvil vise. | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Fixing the Spinner Hubcaps: I guess these 1959 hubcaps may be the heaviest ones among the FWL- cars. As the spinners are just mounted on the wheel covers and remain unbalanced, an asymmetric radial force is being applied on the rims when driving. The pression to the rims is increased on the one side, and reduced correspondingly on the opposite side. This causes the spinner hubcaps to move slightly outwards on the reduced force side. Mechanical shocks on bad streets to the critical diameter accelerates this process. The front wheels, especially the right side one (for right. hand traffic), are more exposed then the rear ones. I have observed on some hubcaps an outward displacement up to 1mm after a trip of about 500km. Therefore the fit of the hubcaps have to be checked at regular intervals. Once it happens me to loose the front right spinner hubcap on the original rims. Fortunately I noticed this on the spot and could retrieve it. After that, on longer trips to car meetings, I safety removed the hubcaps. This caused to miss a winner "best of show", forgetting to put on the hubcaps, laying behind the front seats. Not only, but for best presentation this car needs the original hubcaps. It even happened by an oversight to take pictures without hubcaps. Now I had to find a solution! Diametral in the 15" chrome-wheels I removed two diametric nuts (the nuts are just dummies as design) and put an M5 inserting-nut instead (as described earlier). The position has to match the air-valve! Then I bent a profile in aluminium as fixing latch, with an M4 inserting-nut (here in aluminium black anodized) on one end. For each hubcap two latches are needed. The fine adjustment to the hubcaps is done by rotating and manually bending them on the wheel. The hubcaps need two holes (4 mm) in the groove, not drilled, just by applying multiple times the center puncher in order to keep the border for the countersink screws M4. This two stainless screws are hardly visible, on the picture time position 04.50. I still have some reserve wheel covers for keeping the originality, if one day it should be required. Now, my 1959 Dodge Convertible will always be fitted with the nice spinner hubcaps, without any stress of loosing them or even being "removed" (get stolen). - SERGE - Edited by sermey 2010-02-27 12:50 PM (1 - Inserted Nut LL.jpg) (2 - Fixing Latches LL.jpg) (3 - Latch Mount LL.jpg) (4 - Mounted Latches LL.jpg) (5 - Countersink Screw LL.jpg) (6 - Fixed Spinner Hubcap LL.jpg) Attachments ---------------- 1 - Inserted Nut LL.jpg (90KB - 615 downloads) 2 - Fixing Latches LL.jpg (65KB - 634 downloads) 3 - Latch Mount LL.jpg (73KB - 672 downloads) 4 - Mounted Latches LL.jpg (109KB - 650 downloads) 5 - Countersink Screw LL.jpg (65KB - 671 downloads) 6 - Fixed Spinner Hubcap LL.jpg (124KB - 640 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Fuel Gas Tank Cap: On most FWL-Cars the Fuel Gas Tank Cap is not visible from outside, on many Sports Cars it is part of the design and lettered accordingly (GT, SS). On a nice car, this device should as well correspond to the car, to its design and to the prefences of the owner. On the market there are various caps available, with and without locks. The pictures show a selection offered in eBay. For my car the Fuel Gas Tank Cap should have the properties as: 1. Vented type, preventing pressions in the tank. 2. With lock, protecting the acces to others. 3. Covered lock, to keep it free from dirt. 4. The ability to fix it without key. 5. A nice rechromed design, matched to the car. Now, when tank up, the nice Fuel Gas Tank Cap underscores the exclusivity of the car. - SERGE - Edited by sermey 2010-03-22 6:38 AM (1 - Various Gas Tank Caps LL.jpg) (2 - Various Locking Gas Tank Cap LL.jpg) (3 - Dodge Fuel Gas Tank Cap LL.jpg) (4 - Dodge Fuel Cap Fixed LL.jpg) (5 - Dodge Fuel Cap with Keys LL.jpg) Attachments ---------------- 1 - Various Gas Tank Caps LL.jpg (115KB - 632 downloads) 2 - Various Locking Gas Tank Cap LL.jpg (99KB - 613 downloads) 3 - Dodge Fuel Gas Tank Cap LL.jpg (53KB - 668 downloads) 4 - Dodge Fuel Cap Fixed LL.jpg (53KB - 647 downloads) 5 - Dodge Fuel Cap with Keys LL.jpg (83KB - 624 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Trunk Lamp: Older cars have usually one trunk lamp, positioned in the center of the trunk, near the lock. The switch is in the bulb socket, activated at a given angle or inclination. For a big trunk like on FWL-cars, this illumination can be insufficient at the left and right end, especially when the trunk is dark carpeted. Additional lamps could be useful. I found Lamp Units with integrated switch, for individually On or Off. As separate switch, the same system is used as in the doors for the dome lamps. This switch is mounted by a bracket behind the trunk hinge (left side) the way, that at closed trunk the lamps goes off. Two lamp units are fixed, left and right, not visible on top in the upper corner. The needed electrical supply is already there. Another discreet adds-on. At night the opened trunk appear wider and more generous, as the car already is. - SERGE - Edited by sermey 2010-03-26 6:35 PM (1 - Trunk Light LL.jpg) (2 - Trunk Lamp Units LL.jpg) (3 - Trunk Light Switch LL.jpg) (4 - Mounted Lamp Unit LL.jpg) (5 - Trunk Lamp Unit Left Side View LL.jpg) Attachments ---------------- 1 - Trunk Light LL.jpg (51KB - 656 downloads) 2 - Trunk Lamp Units LL.jpg (65KB - 621 downloads) 3 - Trunk Light Switch LL.jpg (67KB - 655 downloads) 4 - Mounted Lamp Unit LL.jpg (80KB - 644 downloads) 5 - Trunk Lamp Unit Left Side View LL.jpg (81KB - 639 downloads) | ||
Elite Veteran Posts: 1107 Location: Arvada, Colorado (NW Denver Metro Area) | Serge, in picure 6 of the constant voltage regulator thread, there is a small blue electronic device with stripes used, is that a diode or capacitor you installed? and why? thanks! | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | 1959 Belvedere Conv - 2010-03-27 1:45 AM Serge, in picure 6 of the constant voltage regulator thread, there is a small blue electronic device with stripes used, is that a diode or capacitor you installed? and why? thanks! John, this is the 22 Ohm resistor (0.3W), simulating the missing temperature sensor. With this value, corresponding to the warm-up engine, the temp gauge shows 60% reading, visible from the other side.This voltage regulator requires no additional electronic device at all. What you see is the rear of a "reserve" instruments panel 1959 Dodge. - SERGE - Edited by sermey 2010-03-27 2:40 AM | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Water Temperature Gauge Sender: Technical aspects about this device have already been discussed on another thread: "Defective Water Temperature Sensor" http://www.forwardlook.net/forums/forums/thread-view.asp?tid=29524&posts=15&start=1 Now, one more "brillant" on this car! - SERGE - Edited by sermey 2010-03-28 6:29 AM (1 - Temperature Gauge Sender LL.jpg) (2 - Thread M3 on Sensor LL.jpg) (3 - Dome Cap M3 on Connected Sensor LL.jpg) Attachments ---------------- 1 - Temperature Gauge Sender LL.jpg (51KB - 632 downloads) 2 - Thread M3 on Sensor LL.jpg (102KB - 625 downloads) 3 - Dome Cap M3 on Connected Sensor LL.jpg (101KB - 632 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Black Painted Items: Many items on my car are black painted. Not the style of anyone, but to me for practcal reasons. When clean, it looks nice, can be partly repainted anytime without perceiving it, is neutral and gives a classic outfit. Finally: black is black, no problems with various tones as a white color. This is my personal view. Here how I do it, easy and nice: First brush the surface to remove old paint or rust. Then clean it with nitro-dilution or fuel, using a towel or washing the item with a paint-brush, to be absolute free of oil. The best paint I found and use for years is a spray, mat and includes rust-protection. It has a structure as silver paint and dries within a half hour. When the items are not directly exposed to water or rain, this paint can be applied directly on iron (or other material). For hot engine parts there is the similar "high temperature" spray. Inside the car or in corners, the surrounding can be masked with newspapers or a plastic foil, the hidden corners coloured with a paint-brush, using this paint previously sprayed in a can. As sample I used a rusty metal bar, here (highly zoomed) only brushed, not grinded or sanded. On the last picture, the black painted front of the engine (over 10 years old). The black paint is slightly shiny as silk, what gives an animated look. - SERGE - See as well the brushed and black painted Hood-Lock in an upper post. Edited by sermey 2010-04-03 11:20 AM (1 - Black Spray LL.jpg) (2 - Rusty Metal LL.jpg) (3 - Brushing LL.jpg) (4 - Metal Black Sprayed LL.jpg) (5 - Black Paint on Front LL.jpg) Attachments ---------------- 1 - Black Spray LL.jpg (100KB - 655 downloads) 2 - Rusty Metal LL.jpg (68KB - 669 downloads) 3 - Brushing LL.jpg (69KB - 657 downloads) 4 - Metal Black Sprayed LL.jpg (69KB - 656 downloads) 5 - Black Paint on Front LL.jpg (115KB - 646 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Aligning the Front Bumper: We all know, the precision on those cars was not high as on cars of today. This becomes apparent on mounted doors, hoods and trunk lids, but as well on bumpers. The front bumper of the 1959 Dodge is especially critical due to its side design - any mis-alignment to the fender is visible. When mounted as it is from original, most are hanging down. Some nice cars as illustrated (1) (pics from thread Vasteras) look as the front bumper will get lost at any instance. This was as well on my car. Correcting this by an asymmetric support would move the bumper more forward. But the bumper should even be more back to fit as well to the border of the fender. To move it more back, the mounting arms have to be shortened. Due to an angle of about 45deg the arms have in respect to the bumper, the mounting holes would not fit anymore by just cutting them. They have to be welded overlapped as shown (2). The adjustment in forward position then is easy achieved by inserting washers (3). The hanging side to come up can be corrected by grinding the bracket correspondingly. Recently I improved this alignment by slightly untight the bolts, pushing the bumper on the side up to maximum, using the car lifter. Then fixing (just hanging) the bumper up, with two adjustable aluminium angle brackets (3) on each side (4). When aligned and fixed in the correct position, finally tighten all bumper bolts (on Pic 4 you see as well how the Lancer Emblem is fixed, this way already posted earlier). Now, the front bumper is there where it should be, as it was initially designed. - SERGE - Edited by sermey 2010-04-24 1:08 PM (1 - Hanging Front Bumpers LL.jpg) (2 - Bumper Arm Welding LL.jpg) (3 - Forward Adjustment LL.jpg) (4 - Adjustable Angle Brackets LL.jpg) (5 - Front Bumper Fixed in Top Position LL.jpg) (6 - Aligned Front Bumper LL.jpg) Attachments ---------------- 1 - Hanging Front Bumpers LL.jpg (116KB - 645 downloads) 2 - Bumper Arm Welding LL.jpg (72KB - 664 downloads) 3 - Forward Adjustment LL.jpg (70KB - 634 downloads) 4 - Adjustable Angle Brackets LL.jpg (68KB - 683 downloads) 5 - Front Bumper Fixed in Top Position LL.jpg (86KB - 658 downloads) 6 - Aligned Front Bumper LL.jpg (76KB - 649 downloads) | ||
Board Moderator & Exner Expert 10K+ Posts: 13045 Location: Southern Sweden - Sturkö island | Way to go Serge! You have cured the "American Car disese"! Next to all US cars (exeption from the master renovated ones) has a misaligned bumper. This is indeed a very noticable difference. | ||
59CRL |
Expert Posts: 2679 | I see you have a 22 ohm resistor hooked up there, (red, red, blk) I bet for testing purposes, very good. I replaced my old CVR with a 5 volt 7805 today and a NOS gauge. I let the car idle for 30 minutes and the gauge reads 1/3rd, not bad at all. Tomorrow I will take her out for a ride and see where the gauge reads. Too much rain today. Thanks Sermey for the research and pics. | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | 59CRL - 2010-05-02 1:25 AM I see you have a 22 ohm resistor hooked up there, (red, red, blk) I bet for testing purposes, very good. I replaced my old CVR with a 5 volt 7805 today and a NOS gauge. I let the car idle for 30 minutes and the gauge reads 1/3rd, not bad at all. Tomorrow I will take her out for a ride and see where the gauge reads. Too much rain today. Thanks Sermey for the research and pics. Correct, the 22Ohm Resistor substitutes the sensor. This was technically discussed in the thread: "Defective Water Temperature Sensor" http://www.forwardlook.net/forums/forums/thread-view.asp?tid=29524&posts=22&start=1 | ||
59CRL |
Expert Posts: 2679 | sermey - 2010-05-01 7:52 PM 59CRL - 2010-05-02 1:25 AM I see you have a 22 ohm resistor hooked up there, (red, red, blk) I bet for testing purposes, very good. I replaced my old CVR with a 5 volt 7805 today and a NOS gauge. I let the car idle for 30 minutes and the gauge reads 1/3rd, not bad at all. Tomorrow I will take her out for a ride and see where the gauge reads. Too much rain today. Thanks Sermey for the research and pics. Correct, the 22Ohm Resistor substitutes the sensor. This was technically discussed in the thread: "Defective Water Temperature Sensor" http://www.forwardlook.net/forums/forums/thread-view.asp?tid=29524&posts=22&start=1 Bringing this thread back for an update. Sitting at idle with my 7805 voltage regulator I get 1/3rd on the temp gauge. Driving down the highway at temperatures of 95-100 degrees the gauge will read the same. Sitting in 100 degree heat with the engine idling the gauge will creep upto 3/4. Not bad at all. | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Emergency Car Cover: Imagine, you are on the road with your Convertible. It starts raining. You attempt to put up your top. But unfortunately it won't. May-be due to electrical problems, a defective pump, or it just clamps. In order to prevent your precious interior and the dash instruments to go wet, cover the car around all the interior with a multiple purposes Polyethylen-Foil (min. 0.1mm, 0.004"), and wait still raining has stopped. As illustrated, this cover (5 x 4 m) needs practically no space in the trunk (Package 30 x 38cm), and is always and instantly ready to use. ;) - SERGE - Edited by sermey 2011-01-16 4:10 AM (Emergency Car Cover.jpg) Attachments ---------------- Emergency Car Cover.jpg (77KB - 625 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Bullets for Rear View Mirror: A time ago some bullets have been offered in eBay. Even not an original mopar accessory, they went for up nearly USD100 a pair. Now I found "Chrome Bullet Heads" used as Tire Valve Caps in eBay, a set of 4pcs for USD 8.99, 5/8"x1 1/4" in metal. Proceedings: 1. Insert a cylindrical plastic plug inside the Bullet (D:7.2mm L 12mm), put-in a long screw (M4) till end, this will be tight and used for fixing. Reduce the bullet in length (from 30.5mm to 23.2mm) to fit the mirrors end diameter; cut the screw for remaining 5mm. The Bullet is ready for mount. 2. Remove the mirror nut, drill an M4 thread through, put back the Nut - the mirror is ready for the bullet. Now, just screw-in the assembled bullet, and your Rear View Mirror now shows the visible face lifting. The mirror bullets can easy be removed simply by manually unscrewing, to return to the mirrors standard view. Another gadget for your FWL Car - if you like it. - SERGE - Edited by sermey 2011-03-09 8:36 AM (DSC04478 Set of Tire Valve Caps LL.jpg) (DSC04477 Plastic Plug and M4 in Mirror Nut LL.jpg) (DSC04475 Screw-in the Bullet LL.jpg) (DSC04474 Face Lifted Rear View Mirror LL.jpg) (DSC04473 New Mirror with CameraMan LL.jpg) Attachments ---------------- DSC04478 Set of Tire Valve Caps LL.jpg (85KB - 678 downloads) DSC04477 Plastic Plug and M4 in Mirror Nut LL.jpg (47KB - 754 downloads) DSC04475 Screw-in the Bullet LL.jpg (56KB - 717 downloads) DSC04474 Face Lifted Rear View Mirror LL.jpg (58KB - 712 downloads) DSC04473 New Mirror with CameraMan LL.jpg (77KB - 668 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Door Panel Protection: When assembling the door panel I had to find a way, for not wear the new coating material at the opening of the door handle, when manipulating with. I took the body of a "Solder Sucking Wick" as used in electronics. This fits exactly in inner and outer diameter, in thickness of the door panel, and as well to the diameter of the handle, as it was designed for this application. Mounted, it doesn't turn at all and doesn't need additional spacers. Now, no friction at all to the padded coating material when manipulating the door handle - an easy and efficient solution - SERGE - Edited by sermey 2011-03-20 8:15 AM (DSC04514 Panel Protector LL.jpg) (DSC04515 Panel Protector Mounted LL.jpg) (DSC04517 Mounted Protector Rear View LL.jpg) (DSC04516 Door Handle Mounted LL.jpg) Attachments ---------------- DSC04514 Panel Protector LL.jpg (97KB - 688 downloads) DSC04515 Panel Protector Mounted LL.jpg (86KB - 689 downloads) DSC04517 Mounted Protector Rear View LL.jpg (81KB - 697 downloads) DSC04516 Door Handle Mounted LL.jpg (88KB - 741 downloads) | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | Hello Serge Thank you very much for this idea! I'll use it too. Thanks a lot. Happy motoring! Dieter | ||
Board Moderator & Exner Expert 10K+ Posts: 13045 Location: Southern Sweden - Sturkö island | Another Serge special - recycling and preserving in one step | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Emblem on Door Panel: On many previous cars I owned, I liked the variety of the emblems. This is as well with FWL-Cars. But what I was always missing, an emblem on the door panel of the 1959 Dodge Custom Royal.. I purchased gloove box doors of Coronets, where there is an emblem exactly complying to my demands. Now it looks as original, as it was designed for. Another "Royal" eye-catcher. - SERGE - Edited by sermey 2011-03-20 2:42 PM (DSC04544 Emblem Door Panel1 LL.jpg) (DSC04546 Emblem Door Panel2 LL.jpg) Attachments ---------------- DSC04544 Emblem Door Panel1 LL.jpg (76KB - 731 downloads) DSC04546 Emblem Door Panel2 LL.jpg (76KB - 713 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Door Panels: A 3mm, pressed material is used, cut the contour according the door (the lines are not parallel or rectangular!), drill the holes and openings for handle, switches, clamps. Coat all the panel with a premium to be waterproof. Bostitch a protective pad behind the clamps position, then cover all the panel with a soft 3mm padding material as used for upholstery (not foamed rubber!) and fix it with contact spray. Now comes the vinyl (no glue at all!), just bostitch around on backside and on front under the mouldings, first a few ones, finally all around when adjusted. The Door Panel is now ready for mount, not seeing the fixing clamps at all. Same nice job for the other panels. - SERGE - Edited by sermey 2011-03-27 12:26 PM (01 Right Door Panel Front View.jpg) (02 Right Door Panel Rear View.jpg) (03 Right Front Panel Ready.jpg) (04 Rear Side Panel Convertible.jpg) Attachments ---------------- 01 Right Door Panel Front View.jpg (39KB - 662 downloads) 02 Right Door Panel Rear View.jpg (60KB - 687 downloads) 03 Right Front Panel Ready.jpg (60KB - 706 downloads) 04 Rear Side Panel Convertible.jpg (141KB - 667 downloads) | ||
sermey |
At last, now I interchanged the door moulding and illustrate here how this is easy done when fixed as described earlier in http://www.forwardlook.net/forums/forums/thread-view.asp?tid=23691&start=51 , within a few minutes and no need of any special tools: This is fast servicing as is usual in todays cars. - SERGE - Edited by sermey 2012-05-25 11:19 AM (1 - Restored Moulding to be replaced.jpg) (2 - Push up and back.jpg) (3 - Push down and removal.jpg) (4 - Riveted Clamps.jpg) (5 - No Gaps at all.jpg) (6 - New Door Side Moulding.jpg) Attachments ---------------- 1 - Restored Moulding to be replaced.jpg (40KB - 616 downloads) 2 - Push up and back.jpg (56KB - 678 downloads) 3 - Push down and removal.jpg (62KB - 642 downloads) 4 - Riveted Clamps.jpg (46KB - 629 downloads) 5 - No Gaps at all.jpg (37KB - 614 downloads) 6 - New Door Side Moulding.jpg (66KB - 621 downloads) | ||
Board Moderator & Exner Expert 10K+ Posts: 13045 Location: Southern Sweden - Sturkö island | Hi Serge, nice to see your posts again! As always, very informative and sharing - with concern of our othere FL friends. Thanks for sharing! | ||
earleebob |
Elite Veteran Posts: 1120 Location: Brisbane, Australia | G'day Serge thanks for the email and the link. some very ingenious solutions for FL owners Cheers Bob | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Rear Power Windows Motor: The motor is just mounted on the removable panel with two screws. The big manual gear is turned so as to cover all the moving range of the windows lift. The position of the windows motor must be matched to the gear / theeth for the transmission. So, nearly any windows motor can be used. The wires goes under the sill plate. Easy for servicing or changing - and it works. - SERGE - - (1 - Rear Quarter Window Motor.jpg) (2 - Rear Quarter Window Motor Mounted.jpg) Attachments ---------------- 1 - Rear Quarter Window Motor.jpg (103KB - 606 downloads) 2 - Rear Quarter Window Motor Mounted.jpg (69KB - 642 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Dual Oval Exhaust Tips: Long time I had the feeling, my Dual Round Exhaust Tips, as described earlier here, are too small for this big car. Looking around I found Stainless Oval Tips AMG Style 350 x 85 x 58 mm, slanted. The lenght fits exactly up to the exhausts suspension. They can be mounted without seeing Now my Dodge looks more powerful and sporty - a low cost visual power boost! :) Edited by sermey 2012-05-28 2:32 AM (1 - Round Exhaust Tips.jpg) (2 - Oval Exhaust Tips Style AMG 350x85x58.jpg) (3 - Dual Unit Cut and Assembled.jpg) (4 - Unit Ready for Mounting.jpg) (5 - No Exhaust Tip.jpg) (6 - Insert Unit Vertically.jpg) (7 - Push-in and Turn to Horizontal.jpg) (8 - Adjust and Tighten 2 Screws.jpg) (9 - New Oval Exhaust Tips - Side View.jpg) (10 - New Oval Exhaust Tips - Rear View.jpg) Attachments ---------------- 1 - Round Exhaust Tips.jpg (90KB - 652 downloads) 2 - Oval Exhaust Tips Style AMG 350x85x58.jpg (65KB - 633 downloads) 3 - Dual Unit Cut and Assembled.jpg (133KB - 652 downloads) 4 - Unit Ready for Mounting.jpg (96KB - 623 downloads) 5 - No Exhaust Tip.jpg (46KB - 628 downloads) 6 - Insert Unit Vertically.jpg (59KB - 631 downloads) 7 - Push-in and Turn to Horizontal.jpg (63KB - 639 downloads) 8 - Adjust and Tighten 2 Screws.jpg (73KB - 613 downloads) 9 - New Oval Exhaust Tips - Side View.jpg (82KB - 634 downloads) 10 - New Oval Exhaust Tips - Rear View.jpg (81KB - 636 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Buzzer on Flasher: In addition to the earlier subject "Directional Flasher" in this thread here pictures of the final Flasher-Buzzer Unit as glued , connected and fixed with a clamp behind the radio (view from bottom). The buzzer is damped for lower alert with masking tape. Today I won't miss this option in my Convertible at all. - SERGE - Edited by sermey 2012-05-29 10:47 AM (1 - Flasher-Buzzer Unit - Various Views.jpg) (2 - Flasher-Buzzer Unit fixed on Clamp behind Radio - Bottom View.jpg) Attachments ---------------- 1 - Flasher-Buzzer Unit - Various Views.jpg (103KB - 651 downloads) 2 - Flasher-Buzzer Unit fixed on Clamp behind Radio - Bottom View.jpg (86KB - 650 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | sermey - 2012-05-29 4:37 PM Buzzer on Flasher: Explanatory comment This buzzer sounds intermittend with the directional light flashing. On the 1959 Dodge the indicator lamps on the instruments panel are hardly visible. Furthermore, the flasher unit doesn't sound enough to hear the directional light being flashing. Worst on the HighWay when entering at opened top. Then it happens that the flasher doesn't stop automatically and goes on flashing - can be dangerous for the driver as for others. PS: Pay attention to the correct polarity of the buzzer connection! Edited by sermey 2012-05-31 12:52 AM | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | sermey - 2012-05-30 10:34 PM sermey - 2012-05-29 4:37 PM Buzzer on Flasher: An earlier solution instead Many years ago I did another way to get the directional flasher more audible: Connect the output of the flasher directly to the radio loudspeaker, over a serial circuit of a capacitor and a resistor of more than 100 Ohm. Edited by sermey 2012-05-31 7:27 AM | ||
