"Make-Up" your Car! Jump to page : < 1 2 3 4 5 6 7 > Now viewing page 2 [50 messages per page] | View previous thread :: View next thread |
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Directional Flasher: It had happened to me some times, driving in my Topless Convertible to the Highway, and the activated Directional Flasher not turned off. Because of the bright Sunlight I neither could see the Green Flashing Lamps on the Instruments Panel, nor could hear the Flasher switching under the Dashboard due to the Streets Noise.
1. I connected a Miniature Buzzer (+12V) to the Input Port (red) and Output Port (blue) of the Directional Flasher. This Flasher Output leads to the Directional Switch on the Steering Wheel, and then to the corresponding Lamps, left or right. The Buzzer will sound anytime when the Flasher Switch is open and the Directional Switch ON, means in opposite Cycle as the Lamps. When an electronic Flasher Unit (not a bi-metal) in used, then connect the Buzzer to the Output Port of the Flasher (red) and to the Ground (blue). 2. The Buzzer can directly be attached to both Wires leading to the Directional Lamps too. Because it is a DC (Direct Current) Device, a Full Wave Rectifier (50V/200mA or higher)) must be pre-connected. It turns the Supply Voltage in any Direction to the correct Polarity. Even when there is one commun Bulb for Directional and Brake, as most Cars had at this time, the Buzzer will sound only when only one Side is ON. Thus when braking there is no Voltage across the two Wires of the ON Lamps, and of course no buzzing. The Loudness is adjusted acoustically by wrapping something around the Buzzer and / or by hiding it under the Dashboard. To know: the bi-metal Flasher is short-circuit at no Current. Now, the Buzzer produces a well-known intermitting alert, audible even in noisy ambient, no need to check the Instruments Panel, a relaxed Concentration on the Traffic. Edited by sermey 2009-01-17 2:00 AM (DSC02784L Rectifier & Buzzer.jpg) (DSC02785L Wiring Diagram.jpg) (DSC02747L Left Directional Light ON.jpg) Attachments ---------------- DSC02784L Rectifier & Buzzer.jpg (58KB - 707 downloads) DSC02785L Wiring Diagram.jpg (68KB - 691 downloads) DSC02747L Left Directional Light ON.jpg (63KB - 705 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Rear Center Brake Light: The new four glowing Rear Lamps instead originally two of them I still found insufficient for a Show-Effect, namely at Night. The next way was to add a Center Brake Light. The demands on this Feature, should: - match to the body in Size and Color as designed for - be easy to remove at anytime and at the place - not leave any Marks when taken off - show an intense Red Light in the same shade as the other Rear Lamps. Among many offered Kits I selected the best matching one.I lowered the Lamp Unit by removing the bottoms Body, attached two springy mounting Brackets in thin Stainless Steel inside connected to the Minus of the Bulbs, and then painted the Body in the Cars Color. The Lamp Unit is fixed by two Screws for the Tops Cover. The springy Pression of the Brackets hold it tight on the Cars Surface. Pushing by side the Center Chrome Coupling of the Mouldings there is access to the single wire leading to the Rear Brake Lamp, as Power Supply. To know: When there is a combined Lamp for Directional and Brake, as most Car had at this time, then the Supply should be branched directly to the Brake Light Switch. Now, all initial demands could be completed. This additional Feature is another attractive Eye-Catcher and improves the Cars Show-Effect by an exciting Red Glow when braking. Another item instantly removable to its Original! (my Digital Camera doesn’t like this high Contrast Bright Red!) Edited by sermey 2009-01-17 1:30 PM (DSC02803L Brake Light Unit Top View.jpg) (DSC02799L Brake Light Unit Rear View.jpg) (DSC02804L Brake Light Unit Ready for Mount.jpg) (DSC02794L Brake Light Unit Connected.jpg) (DSC02788 Brake Light Unit Mounted.jpg) (DSC02786L Center Brake Light ON.jpg) (DSC00001L Brake Lamps Side View.jpg) (DSC00007L Night Lights.jpg) Attachments ---------------- DSC02803L Brake Light Unit Top View.jpg (28KB - 665 downloads) DSC02799L Brake Light Unit Rear View.jpg (62KB - 715 downloads) DSC02804L Brake Light Unit Ready for Mount.jpg (38KB - 707 downloads) DSC02794L Brake Light Unit Connected.jpg (54KB - 689 downloads) DSC02788 Brake Light Unit Mounted.jpg (33KB - 714 downloads) DSC02786L Center Brake Light ON.jpg (45KB - 678 downloads) DSC00001L Brake Lamps Side View.jpg (79KB - 675 downloads) DSC00007L Night Lights.jpg (71KB - 677 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Tag Plate: On a nice Car the License Plate should be as nice, for most people look at this. The Expert however is interested in the Tag Plate. This Plate is as the Birth Certificate of the Car, an important integral Part and merits to be cared. What a Problem when this Plate is missing, I just read in another Thread! When restoring a Car, many paint over the Tag Plate. Made in Aluminum, a polishing gives an additional decorative Character. It can be anodized in any Colors as illustrated. This Golden would better match to another Paint. (the lower Shadow is the Hood Reflection). For a fix mount I used Aluminum Rivets instead of Screws, polished too. Small effort, nice Effect. Now, at the first glance the Expert will get an excellent Impression of the Car, the next Look at the Tag Plate he will be positively surprised!! Edited by sermey 2009-01-18 12:31 PM (DSC02817L Tag Plate.jpg) (DSC01376L Polished Tag Plate.jpg) (DSC01376L Anodized Tag Plate.jpg) Attachments ---------------- DSC02817L Tag Plate.jpg (48KB - 683 downloads) DSC01376L Polished Tag Plate.jpg (46KB - 683 downloads) DSC01376L Anodized Tag Plate.jpg (59KB - 667 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Hood Isolation: Many Hoods comes with poor or even with no Isolation at all. Knocking on the Hood is an acoustical Check how the Hood is isolated. Isolation means damping of Drumming due to Vibrations and Motor Noise, but will isolate from Heath too. I put an Isolation of a today Car, usually made in one piece, for they are heath resistant and attenuate the Noise considerably. To keep the Design of the Under Hood the Isolation is cut in Segments to fit in and then glue them on. Take your attention to the upper Rubber Strip. This prevents hot Air Circulation from the Engine Compartment turning back to the Cooler when the Car stands idling. (the white shadows are sunshine reflections of the Air Cleaner and others) Must see and hear the Difference! Edited by sermey 2009-01-21 10:46 AM (DSC00069L Hood Isolation.jpg) Attachments ---------------- DSC00069L Hood Isolation.jpg (109KB - 683 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Radiator Cap: Many small polished items enhance the Status of a Car. Here some visible Distinctions more. Just to see.
Edited by sermey 2009-01-21 4:02 PM (DSC00079L Polished Radiator &-Steering Pump Cap.jpg) Attachments ---------------- DSC00079L Polished Radiator &-Steering Pump Cap.jpg (86KB - 697 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Convertible Top: A white Top is nice for any Bodys Color – except for white. Because Top and Body in white never match exactly, one will always appear as dirty. Thus, I switched to a black Top, matching best to my black/white Interior. Due to the slanted Rear Back Seats I had to do minor Modifications on the Tops Mechanic. Simultaneously I lowered it for Top DOWN Position, to reduce the old fashioned “carriage” Look. By modifying the arms in shape, length and crops, the Mechanics went considerably lower, resulting only +1.5cm to the Height of the Body Sides with mounted Top (see earlier Pics of the Car too). As the Picture shows, now there is just enough room for the Top behind the slanted Rear Back Seats. Modified, complementary croped Arms for lowering the Mechanics are illustrated. The left and the right side Arms must have identical mirrored shape. To protect the Top, all Edges of the Main Arms are rounded (for the finish use abrasive paper at Top UP). Customized Stainless Screws and Nylon Bushings with borders (to put between the Arms) assure a frictionless, inaudible and smooth Operation, no needing oil lubrication. Another functional and visible improvement! To know: Important for lowest Top DOWN and minor Wrinkles is a carefully correct folding. This needs about 2 – 3 Steps. The Vinyl Window I left always closed at Top DOWN. Without Top and the Cylinders disconnected, the Mechanics should be moved easily up and down by hand. The Top DOWN Height then is lower than the Body Sides. Edited by sermey 2009-01-25 4:49 PM (DSC02856L Modified Top Screws and Bushings.jpg) (DSC02849L Modified Croped Arm.jpg) (DSC02936L Other Side Main Arm Crop.jpg) (DSC02851L Top Lifted.jpg) (DSC02825L Top DOWN Folded.jpg) (DSC02828L Top full DOWN in Side Panel.jpg) (DSC00082L Lowered Top Covered.jpg) (DSC00096L Top Up Back View.jpg) (DSC00094L Top UP.jpg) Attachments ---------------- DSC02856L Modified Top Screws and Bushings.jpg (63KB - 689 downloads) DSC02849L Modified Croped Arm.jpg (66KB - 635 downloads) DSC02936L Other Side Main Arm Crop.jpg (72KB - 635 downloads) DSC02851L Top Lifted.jpg (64KB - 668 downloads) DSC02825L Top DOWN Folded.jpg (89KB - 674 downloads) DSC02828L Top full DOWN in Side Panel.jpg (82KB - 666 downloads) DSC00082L Lowered Top Covered.jpg (54KB - 653 downloads) DSC00096L Top Up Back View.jpg (96KB - 675 downloads) DSC00094L Top UP.jpg (86KB - 671 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Fuse Box: When I switched from the Generator (30A) to an Alternator (60A) it was obvious to install two new Fuse Boxes. I went sick to search the hidden Fuses under the Dashboard for a replacement, not seeing anything. Then I changed the Wires to double Diameter. The new Fuse Boxes use Color encoded Fuses, easy to remove with the special Tool. I mounted them on the left front Wheelhouse for direct access, first both on a metal bar, then this unit with two longer screws from center to the body, as can see on the last Pic. All "fused" cables leading underneath invisible to the thick Wire Channel, then to the Instruments Panel. The transparent Covers with Rubber Seals make them water proof and allow an instant visual Check of the Fuses. The One-Wire Alternator allow a simple wiring: from the Alternator to the First Fuse Box, then leading the wire (yellow) through the Ampere Gauge in the Instruments Panel, then back (red) to the Second Fuse Box, and finally ending at the Battery (+). The First Box supplies all items needed to be measured, the second one the momentary High Current items directly from the Battery, not measured such as Starter, Power Windows, Convertible Top, needing Fuse Values up to 40A. The new Voltage Regulator is still there but not connected. Now, at a "Black-Out" by a defective Fuse: just lift the Hood, look at the Fuses and replace the defective one! Edited by sermey 2009-01-26 8:29 AM (DSC02890L One Wire Alternator.jpg) (DSC02967L Wiring Diagram.jpg) (DSC02963L Tool & Color Coded Fuses.jpg) (DSC02966L Rubber Sealed Fuse Box Covers.jpg) (DSC02959L Opened Fuse Boxes.jpg) Attachments ---------------- DSC02890L One Wire Alternator.jpg (82KB - 622 downloads) DSC02967L Wiring Diagram.jpg (49KB - 626 downloads) DSC02963L Tool & Color Coded Fuses.jpg (56KB - 672 downloads) DSC02966L Rubber Sealed Fuse Box Covers.jpg (61KB - 603 downloads) DSC02959L Opened Fuse Boxes.jpg (81KB - 648 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | 1959 Dodge HubCaps Paint: As the ConvertibleTop I got the HubCaps in white Color. White painted HubCaps are nice for any Bodys Color – except for white. Because HubCaps as the Convertible Top white never match exactly, one will always appear as dirty. Thus, I switched to black HubCaps, matching best to my black/white Interior. First I removed the old outworn Paint by a solvent. Then I polished all the HubCaps Surface for a new look. Masking around all the many squares and then spraying in black, there was no chance to get a satisfactory result. I had to find another solution, already mentioned in an earlier post. I made Steel Stamping Tools for the two Square Sizes and stamped manually Stickers from professional, all weather-proof adhesive Material, as used for long lasting Outdoor Promotion on Cars. The same I did with the Center of the Spinners. Now, the “new paint” has all around sharply defined Edges as never feasible with Paint, the Squares are identical, and they can be washed free of damage. At a Glance, the HubCaps look as new and never used, another nice Upgrade of every 1959 Dodge. :) To know: Just now I got a limited Quantity of Precision Laser-Cut Stickers and offer them at first to FWL-Members. A Set, in White or in Black, fitting four HubCaps (314 Square + 6 Knight Stickers, Application), covering costs ($30.00 + $10 Package & Shipment, PayPal sermey@bluewin.ch). Edited by sermey 2009-01-28 12:29 PM (DSC00058L Old Outworn Paint.jpg) (DSC02977L Stamping Tools.jpg) (DSC02970L CAD Design A4.jpg) (DSC00025L White Center Sticker.jpg) (DSC01930L Black Stickers.jpg) (DSC02972L Black Center Sticker.jpg) (DSC02975L All Stickers on HubCap.jpg) Attachments ---------------- DSC00058L Old Outworn Paint.jpg (65KB - 626 downloads) DSC02977L Stamping Tools.jpg (58KB - 613 downloads) DSC02970L CAD Design A4.jpg (84KB - 630 downloads) DSC00025L White Center Sticker.jpg (103KB - 612 downloads) DSC01930L Black Stickers.jpg (80KB - 653 downloads) DSC02972L Black Center Sticker.jpg (90KB - 587 downloads) DSC02975L All Stickers on HubCap.jpg (76KB - 639 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Automatic Beam-Changer: This Option was not on my Car when purchased. One day I found solely the Original Sensor Module, and I thought: “Why not?” I designed a Transistor Trigger Circuit, soldered on a Board and mount under the Dashboard for direct access. A Printed Circuit Board (PCB) would have a quarter of Size. To eliminate the often discussed Flashing in Operate Mode, I set a higher Hysteresis (= Difference between ON – OFF Transition) and a longer ON Time-Constant (10 millisec for Beam OFF, +2 sec for Beam ON), as a manual Switching. The preset of the Sensitivity is done by the Trimmer on the Circuit Board (not visible), directing in the Garage a Pocket Lamp to the Beamer Unit to simulate the Light of an oncoming Car. The fine Adjustment when driving by turning the rear Knob on the Sensor Unit. Now, the Automatic Headlight Control works excellently, but still remains critical in some Light Conditions due to the limited Viewing Angle of the Photo-Cell. Another Optional Equipment, not necessarily needed, but always nice to have. :) To know: the Automatic Inside Mirror - MirrorMatic uses the same basic circuit, both use the same Vacuum Tube 12k5. A PCB Transistor Circuit would fit in this Housing, or the Tube could simply be substituted by adequate Transistors, directly plug in the Tube Socket (12V Operation). Edited by sermey 2009-01-29 9:51 AM (1 Ross Roy - Automatic Beam-Changer L.jpg) (2 DSC03002L Transistor Circuit & Relais.jpg) (3 DSC02982L Beamer Unit .jpg) (4 DSC03000L Beamer OverView.jpg) Attachments ---------------- 1 Ross Roy - Automatic Beam-Changer L.jpg (54KB - 654 downloads) 2 DSC03002L Transistor Circuit & Relais.jpg (89KB - 629 downloads) 3 DSC02982L Beamer Unit .jpg (47KB - 652 downloads) 4 DSC03000L Beamer OverView.jpg (81KB - 669 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Dimmer Switch: Even when not directly visible, this Switch can easy be upgraded just by putting a Rubber Cap (not Plastic, Bore Dia. 22mm x 20), as used for Chairs. Now, the covered Knob not only looks more discreet and similar to the Windshield Washer Pad, applying the Dimmer Switch feels much more comfortable. Comparing both Pictures it even seems, without the Rubber Cap something is missing. A quite simply improvement for any Oldtimer! Edited by sermey 2009-01-31 4:39 AM (DSC03036L Rubber Cap.jpg) (DSC03051L Original Dimmer Switch.jpg) (DSC03050L Dimmer Switch with Rubber Cap.jpg) Attachments ---------------- DSC03036L Rubber Cap.jpg (39KB - 631 downloads) DSC03051L Original Dimmer Switch.jpg (67KB - 662 downloads) DSC03050L Dimmer Switch with Rubber Cap.jpg (67KB - 656 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Sun Visors: On a Convertible the Sun Visors have an additional Function. In slightly higher than in horizontal Position they can reduce the Turbulences at open Top, acting as a virtual Extension of the Windshield. Then they are additionally exposed to a displacement. To tighten a hanging Sun Visor, pull it out (may need some force), put in a parallel vice between two plane planks, protect it as illustrated, then squeeze a little bit in several steps until fixed enough. Now, the Sun Visors remain in any circumstances at the preset Position. Edited by sermey 2009-01-31 3:04 PM (DSC03074L Removed Sun Visor.jpg) (DSC03069L Retense The Sun Visor.jpg) (DSC03068L Sun Visor Up.jpg) Attachments ---------------- DSC03074L Removed Sun Visor.jpg (49KB - 633 downloads) DSC03069L Retense The Sun Visor.jpg (71KB - 636 downloads) DSC03068L Sun Visor Up.jpg (78KB - 628 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | 15” Wheels and Tires: I always found, 14” Wheels on my Car are relatively too small and look poor in Proportion to the Body and its Wheelhouse. Must say, this was the Style at this time. The other Point, bigger and wider Tires have much better Adhesion on the Street, the 235/70/15 Radial Tires about +25% in Comparison to the Original 14” Diagonal ones. This improvement is necessarily needed for a full Advantage of Disk Brakes. Thus, I decided in favor of 15” Wheels and the corresponding WWW Tires, still keeping the Original 14” Wheel Set including the Spinner Hubcaps. In order to keep the Original Appearance, the Original HubCaps should fit to the 15” Rims. I bought 15” decorative stainless Rings, cut out the Border around, and soldered it inside the Wheel Cover. For a stronger Fixing on the rechromed Wheels I increased the Clamp Pression by putting a soft round PVC Profile under the Clamps. Now, the Hubcaps fit perfectly to the 15” Rims, their Edges are even protected from Curbstones due to the inner Position, and the Air Valve is perfectly centered as well. According my personal feeling, this Wheel Size gives the Car its settled Proportions. Another improvement of the Outfit, for the Drivers Security, and as an additional Benefit the Wheel Cover Edge Protection. (can see, my HubCaps are not perfect, but polished and with the sticked Black they look as) Edited by sermey 2009-02-01 12:24 PM (Original Wheel and Parking Lamp.jpg) (1 DSC00001L Coker Tires 235-70-15.jpg) (2 DSC03078L 15 Inch Decorative Stainless Rings.jpg) (3 DSC00051L Soldered 15 Inch Ring.jpg) (4 DSC03081L Inner Border of HubCap.jpg) (5 DSCN0012L 15 Inch Wheel Assembled.jpg) Attachments ---------------- Original Wheel and Parking Lamp.jpg (73KB - 651 downloads) 1 DSC00001L Coker Tires 235-70-15.jpg (101KB - 643 downloads) 2 DSC03078L 15 Inch Decorative Stainless Rings.jpg (67KB - 621 downloads) 3 DSC00051L Soldered 15 Inch Ring.jpg (68KB - 592 downloads) 4 DSC03081L Inner Border of HubCap.jpg (89KB - 619 downloads) 5 DSCN0012L 15 Inch Wheel Assembled.jpg (97KB - 618 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | obsolete Edited by sermey 2009-12-04 5:07 PM | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Dome Nuts and Caps: These devices remove optically bad nuts, covers them or even protect them. Dome Nuts in polished stainless steel may appear as small diamonds. A low-cost "Jewel+ for your car! - SERGE - :laugh: (01 Dome Nuts - Caps DSC03156.jpg) (02 DomeCap DSC03154.jpg) (03 DomeNuts Connector DSC00632a.jpg) (04 DomeNuts Induction Coil.jpg) Attachments ---------------- 01 Dome Nuts - Caps DSC03156.jpg (48KB - 630 downloads) 02 DomeCap DSC03154.jpg (53KB - 628 downloads) 03 DomeNuts Connector DSC00632a.jpg (55KB - 611 downloads) 04 DomeNuts Induction Coil.jpg (79KB - 600 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Plugged Instruments and Speedometer Units: Working on this Units, what ever the brand of the car, was always a mess for not scratching the painted surrounding, interrupt unintentionally a connection, produce accidentally a short-circuit (when battery unplugged) and even to fix them when working. On newer cars the Units can be removed by unplugging many cables. On our FL-cars, except for the lamps, most cables are fixed.
Edited by sermey 2009-12-06 11:00 AM (2009-04-23 DSC03212 Speedometer Unit.jpg) (2009-04-23 DSC03206 Front Instruments Panel.jpg) (2009-04-23 DSC03205 Rear Instruments Panel.jpg) (2009-04-23 DSC03204 View Under Dashboard.jpg) Attachments ---------------- 2009-04-23 DSC03212 Speedometer Unit.jpg (58KB - 584 downloads) 2009-04-23 DSC03206 Front Instruments Panel.jpg (82KB - 596 downloads) 2009-04-23 DSC03205 Rear Instruments Panel.jpg (88KB - 610 downloads) 2009-04-23 DSC03204 View Under Dashboard.jpg (129KB - 616 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Rechromed Substitute Parts: On the market there are many rechromed parts available as substitutes, additional eye-catchers. Here two samples. The Generator Bracket. Fits directly. For a nicer look can be shortened for best match, as I did here. The Oil DipStick with the Tube. I bent the tube according the position I liked. Then, unfortunately the Oil DipStick couldn't be inserted anymore in the tube. Easy trick: Just twist it! :laugh: - SERGE - (Rechromed Generator Braket LL.jpg) (Rechromed Distributor HoldDown LL.jpg) (Rechromed Oil DipStick LL.jpg) (Rechromed Oil DipStick Twisted LL.jpg) (Rechromed DipStick in Tube LL.jpg) Attachments ---------------- Rechromed Generator Braket LL.jpg (92KB - 605 downloads) Rechromed Distributor HoldDown LL.jpg (75KB - 614 downloads) Rechromed Oil DipStick LL.jpg (64KB - 593 downloads) Rechromed Oil DipStick Twisted LL.jpg (40KB - 609 downloads) Rechromed DipStick in Tube LL.jpg (97KB - 581 downloads) | ||
1959 Belvedere Conv |
Elite Veteran Posts: 1107 Location: Arvada, Colorado (NW Denver Metro Area) | Serge, You have a beautiful well detailed car. You should go back in time an be a stylist for Chrysler back in the Forward Look days. Though my 59 Plymouth convert is not at your higher trim level, I will use a lot of the detail points to bring out the best in my instrument panel. PS I have never seen here in the States Dupli-color in the RAL color system. I am in the electrical business now (20 years )and we use the RAL paint system for coloring large electrical enclosures. I will have to see if they market these RAL colors in the US of A. It would help me a lot in getting touch up paint. | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | 1959 Belvedere Conv - 2010-02-14 2:49 AM Serge, You have a beautiful well detailed car. You should go back in time an be a stylist for Chrysler back in the Forward Look days. Though my 59 Plymouth convert is not at your higher trim level, I will use a lot of the detail points to bring out the best in my instrument panel. PS I have never seen here in the States Dupli-color in the RAL color system. I am in the electrical business now (20 years )and we use the RAL paint system for coloring large electrical enclosures. I will have to see if they market these RAL colors in the US of A. It would help me a lot in getting touch up paint. Thank you, John. Every one has his own talents. We all have got them for free. The ones uses them more, the others less. I think, most owner of an oldtimer will find and trim his car to a higher level, as soon he has done all needed restorations. Owning just one car is much easier. The RAL Colors are well defined Color Standards and available on a CD, indicating the RGB (Red-Green-Blue) percents, awell known by Photoshop-Users. Thus, any RAL Color can be mixed accordingly, and get exactly the same tone. Edited by sermey 2010-02-15 10:49 AM | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Oil Cap on Valve Cover: This is another part that can be directly replaced by a similar rechromed one, also available on the market. Here I preferred to keep the Original Cap of the 1959 DODGE with the script "OIL" on top. Bevor rechroming, the steel filter preventing oil to leak on the valve cover, has to be removed. It can be replaced by a rough stainless steel wool, as used for cleaning pans, inserted with a long-nosed plier. A fine steel Wool would clog when oily and prevent the needed air breathing. Valve Cover: There are as well rechromed valve covers available, What you see are the rechromed originals. To rechrome with polishing costs more than than a replacement. - SERGE - Edited by sermey 2010-02-15 1:14 PM (1959 Original Rechromed Oil Cap LL.jpg) (Oil Cap Stainless Steel Wool LL.jpg) (361 Oil Cap on Valve Cover LL.jpg) Attachments ---------------- 1959 Original Rechromed Oil Cap LL.jpg (55KB - 711 downloads) Oil Cap Stainless Steel Wool LL.jpg (66KB - 742 downloads) 361 Oil Cap on Valve Cover LL.jpg (126KB - 746 downloads) | ||
1959Dodge |
Expert Posts: 2244 Location: Yorba Linda, Ca | Nice job on the car "Make up". Maybe when you are done, we can switch cars for a while and you can do mine. Or you could come out here, weather is great today, probably be close to 30C so come here, I give ya free room and board, while you update the makeup on ny car!!! Gary | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | 1959 Belvedere Conv - 2010-02-14 2:49 AM Serge, You have a beautiful well detailed car. You should go back in time an be a stylist for Chrysler back in the Forward Look days. John, I have done some small stylist modifications, Virgil Exner would even be happy about - but not the purists. | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | 1959Dodge - 2010-02-15 7:22 PM Nice job on the car "Make up". Maybe when you are done . . . Sorry, Gary, it is never done. The show goes on! A never ending process. - SERGE - | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | sermey - 2010-02-15 4:39 PM Here I preferred to keep the Original Cap of the 1959 DODGE with the script "OIL" on top. Bevor rechroming, the steel filter preventing oil to leak on the valve cover, has to be removed. It can be replaced by a rough stainless steel wool, as used for cleaning pans, inserted with a long-nosed plier. A fine steel Wool would clog when oily and prevent the needed air breathing. - SERGE - I used exactly the same material and method with Oil Cap - mine is painted black though. | ||
Windsor59 |
Expert Posts: 2596 Location: Upplands Väsby, Sweden | wizard - 2010-02-17 12:00 PM sermey - 2010-02-15 4:39 PM Here I preferred to keep the Original Cap of the 1959 DODGE with the script "OIL" on top. Bevor rechroming, the steel filter preventing oil to leak on the valve cover, has to be removed. It can be replaced by a rough stainless steel wool, as used for cleaning pans, inserted with a long-nosed plier. A fine steel Wool would clog when oily and prevent the needed air breathing. - SERGE - I used exactly the same material and method with Oil Cap - mine is painted black though. OK! thanks for this tips: It can be replaced by a rough stainless steel wool, as used for cleaning pans, inserted with a long-nosed plier I must changes the stainless steel wool in my oil cap. | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Constant Voltage Regulator: This is a thermo-mechanical contact breaker, and cannot be repaired (metallic sealed). It's output is a pulsing 12V, resulting in an average output of 5Volt. This voltage can only be measured with a long-time integrating instrument. A connected 12V instruments bulb will flash correspondingly. The regulator is used to operate both, the fuel level and the temperature gauges. The readings for two Input Voltages of 9 and 18 Volt, and the water temperature gauge loaded for "normal" reading (sensor simulation R = 22 Ohm, see Pic) have been tested. The output of the device shows a constant value of 4.90 Volt. The original voltage regulator can be left there as is, but unconnected, or it can be removed as shown. On the illustrations the device is not connected (demo on a spare instruments panel), best should be soldered. Another invisible new technology for a better performance and a higher reliability of your car. - SERGE - :laugh: To know: I have purchased some additional devices for interested FWLs and can offer them at cost price: USD 5.00/piece plus shipment by letter (PAYPAL sermey@bluewin.ch). Edited by sermey 2010-02-24 1:48 PM (1 - Dodge59 Constant Voltage Regulator LL.jpg) (2 - Electronic Regulator Pin Connection LL.jpg) (3 - Reading at 9 Volt Input LL.jpg) (4 - Reading at 18 Volt Input LL.jpg) (5- Both 5 Volt Regulators Mounted LL.jpg) (6 - Only Electronic 5 Volt Regulator Mounted LL.jpg) Attachments ---------------- 1 - Dodge59 Constant Voltage Regulator LL.jpg (92KB - 634 downloads) 2 - Electronic Regulator Pin Connection LL.jpg (64KB - 679 downloads) 3 - Reading at 9 Volt Input LL.jpg (81KB - 665 downloads) 4 - Reading at 18 Volt Input LL.jpg (90KB - 704 downloads) 5- Both 5 Volt Regulators Mounted LL.jpg (80KB - 637 downloads) 6 - Only Electronic 5 Volt Regulator Mounted LL.jpg (93KB - 649 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Remote Hood Lock: Most cars at this era didn't had this option. Everyone could open the hood from front, the ones for curiousity, the others just for steal the battery as experienced many years ago. Thus, I had not a good feeling with an "open" hood on my Dodge. I found a "HOOD" remote cable (must be from a 1960 Mopar?), purchased later a NOS hood lock on eBay, and now it is mounted. The hood lock arm had to be cut and bent upward for a functional operation, and for preventing from manual open. Then the end of the arm got a thread (M5) with a groove for easy connecting and the fine adjustment of the cable length. The remote hood lock handle is mounted on the drivers left side, under the dashboard. Now, the battery (and the oval air filters!) are safe, and not anymore opened hood by curious people. - SERGE - Edited by sermey 2010-02-25 4:28 PM (1 - Hood Lock - Arm Cut LL.jpg) (2 - Prepared Lock Arm LL.jpg) (3 - Remote Cabel End LL.jpg) (4 - Control Cabel Connection LL.jpg) (5 - Connected Remote Control LL.jpg) (6 - Remote Hood Lock Handle LL.jpg) Attachments ---------------- 1 - Hood Lock - Arm Cut LL.jpg (60KB - 668 downloads) 2 - Prepared Lock Arm LL.jpg (59KB - 662 downloads) 3 - Remote Cabel End LL.jpg (43KB - 654 downloads) 4 - Control Cabel Connection LL.jpg (75KB - 681 downloads) 5 - Connected Remote Control LL.jpg (85KB - 671 downloads) 6 - Remote Hood Lock Handle LL.jpg (75KB - 675 downloads) | ||
DeSotohead |
Board Moderator Posts: 3186 Location: The not-so-great, dirty-white North ( Michigan) | sermey - 2010-02-24 11:07 AM Constant Voltage Regulator: This is a thermo-mechanical contact breaker, and cannot be repaired (metallic sealed). It's output is a pulsing 12V, resulting in an average output of 5Volt. This voltage can only be measured with a long-time integrating instrument. A connected 12V instruments bulb will flash correspondingly. The regulator is used to operate both, the fuel level and the temperature gauges. The readings for two Input Voltages of 9 and 18 Volt, and the water temperature gauge loaded for "normal" reading (sensor simulation R = 22 Ohm, see Pic) have been tested. The output of the device shows a constant value of 4.90 Volt. The original voltage regulator can be left there as is, but unconnected, or it can be removed as shown. On the illustrations the device is not connected (demo on a spare instruments panel), best should be soldered. Another invisible new technology for a better performance and a higher reliability of your car. - SERGE - :laugh: To know: I have purchased some additional devices for interested FWLs and can offer them at cost price: USD 5.00/piece plus shipment by letter (PAYPAL sermey@bluewin.ch). Serge..... If you really want to make it look "original", you can mount the 5V regulator on a PC board inside the old regulator housing. That is what I have done with the Lucas equivalent on my Lotus Europa........ | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | DeSotohead: ..... If you really want to make it look "original", you can mount the 5V regulator on a PC board inside the old regulator housing. This is a good idea, Hank. Then the integrated circuit can directly be soldered inside on the existing pins. It will need a screw for the heat sink, and on the Dodge, the metallic housing of the regulator is bent all around and must be opened (?). I don't know if the other Mopars use the same regulator. Edited by sermey 2010-02-25 10:31 AM | ||
DeSotohead |
Board Moderator Posts: 3186 Location: The not-so-great, dirty-white North ( Michigan) | Here is how its done for the Europas..... (5vregulator.gif) Attachments ---------------- 5vregulator.gif (57KB - 661 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | This is the same Mopar Regulator. But this one has only two bent edges. The one in my car (see above Pic 5) is bent all around. The electronic regulator is a similar one, may-be an earlier product. There are many available, from various manufacturers and for different applications. The one I selected is best for our application and, according the datasheet, doesn't need any components at all (internally compensated), and cannot be destroyed (temperature and current protected). This security is a big advantage, thinking the regulator is located behind the instruments panel and not directly accessible. Not needed, but the output accuracy in respect to the input range as tested is impressive (4.90V). Too precise for cars of the fifties! Edited by sermey 2010-02-25 11:18 AM | ||
DeSotohead |
Board Moderator Posts: 3186 Location: The not-so-great, dirty-white North ( Michigan) | THe actual 5V regulator is really not an issue. As you point out, several companies make them, including the infamous adjustible "LM317" regulator from National. As for your housing, I think it is quite possible to bend the four corners up and away. You might try heating the metal with a small butane torch as you pry, or use a large tip on a soldering iron. Once removed, you can finish the bent up taba with a small hammer and a piece of steel as a backer to straighten the metal. Recrimping can be done with a small anvil vise. | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Fixing the Spinner Hubcaps: I guess these 1959 hubcaps may be the heaviest ones among the FWL- cars. As the spinners are just mounted on the wheel covers and remain unbalanced, an asymmetric radial force is being applied on the rims when driving. The pression to the rims is increased on the one side, and reduced correspondingly on the opposite side. This causes the spinner hubcaps to move slightly outwards on the reduced force side. Mechanical shocks on bad streets to the critical diameter accelerates this process. The front wheels, especially the right side one (for right. hand traffic), are more exposed then the rear ones. I have observed on some hubcaps an outward displacement up to 1mm after a trip of about 500km. Therefore the fit of the hubcaps have to be checked at regular intervals. Once it happens me to loose the front right spinner hubcap on the original rims. Fortunately I noticed this on the spot and could retrieve it. After that, on longer trips to car meetings, I safety removed the hubcaps. This caused to miss a winner "best of show", forgetting to put on the hubcaps, laying behind the front seats. Not only, but for best presentation this car needs the original hubcaps. It even happened by an oversight to take pictures without hubcaps. Now I had to find a solution! Diametral in the 15" chrome-wheels I removed two diametric nuts (the nuts are just dummies as design) and put an M5 inserting-nut instead (as described earlier). The position has to match the air-valve! Then I bent a profile in aluminium as fixing latch, with an M4 inserting-nut (here in aluminium black anodized) on one end. For each hubcap two latches are needed. The fine adjustment to the hubcaps is done by rotating and manually bending them on the wheel. The hubcaps need two holes (4 mm) in the groove, not drilled, just by applying multiple times the center puncher in order to keep the border for the countersink screws M4. This two stainless screws are hardly visible, on the picture time position 04.50. I still have some reserve wheel covers for keeping the originality, if one day it should be required. Now, my 1959 Dodge Convertible will always be fitted with the nice spinner hubcaps, without any stress of loosing them or even being "removed" (get stolen). - SERGE - Edited by sermey 2010-02-27 12:50 PM (1 - Inserted Nut LL.jpg) (2 - Fixing Latches LL.jpg) (3 - Latch Mount LL.jpg) (4 - Mounted Latches LL.jpg) (5 - Countersink Screw LL.jpg) (6 - Fixed Spinner Hubcap LL.jpg) Attachments ---------------- 1 - Inserted Nut LL.jpg (90KB - 616 downloads) 2 - Fixing Latches LL.jpg (65KB - 635 downloads) 3 - Latch Mount LL.jpg (73KB - 674 downloads) 4 - Mounted Latches LL.jpg (109KB - 651 downloads) 5 - Countersink Screw LL.jpg (65KB - 673 downloads) 6 - Fixed Spinner Hubcap LL.jpg (124KB - 641 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Fuel Gas Tank Cap: On most FWL-Cars the Fuel Gas Tank Cap is not visible from outside, on many Sports Cars it is part of the design and lettered accordingly (GT, SS). On a nice car, this device should as well correspond to the car, to its design and to the prefences of the owner. On the market there are various caps available, with and without locks. The pictures show a selection offered in eBay. For my car the Fuel Gas Tank Cap should have the properties as: 1. Vented type, preventing pressions in the tank. 2. With lock, protecting the acces to others. 3. Covered lock, to keep it free from dirt. 4. The ability to fix it without key. 5. A nice rechromed design, matched to the car. Now, when tank up, the nice Fuel Gas Tank Cap underscores the exclusivity of the car. - SERGE - Edited by sermey 2010-03-22 6:38 AM (1 - Various Gas Tank Caps LL.jpg) (2 - Various Locking Gas Tank Cap LL.jpg) (3 - Dodge Fuel Gas Tank Cap LL.jpg) (4 - Dodge Fuel Cap Fixed LL.jpg) (5 - Dodge Fuel Cap with Keys LL.jpg) Attachments ---------------- 1 - Various Gas Tank Caps LL.jpg (115KB - 633 downloads) 2 - Various Locking Gas Tank Cap LL.jpg (99KB - 614 downloads) 3 - Dodge Fuel Gas Tank Cap LL.jpg (53KB - 669 downloads) 4 - Dodge Fuel Cap Fixed LL.jpg (53KB - 648 downloads) 5 - Dodge Fuel Cap with Keys LL.jpg (83KB - 625 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Trunk Lamp: Older cars have usually one trunk lamp, positioned in the center of the trunk, near the lock. The switch is in the bulb socket, activated at a given angle or inclination. For a big trunk like on FWL-cars, this illumination can be insufficient at the left and right end, especially when the trunk is dark carpeted. Additional lamps could be useful. I found Lamp Units with integrated switch, for individually On or Off. As separate switch, the same system is used as in the doors for the dome lamps. This switch is mounted by a bracket behind the trunk hinge (left side) the way, that at closed trunk the lamps goes off. Two lamp units are fixed, left and right, not visible on top in the upper corner. The needed electrical supply is already there. Another discreet adds-on. At night the opened trunk appear wider and more generous, as the car already is. - SERGE - Edited by sermey 2010-03-26 6:35 PM (1 - Trunk Light LL.jpg) (2 - Trunk Lamp Units LL.jpg) (3 - Trunk Light Switch LL.jpg) (4 - Mounted Lamp Unit LL.jpg) (5 - Trunk Lamp Unit Left Side View LL.jpg) Attachments ---------------- 1 - Trunk Light LL.jpg (51KB - 657 downloads) 2 - Trunk Lamp Units LL.jpg (65KB - 623 downloads) 3 - Trunk Light Switch LL.jpg (67KB - 659 downloads) 4 - Mounted Lamp Unit LL.jpg (80KB - 645 downloads) 5 - Trunk Lamp Unit Left Side View LL.jpg (81KB - 640 downloads) | ||
Elite Veteran Posts: 1107 Location: Arvada, Colorado (NW Denver Metro Area) | Serge, in picure 6 of the constant voltage regulator thread, there is a small blue electronic device with stripes used, is that a diode or capacitor you installed? and why? thanks! | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | 1959 Belvedere Conv - 2010-03-27 1:45 AM Serge, in picure 6 of the constant voltage regulator thread, there is a small blue electronic device with stripes used, is that a diode or capacitor you installed? and why? thanks! John, this is the 22 Ohm resistor (0.3W), simulating the missing temperature sensor. With this value, corresponding to the warm-up engine, the temp gauge shows 60% reading, visible from the other side.This voltage regulator requires no additional electronic device at all. What you see is the rear of a "reserve" instruments panel 1959 Dodge. - SERGE - Edited by sermey 2010-03-27 2:40 AM | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Water Temperature Gauge Sender: Technical aspects about this device have already been discussed on another thread: "Defective Water Temperature Sensor" http://www.forwardlook.net/forums/forums/thread-view.asp?tid=29524&posts=15&start=1 Now, one more "brillant" on this car! - SERGE - Edited by sermey 2010-03-28 6:29 AM (1 - Temperature Gauge Sender LL.jpg) (2 - Thread M3 on Sensor LL.jpg) (3 - Dome Cap M3 on Connected Sensor LL.jpg) Attachments ---------------- 1 - Temperature Gauge Sender LL.jpg (51KB - 634 downloads) 2 - Thread M3 on Sensor LL.jpg (102KB - 627 downloads) 3 - Dome Cap M3 on Connected Sensor LL.jpg (101KB - 633 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Black Painted Items: Many items on my car are black painted. Not the style of anyone, but to me for practcal reasons. When clean, it looks nice, can be partly repainted anytime without perceiving it, is neutral and gives a classic outfit. Finally: black is black, no problems with various tones as a white color. This is my personal view. Here how I do it, easy and nice: First brush the surface to remove old paint or rust. Then clean it with nitro-dilution or fuel, using a towel or washing the item with a paint-brush, to be absolute free of oil. The best paint I found and use for years is a spray, mat and includes rust-protection. It has a structure as silver paint and dries within a half hour. When the items are not directly exposed to water or rain, this paint can be applied directly on iron (or other material). For hot engine parts there is the similar "high temperature" spray. Inside the car or in corners, the surrounding can be masked with newspapers or a plastic foil, the hidden corners coloured with a paint-brush, using this paint previously sprayed in a can. As sample I used a rusty metal bar, here (highly zoomed) only brushed, not grinded or sanded. On the last picture, the black painted front of the engine (over 10 years old). The black paint is slightly shiny as silk, what gives an animated look. - SERGE - See as well the brushed and black painted Hood-Lock in an upper post. Edited by sermey 2010-04-03 11:20 AM (1 - Black Spray LL.jpg) (2 - Rusty Metal LL.jpg) (3 - Brushing LL.jpg) (4 - Metal Black Sprayed LL.jpg) (5 - Black Paint on Front LL.jpg) Attachments ---------------- 1 - Black Spray LL.jpg (100KB - 656 downloads) 2 - Rusty Metal LL.jpg (68KB - 670 downloads) 3 - Brushing LL.jpg (69KB - 658 downloads) 4 - Metal Black Sprayed LL.jpg (69KB - 657 downloads) 5 - Black Paint on Front LL.jpg (115KB - 647 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Aligning the Front Bumper: We all know, the precision on those cars was not high as on cars of today. This becomes apparent on mounted doors, hoods and trunk lids, but as well on bumpers. The front bumper of the 1959 Dodge is especially critical due to its side design - any mis-alignment to the fender is visible. When mounted as it is from original, most are hanging down. Some nice cars as illustrated (1) (pics from thread Vasteras) look as the front bumper will get lost at any instance. This was as well on my car. Correcting this by an asymmetric support would move the bumper more forward. But the bumper should even be more back to fit as well to the border of the fender. To move it more back, the mounting arms have to be shortened. Due to an angle of about 45deg the arms have in respect to the bumper, the mounting holes would not fit anymore by just cutting them. They have to be welded overlapped as shown (2). The adjustment in forward position then is easy achieved by inserting washers (3). The hanging side to come up can be corrected by grinding the bracket correspondingly. Recently I improved this alignment by slightly untight the bolts, pushing the bumper on the side up to maximum, using the car lifter. Then fixing (just hanging) the bumper up, with two adjustable aluminium angle brackets (3) on each side (4). When aligned and fixed in the correct position, finally tighten all bumper bolts (on Pic 4 you see as well how the Lancer Emblem is fixed, this way already posted earlier). Now, the front bumper is there where it should be, as it was initially designed. - SERGE - Edited by sermey 2010-04-24 1:08 PM (1 - Hanging Front Bumpers LL.jpg) (2 - Bumper Arm Welding LL.jpg) (3 - Forward Adjustment LL.jpg) (4 - Adjustable Angle Brackets LL.jpg) (5 - Front Bumper Fixed in Top Position LL.jpg) (6 - Aligned Front Bumper LL.jpg) Attachments ---------------- 1 - Hanging Front Bumpers LL.jpg (116KB - 646 downloads) 2 - Bumper Arm Welding LL.jpg (72KB - 665 downloads) 3 - Forward Adjustment LL.jpg (70KB - 635 downloads) 4 - Adjustable Angle Brackets LL.jpg (68KB - 686 downloads) 5 - Front Bumper Fixed in Top Position LL.jpg (86KB - 660 downloads) 6 - Aligned Front Bumper LL.jpg (76KB - 651 downloads) | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | Way to go Serge! You have cured the "American Car disese"! Next to all US cars (exeption from the master renovated ones) has a misaligned bumper. This is indeed a very noticable difference. | ||
59CRL |
Expert Posts: 2679 | I see you have a 22 ohm resistor hooked up there, (red, red, blk) I bet for testing purposes, very good. I replaced my old CVR with a 5 volt 7805 today and a NOS gauge. I let the car idle for 30 minutes and the gauge reads 1/3rd, not bad at all. Tomorrow I will take her out for a ride and see where the gauge reads. Too much rain today. Thanks Sermey for the research and pics. | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | 59CRL - 2010-05-02 1:25 AM I see you have a 22 ohm resistor hooked up there, (red, red, blk) I bet for testing purposes, very good. I replaced my old CVR with a 5 volt 7805 today and a NOS gauge. I let the car idle for 30 minutes and the gauge reads 1/3rd, not bad at all. Tomorrow I will take her out for a ride and see where the gauge reads. Too much rain today. Thanks Sermey for the research and pics. Correct, the 22Ohm Resistor substitutes the sensor. This was technically discussed in the thread: "Defective Water Temperature Sensor" http://www.forwardlook.net/forums/forums/thread-view.asp?tid=29524&posts=22&start=1 | ||
59CRL |
Expert Posts: 2679 | sermey - 2010-05-01 7:52 PM 59CRL - 2010-05-02 1:25 AM I see you have a 22 ohm resistor hooked up there, (red, red, blk) I bet for testing purposes, very good. I replaced my old CVR with a 5 volt 7805 today and a NOS gauge. I let the car idle for 30 minutes and the gauge reads 1/3rd, not bad at all. Tomorrow I will take her out for a ride and see where the gauge reads. Too much rain today. Thanks Sermey for the research and pics. Correct, the 22Ohm Resistor substitutes the sensor. This was technically discussed in the thread: "Defective Water Temperature Sensor" http://www.forwardlook.net/forums/forums/thread-view.asp?tid=29524&posts=22&start=1 Bringing this thread back for an update. Sitting at idle with my 7805 voltage regulator I get 1/3rd on the temp gauge. Driving down the highway at temperatures of 95-100 degrees the gauge will read the same. Sitting in 100 degree heat with the engine idling the gauge will creep upto 3/4. Not bad at all. | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Emergency Car Cover: Imagine, you are on the road with your Convertible. It starts raining. You attempt to put up your top. But unfortunately it won't. May-be due to electrical problems, a defective pump, or it just clamps. In order to prevent your precious interior and the dash instruments to go wet, cover the car around all the interior with a multiple purposes Polyethylen-Foil (min. 0.1mm, 0.004"), and wait still raining has stopped. As illustrated, this cover (5 x 4 m) needs practically no space in the trunk (Package 30 x 38cm), and is always and instantly ready to use. ;) - SERGE - Edited by sermey 2011-01-16 4:10 AM (Emergency Car Cover.jpg) Attachments ---------------- Emergency Car Cover.jpg (77KB - 625 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Bullets for Rear View Mirror: A time ago some bullets have been offered in eBay. Even not an original mopar accessory, they went for up nearly USD100 a pair. Now I found "Chrome Bullet Heads" used as Tire Valve Caps in eBay, a set of 4pcs for USD 8.99, 5/8"x1 1/4" in metal. Proceedings: 1. Insert a cylindrical plastic plug inside the Bullet (D:7.2mm L 12mm), put-in a long screw (M4) till end, this will be tight and used for fixing. Reduce the bullet in length (from 30.5mm to 23.2mm) to fit the mirrors end diameter; cut the screw for remaining 5mm. The Bullet is ready for mount. 2. Remove the mirror nut, drill an M4 thread through, put back the Nut - the mirror is ready for the bullet. Now, just screw-in the assembled bullet, and your Rear View Mirror now shows the visible face lifting. The mirror bullets can easy be removed simply by manually unscrewing, to return to the mirrors standard view. Another gadget for your FWL Car - if you like it. - SERGE - Edited by sermey 2011-03-09 8:36 AM (DSC04478 Set of Tire Valve Caps LL.jpg) (DSC04477 Plastic Plug and M4 in Mirror Nut LL.jpg) (DSC04475 Screw-in the Bullet LL.jpg) (DSC04474 Face Lifted Rear View Mirror LL.jpg) (DSC04473 New Mirror with CameraMan LL.jpg) Attachments ---------------- DSC04478 Set of Tire Valve Caps LL.jpg (85KB - 678 downloads) DSC04477 Plastic Plug and M4 in Mirror Nut LL.jpg (47KB - 754 downloads) DSC04475 Screw-in the Bullet LL.jpg (56KB - 717 downloads) DSC04474 Face Lifted Rear View Mirror LL.jpg (58KB - 713 downloads) DSC04473 New Mirror with CameraMan LL.jpg (77KB - 669 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Door Panel Protection: When assembling the door panel I had to find a way, for not wear the new coating material at the opening of the door handle, when manipulating with. I took the body of a "Solder Sucking Wick" as used in electronics. This fits exactly in inner and outer diameter, in thickness of the door panel, and as well to the diameter of the handle, as it was designed for this application. Mounted, it doesn't turn at all and doesn't need additional spacers. Now, no friction at all to the padded coating material when manipulating the door handle - an easy and efficient solution - SERGE - Edited by sermey 2011-03-20 8:15 AM (DSC04514 Panel Protector LL.jpg) (DSC04515 Panel Protector Mounted LL.jpg) (DSC04517 Mounted Protector Rear View LL.jpg) (DSC04516 Door Handle Mounted LL.jpg) Attachments ---------------- DSC04514 Panel Protector LL.jpg (97KB - 689 downloads) DSC04515 Panel Protector Mounted LL.jpg (86KB - 689 downloads) DSC04517 Mounted Protector Rear View LL.jpg (81KB - 698 downloads) DSC04516 Door Handle Mounted LL.jpg (88KB - 741 downloads) | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | Hello Serge Thank you very much for this idea! I'll use it too. Thanks a lot. Happy motoring! Dieter | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | Another Serge special - recycling and preserving in one step | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Emblem on Door Panel: On many previous cars I owned, I liked the variety of the emblems. This is as well with FWL-Cars. But what I was always missing, an emblem on the door panel of the 1959 Dodge Custom Royal.. I purchased gloove box doors of Coronets, where there is an emblem exactly complying to my demands. Now it looks as original, as it was designed for. Another "Royal" eye-catcher. - SERGE - Edited by sermey 2011-03-20 2:42 PM (DSC04544 Emblem Door Panel1 LL.jpg) (DSC04546 Emblem Door Panel2 LL.jpg) Attachments ---------------- DSC04544 Emblem Door Panel1 LL.jpg (76KB - 732 downloads) DSC04546 Emblem Door Panel2 LL.jpg (76KB - 713 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Door Panels: A 3mm, pressed material is used, cut the contour according the door (the lines are not parallel or rectangular!), drill the holes and openings for handle, switches, clamps. Coat all the panel with a premium to be waterproof. Bostitch a protective pad behind the clamps position, then cover all the panel with a soft 3mm padding material as used for upholstery (not foamed rubber!) and fix it with contact spray. Now comes the vinyl (no glue at all!), just bostitch around on backside and on front under the mouldings, first a few ones, finally all around when adjusted. The Door Panel is now ready for mount, not seeing the fixing clamps at all. Same nice job for the other panels. - SERGE - Edited by sermey 2011-03-27 12:26 PM (01 Right Door Panel Front View.jpg) (02 Right Door Panel Rear View.jpg) (03 Right Front Panel Ready.jpg) (04 Rear Side Panel Convertible.jpg) Attachments ---------------- 01 Right Door Panel Front View.jpg (39KB - 662 downloads) 02 Right Door Panel Rear View.jpg (60KB - 687 downloads) 03 Right Front Panel Ready.jpg (60KB - 707 downloads) 04 Rear Side Panel Convertible.jpg (141KB - 668 downloads) | ||
