"Make-Up" your Car!
Jump to page : < 1 2 3 4 5 6 7 >
Now viewing page 7 [50 messages per page]
sermey
Posted 2022-10-08 8:08 PM (#624784 - in reply to #156081)
Subject: RE: "Make-Up" your Car!
1000100252525
Cap MIRROR CONTROL: I found a remote mirror set with the cap MIRROR CONTROL, didn’t see before and missing in my car (01). When arrived it showed scratched and too wasted, couldn't repair better (02). I had to remake another cap.
First model in 3D-RealView with engraved letters (03) (04), then 3D-Print in black, fill the letters in white (05) and hook up on the nut (06).
Now the heavy chrome has reduced somewhat, the aspect more appealing (07).  - SERGE -   ;)
N.B. The cap was printed in FDM-Technology. Will redo in SLA-Technology for much higher accuracy of the engraved letters. When done I will replace and present here.
Edited by sermey 2022-10-09 12:04 PM
(01 Remote Mirror Set.jpg)
(02 Cap MIRROR CONTROL OR.jpg)
(03 Cap MIRROR CONTROL CAD.jpg)
(04 Version Smaller Center CAD.jpg)
(05 Painting Letters on 3D-Print .jpg)
(06 Cap Hooked up.jpg)
(07 Final Front View.jpg)
Attachments 01 Remote Mirror Set.jpg (102KB - 52 downloads)
Attachments 02 Cap MIRROR CONTROL OR.jpg (57KB - 50 downloads)
Attachments 03 Cap MIRROR CONTROL CAD.jpg (95KB - 57 downloads)
Attachments 04 Version Smaller Center CAD.jpg (69KB - 48 downloads)
Attachments 05 Painting Letters on 3D-Print .jpg (90KB - 48 downloads)
Attachments 06 Cap Hooked up.jpg (86KB - 50 downloads)
Attachments 07 Final Front View.jpg (118KB - 51 downloads)
sermey
Posted 2022-10-11 6:19 PM (#624849 - in reply to #624768)
1000100252525
Replacing the Windshield (Add-on): On special request here the full picture (05).
(05 All New Green Tinted Glasses.jpg)
Attachments 05 All New Green Tinted Glasses.jpg (236KB - 50 downloads)
sermey
Posted 2022-10-14 11:22 AM (#624880 - in reply to #157713)
1000100252525
sermey - 2009-01-04 1:02 AM
Rear Lamp Gaskets: No comments to the old / original Gasket.
I found High Precision Hydraulic Rings, self-centering inside, outside not overlapping at all, and they fit as tailored. The black Height of 1/4" is a nice separation between the White Body and the Rechromed Housing.
Another inconspicious "Make-Up". :)
________________________________________
Rear Lamp Gaskets Data Sheet: This High Precision Hydraulic Ring is no more available from the supplier. I found a similar Data Sheet as information (01) from another manufacturer.
The costs are quite high for a gasket, as it needs 4 items for a 1959 Dodge. On the other hand this material is more durable than any rubber.
The CAD design shows how the lip sets in center position of the housing (02), and how accurate this profile fits in size (03).
Mounted on the car there is a decorative distance of 6mm (04). By tightening, the outer surface of the ring becomes slightly rounded, a desirable effect (05).  - SERGE -
(01 Abstreifer Datenblatt.jpg)
(02 Rear Lamp Gasket Profile CAD.jpg)
(03 Rear Lamp Gasket CAD.jpg)
(04 Rear Lamp Gasket on Car.jpg)
(05 Rear Lamp Gasket on Car Zoomed.jpg)
Attachments 01 Abstreifer Datenblatt.jpg (131KB - 47 downloads)
Attachments 02 Rear Lamp Gasket Profile CAD.jpg (51KB - 50 downloads)
Attachments 03 Rear Lamp Gasket CAD.jpg (75KB - 51 downloads)
Attachments 04 Rear Lamp Gasket on Car.jpg (179KB - 47 downloads)
Attachments 05 Rear Lamp Gasket on Car Zoomed.jpg (159KB - 50 downloads)
sermey
Posted 2022-10-25 8:47 AM (#625113 - in reply to #156081)
1000100252525
Convertible Top Down: Most Convertibles shows not correct setting of the top when down. Even on perfect restored cars of our challenging members (01) (02), the heighted top stands out, up to 10cm (03). This reminds the old fashioned “carriage” look on convertibles of earlier years (04).
Before restoring, the top arm of my car was as well up (05). With some effort I adjusted the mechanics for fully entering in the side box. The end of the arm now touches the body, as it should be (06). View from side, camera horizontal lined to both door borders, the top arm almost disappears (07). Then the top cover is adapted correspondingly to fit. Now it shows very flat (08).
Another harmonic car outline of designer Virgil Exner (09).  – SERGE -
(01 Nice Convertible - Gary.jpg)
(02 Nice Convertible - Mike.jpg)
(03 Top not down - Gary.jpg)
(04 Top earlier years.jpg)
(05 My Convertible Before - Top Arm Up.jpg)
(06 My Convertible After - Top Arm down.jpg)
(07 View from Side.jpg)
(08 Flat Top Cover.jpg)
(09 Review the Convertible.jpg)
Attachments 01 Nice Convertible - Gary.jpg (183KB - 44 downloads)
Attachments 02 Nice Convertible - Mike.jpg (185KB - 48 downloads)
Attachments 03 Top not down - Gary.jpg (183KB - 46 downloads)
Attachments 04 Top earlier years.jpg (128KB - 50 downloads)
Attachments 05 My Convertible Before - Top Arm Up.jpg (102KB - 47 downloads)
Attachments 06 My Convertible After - Top Arm down.jpg (117KB - 49 downloads)
Attachments 07 View from Side.jpg (133KB - 48 downloads)
Attachments 08 Flat Top Cover.jpg (114KB - 47 downloads)
Attachments 09 Review the Convertible.jpg (153KB - 43 downloads)
22mafeja
Posted 2022-10-27 7:50 AM (#625178 - in reply to #156081)
5002525
The difficulty to get the top down completely is a common one. I have installed two soft tops on cars I have restored and both have had this issue more or less.
I spent a lot of time to adjust and got to the point where I had to enlarge the holes. I think maybe the soft tops are thicker and stiffer nowadays. In my case they
were canvas tops.
You seem to have succeeded in this too Serge.
sermey
Posted 2022-10-28 2:26 PM (#625238 - in reply to #625178)
1000100252525
22mafeja - 2022-10-27 1:50 PM The difficulty to get the top down completely is a common one. . . . . .
You see absolute right, Ralf. I will come back and show some basic points how I did. There are already about 20 years since then. - SERGE -
Edited by sermey 2022-10-28 2:30 PM
sermey
Posted 2022-11-07 8:28 AM (#625414 - in reply to #156081)
1000100252525
Foiling a 1959 Dodge: Original Danis 1959 Dodge was unicolor white (01). Then he foiled his car partly to green (02). Seeing my car live he got very impressed about this combo, so as now re-foiled green to golden (03)(03a). Another golden 1959 Dodge. Congrats to his top-job! He can redo at anytime and to any color if desired.
After getting all knights golden (04), this 1959 Dodge is on the best way to become a noble vehicle - nice to look at.  - SERGE-
Edited by sermey 2022-11-07 10:39 AM
(01 Danis 1959 Dodge.jpg)
(02 Green Foiled.jpg)
(03 Foiling green to golden.jpg)
(03a Foiling green to golden.jpg)
(04 Danis 1959 Dodge Front.jpg)
Attachments 01 Danis 1959 Dodge.jpg (160KB - 40 downloads)
Attachments 02 Green Foiled.jpg (132KB - 39 downloads)
Attachments 03 Foiling green to golden.jpg (160KB - 42 downloads)
Attachments 03a Foiling green to golden.jpg (121KB - 37 downloads)
Attachments 04 Danis 1959 Dodge Front.jpg (147KB - 40 downloads)
sermey
Posted 2022-11-09 11:57 AM (#625478 - in reply to #625414)
1000100252525
sermey - 2022-11-07 2:28 PM
Foiling a 1959 Dodge: . . . . this 1959 Dodge is on the best way to become a noble vehicle - nice to look at.
And now all done, within 24 hours - what a prospect!! Who shows next Golden 1959 Dodge?  - SERGE -
Edited by sermey 2022-11-09 12:06 PM
(Danis Golden 1959 Dodge.jpg)
Attachments Danis Golden 1959 Dodge.jpg (119KB - 39 downloads)
57plymouth
Posted 2022-11-09 12:15 PM (#625479 - in reply to #156081)
Subject: Re: "Make-Up" your Car!
200010005002525
Do you mean a vinyl wrap?
sermey
Posted 2022-11-09 12:41 PM (#625480 - in reply to #625479)
1000100252525
57plymouth - 2022-11-09 6:15 PM Do you mean a vinyl wrap?
Yes Brian. A Vinyl especial for cars, as applied on many Sport Cars. It is tricky to mount, on curves to avoid scroll must heat somewhat with a Hair-Dryer.
Needs some practical skill, artistic vein and the motivation to go forward.  - SERGE -
jwheath68
Posted 2023-03-11 11:33 AM (#628192 - in reply to #156081)
I'm a little surprised you haven't tried to run 59 Cadillac tail light lenses, maybe you thought about it, seems to be in the same vein as some of your cosmetic ideas.
22mafeja
Posted 2023-03-12 3:43 AM (#628204 - in reply to #156081)
5002525
I had to read this thread from the beginning again...made me humble...
Which gas springs did you end up with Serge(trunk lid springs)?
And which stroke?
sermey
Posted 2023-03-12 7:22 AM (#628205 - in reply to #628204)
1000100252525
22mafeja - 2023-03-12 9:43 AM I had to read this thread from the beginning again...made me humble... Which gas springs did you end up with Serge(trunk lid springs)?
Gas Spring Length 275 mm Hub 100 mm Force 200 N with Ball Head Ball Joint, Black. Style Name:275|100|200N|Black
This Gas Spring, Ralf, comes in addition to the existing Torsion Spring Bars in the trunk. Check for correct position, then drill and mount. By removing the clips it can easily be
removed and replaced. Good Luck  - SERGE -
Edited by sermey 2023-03-12 7:26 AM
(Gas Spring for Trunk.jpg)
Attachments Gas Spring for Trunk.jpg (65KB - 21 downloads)
22mafeja
Posted 2023-03-12 8:17 AM (#628207 - in reply to #156081)
5002525
Thanks Serge.
Posted 2023-03-12 12:49 PM (#628210 - in reply to #628207)
50002000200050025
Amazing!
 The flat fold-down looks wonderful
Edited by Lancer Mike 2023-03-12 12:56 PM
sermey
Posted 2023-03-26 11:07 AM (#628550 - in reply to #156081)
1000100252525
Covering the bottom fold: Most bottom folds under the sill plate look messed up, any more when they are rusty. For protection and a nicer appearance it can be coated as I did with a special black adhesive Tape 3M-33 (01). Of course, the other side of the fold must be sealed when coated, as I did with noise reduction panels on all interior surfaces, and as described earlier.
As the surfaces showed very uneven (02), I started another way by grinding the metal peaks (03), and looked for an adequate Silicone Rubber Profile (04). This, filled with black special adhesive sealant, then set on (05). The excess of glue was immediately removed, the car left for a week to dry through (06).
Now, the fold is protected, especially view from side it looks straight and neatly, as it should be all the time (07). Another “Make-Up” on my 1959 Dodge Custom Royal Convertible.  - SERGE -
(01 Fold coated with Scotch Tape.jpg)
(02 Uneven Surfaces.jpg)
(03 Grinding the Peaks.jpg)
(04 Silicone Rubber Profile.jpg)
(05 Pre-Setting the Profile.jpg)
(06 Preview.jpg)
(07 Profile Optimized and Fixed.jpg)
Attachments 01 Fold coated with Scotch Tape.jpg (80KB - 16 downloads)
Attachments 02 Uneven Surfaces.jpg (74KB - 15 downloads)
Attachments 03 Grinding the Peaks.jpg (91KB - 16 downloads)
Attachments 04 Silicone Rubber Profile.jpg (72KB - 16 downloads)
Attachments 05 Pre-Setting the Profile.jpg (84KB - 18 downloads)
Attachments 06 Preview.jpg (104KB - 16 downloads)
Attachments 07 Profile Optimized and Fixed.jpg (93KB - 16 downloads)
Posted 2023-03-26 2:23 PM (#628552 - in reply to #628550)
500020002000100100252525
Very neat and clean there Serge. Good job.
I hate (strongly dislike) the equivalent pinch weld on my 56 Dodge. So far I have cleaned and painted it (but still light blue) but I was thinking of painting it flat black to make it visually disappear from the side.
But now I see yours with the rubber covering and I say "Hmm...that looks good", I am re-thinking the black paint thing.
Where did you get the rubber profile, i.e. what was its original purpose? (Where would I look over here in Canada?)
My pinch weld flange (pretty straight but still ugly)
Edited by 56D500boy 2023-03-26 3:09 PM
(DaveFs56DodgeRockerPanelPinchWeldFlange_Mar26_2023.jpg)
Attachments DaveFs56DodgeRockerPanelPinchWeldFlange_Mar26_2023.jpg (147KB - 14 downloads)
sermey
Posted 2023-03-26 3:12 PM (#628553 - in reply to #628552)
1000100252525
I never doubt Dave, that you have a pronounced sense for aesthetics, recognizing the optical effect . . . . .
There are various suppliers for such profiles. For your car another profile would fit better, check first the thickness of the fold.  - SERGE -
 https://shop.maagtechnic.ch/de/elastomertechnik-gummiprofile/u-profile-pr1579278053429099/?searchTerm=gummi+u-profile
just for dimensions, look at page 3
Edited by sermey 2023-03-26 3:16 PM
Posted 2023-03-26 5:52 PM (#628559 - in reply to #628553)
sermey - 2023-03-26 12:12 PM
So I guessing that you used this one:
U-Profil rund EPDM 5,5x18mm U-Profil rund EPDM 5,5x18mm Maagtechnic Artikelnr: 10007460 Vorrätig
Vergleichen
sermey
Posted 2023-03-27 5:31 AM (#628567 - in reply to #628559)
1000100252525
The used profile is not shown in the internet. Here a scan from the big catalogue, you will see Art. No. 122157. I think the narrow one Art. Nr. 122195 may better fit to your car.
You will need total up to 5m. - SERGE -
Edited by sermey 2023-03-27 5:40 AM
(U-Profile 150.jpg)
Attachments U-Profile 150.jpg (196KB - 14 downloads)
Attachments U-Profile 150.pdf (200KB - 13 downloads)
sermey
Posted 2023-04-01 9:28 AM (#628659 - in reply to #156081)
1000100252525
Checking the Fuel Pump: As shown earlier, in my car I have two fuel pumps, one original mechanic and a second electrical, switchable. After about 30 sec activation of the electrical Fuel Pump, the glass fuel filter (01) becomes  full, can even hear the lower speed of the pump. Now  the car will  start up immediately. This the main advantage.
The two pumps work in parallel. Due to the non-return valves in the out port of the units, only the stronger one contributes fuel to the carburators.
My fuel line offers the option to connect a pression gauge (02). The fuel pressure of the single mechanical pump, at idle 450 rpm, is shown in (03), at 2000 rpm in (04).
The fuel pressure of the single electrical pump is shown in (05, and is independent of the rpm.
When both  pumps are active, the dominant electrical pump defines the fuel pressure. So far, just for information.  – SERGE –
Edited by sermey 2023-04-01 9:49 AM
(01 Glass Fuel Filter.jpg)
(02 Port for Pressure Gauge.jpg)
(03 Mechanical Fuel Pump 450rpm.jpg)
(04 Mechanical Fuel Pump 2000rpm.jpg)
(05 Electrical Fuel Pump.jpg)
Attachments 01 Glass Fuel Filter.jpg (107KB - 13 downloads)
Attachments 02 Port for Pressure Gauge.jpg (136KB - 13 downloads)
Attachments 03 Mechanical Fuel Pump 450rpm.jpg (127KB - 13 downloads)
Attachments 04 Mechanical Fuel Pump 2000rpm.jpg (135KB - 13 downloads)
Attachments 05 Electrical Fuel Pump.jpg (133KB - 13 downloads)
sermey
Posted 2023-04-21 7:35 PM (#629039 - in reply to #156081)
1000100252525
Dual Front Door Catch System: Hitting the door to another car or wall – a big disaster due to the expensive replacement of the rare sheet metal.
This Dual Front Door Catch System, passenger and driver side, for 1959 Dodge and Plymouth (10), may fit as well for years 1956 (11), 1957 and 1958.
HighTech 3D engineered and simulated. Precision stainless steel parts, Laser cut to fit to minimum gap of 1mm. Smooth, floating roller-based operation, thus no additional door friction until snap (01). Dual trap position. First trap (02) aperture 65cm (03). Second trap (04) aperture 110cm (05). Fully opened (06) 150cm as original. Determined snap-in (07). Release force adjustable.
A unique compact set: 32 items, included stainless hex screws with matching tool, drilling template (08) and the mounting instructions. After drilled ready for mount.
An indispensable safety feature, for a valuable vehicle, avoiding damage when parking, and on slanting streets. A standard on all today’s vehicles.  - SERGE -
Edited by sermey 2023-04-22 5:48 AM
(01 Top View.jpg)
(02 First Trap.jpg)
(03 Measured 64cm.jpg)
(04 Second Trap.jpg)
(05 Measured 110cm.jpg)
(06 Door fully opened 150cm.jpg)
(07 Front View CAD.jpg)
(08 Drilling Template A4.jpg)
(09 Assembled Trap Bar CAD.jpg)
(10 1959 Plymouth Door Fully Opened.jpg)
(11 56DodgeD500_4502_RightsideCourtesyLightPlunger.jpg)
(12 56Dodge Dave FrontDoorShowingDoorStopInAction.jpg)
Attachments 01 Top View.jpg (128KB - 12 downloads)
Attachments 02 First Trap.jpg (133KB - 12 downloads)
Attachments 03 Measured 64cm.jpg (112KB - 11 downloads)
Attachments 04 Second Trap.jpg (122KB - 12 downloads)
Attachments 05 Measured 110cm.jpg (110KB - 11 downloads)
Attachments 06 Door fully opened 150cm.jpg (102KB - 13 downloads)
Attachments 07 Front View CAD.jpg (68KB - 11 downloads)
Attachments 08 Drilling Template A4.jpg (90KB - 13 downloads)
Attachments 09 Assembled Trap Bar CAD.jpg (75KB - 11 downloads)
Attachments 10 1959 Plymouth Door Fully Opened.jpg (118KB - 12 downloads)
Attachments 11 56DodgeD500_4502_RightsideCourtesyLightPlunger.jpg (114KB - 16 downloads)
Attachments 12 56Dodge Dave FrontDoorShowingDoorStopInAction.jpg (159KB - 12 downloads)
sermey
Posted 2023-04-23 2:19 PM (#629083 - in reply to #629039)
1000100252525
Compatibilty to other Mopars: I was asked about. Here to compare, a picture with transparent front at fully opened door, and the link:
http://www.forwardlook.net/forums/forums/thread-view.asp?tid=34070&start=115
Edited by sermey 2023-04-23 2:33 PM
(2023-04-23 Original Front Door Stop FWL.jpg)
Attachments 2023-04-23 Original Front Door Stop FWL.jpg (89KB - 10 downloads)
sermey
Posted 2023-04-29 4:06 AM (#629247 - in reply to #156081)
1000100252525
Checking the Neutral Safety Switch: (01) It happens once, the starter motor didn’t engage in N position. I switched the push buttons to R, then to D, and back again to N. So the starter ran and then motor as well.
To know: This device is not a switch from a classic point of view. It consists of a movable bolt as contact element, guided by the isolation, and pressed out by an internal spring. It activates the relay to the starter.
Unmounted: Whatever the position of this contact, the resistance between the wire connection and the bolt (04) should always show 0 Ohm, as well when bolt point is pressed down (02). Measured 0.1 Ohm on point, 0.00 Ohm when fully pushed in (for test). As stated, this device is not a switch, but acts as a flexible conductor, or simply a contact device. Thus, following I will talk about contact, or about safety switch.
The contact is ON when the transmission lever (03) touches the point of the safety switch, and thus the connection turns grounded. This only happens when the gear is set to N position (04). For safety, the starter motor should only work in N position. So far so good and well known. -
I did some electrical measurements on this device. from wire connection to ground (04), the safety switch always mounted, and the cable connected. Measuring Ohms the battery is disconnected:
Result should be: (Instrument checked for 0.0 Ohm at short circuit)
Position ignition switch OFF and battery disconnected:       (N) position -> 0 Ohm  (R or D) position -> High Ohm
Position ignition switch ON and battery connected:             (N) position -> 0 Volt    (R or D) position -> Battery Voltage 12V
Result was:
Position ignition switch OFF and battery disconnected:       (N) position -> switched multiple: 1.7 – 6.9 Ohm (06), but never 0 as it should show. Sometimes even up to 60 Ohm (!).
I unlocked the adjustment wheel (07) by rotating out to get the gearshift control cable somewhat movable. Now pushed it in < - > out to find minimum Ohm reading, fixed it at this optimized position.
Result Now at optimized position:
Position ignition switch OFF and battery disconnected:    (N) position -> up to max 1.3 Ohm (08)
Position ignition switch ON and battery connected:          (N) position -> starter motor will always work
This proceeding may be considered as another, simple operational check of the Neutral Safety Switch, without unmount. A way for electrically fine position the control cable to the peak of the contact lever (03).
- SERGE -
N.B If the safety switch shows in any position 0 Ohm, resp. 0 Volt, then there is a short-circuit, and no start protection. If there is always High Ohm, resp. 12 Volt, then there is no contact at all. The car cannot be started. May be too low pressure from the bolt to the contact lever, the internal spring may be weakened or even broken. In both cases the switch must be replaced (09). By switching the gear selector (10) before starting several times from R to N and the other way back, the contact may be cleaned.
Some basics and pictures presented earlier by courtesy of Phil Courant (Phil_the_frenchie).
Edited by sermey 2023-04-29 12:16 PM
(01 Neutral Safety Switch.jpg)
(02 Contact Pressed in.jpg)
(03 View on Transmission Contact Lever.jpg)
(04 Electric Test Connection.jpg)
(05 PhilCourantsSafetyLeverContactingSafetySwitchInNeutral.jpg)
(06 Reading 1.7 - 6.9 Ohm.jpg)
(07 Turning out the adjustment washer.jpg)
(08 Reading max Ohm 1.3 Ohm.jpg)
(09 PhilCourantsNeutralSafetySwitch_1704283.jpg)
(10 Push Button Unit.jpg)
Attachments 01 Neutral Safety Switch.jpg (81KB - 8 downloads)
Attachments 02 Contact Pressed in.jpg (62KB - 8 downloads)
Attachments 03 View on Transmission Contact Lever.jpg (154KB - 7 downloads)
Attachments 04 Electric Test Connection.jpg (111KB - 7 downloads)
Attachments 05 PhilCourantsSafetyLeverContactingSafetySwitchInNeutral.jpg (129KB - 7 downloads)
Attachments 06 Reading 1.7 - 6.9 Ohm.jpg (123KB - 7 downloads)
Attachments 07 Turning out the adjustment washer.jpg (69KB - 7 downloads)
Attachments 08 Reading max Ohm 1.3 Ohm.jpg (136KB - 7 downloads)
Attachments 09 PhilCourantsNeutralSafetySwitch_1704283.jpg (138KB - 8 downloads)
Attachments 10 Push Button Unit.jpg (115KB - 7 downloads)
sermey
Posted 2023-05-28 1:04 PM (#629862 - in reply to #156081)
1000100252525
Color of a Convertible Top: There are two ways for select the color of a convertible top: Original color or Custom color.
When I got my 1959 Dodge Custom Royal Lancer Convertible, it had a white top, greyed-out similar as shown in (01), and partly broken at the edges. The new included white top I gave to a friend as gift, for I decided to switch to black.
Can say, never a white top on a white car, for the color will barely match, fade out in time, and show any dirt. Except to a white paint, a white top will fit to any other color. On the other side, any other top color may fit to a white car. This my personal view from an esthetical and practical point.
The black top on my convertible looks always as new, now even many years later (02)(03)(04).  - SERGE -
Edited by sermey 2023-05-29 2:51 AM
(01 Convertible Top White Greyed.jpg)
(02 Convertible Top Black.jpg)
(03 Convertible Top Black.jpg)
(04 Convertible Top Black.jpg)
Attachments 01 Convertible Top White Greyed.jpg (110KB - 2 downloads)
Attachments 02 Convertible Top Black.jpg (142KB - 3 downloads)
Attachments 03 Convertible Top Black.jpg (141KB - 3 downloads)
Attachments 04 Convertible Top Black.jpg (105KB - 2 downloads)
