59 Power Steering Pump.. Moderators: Ian, Rebels-59 Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Forward Look Local Regions -> United Kingdom Region | Message format |
Rebels-59 |
Board Moderator & Exner Expert 10K+ Location: .Norfolk..Mafia.. ,England UK | Just been in the Garage, and either Someone has crawled under the 59 Chrysler Windsor and Died, OR i have a Power Steering Leak.. I did notice the Pump was a Little Whiny when i drove it in the States and had to tighten the Belt after 1000 plus miles .. So i checked the Transmission Box level ( not running ) and that appears OK as it is way up the stick. I checked the Power Pump and although it is Not completely empty, It is Very Low.. So has anyone got a spare Pump Laying around that they wouldn,t mind selling .. I can take a PIC of the Pump if there are Different pumps fitted in that year model.. Either reply here or send a PM Thanks Clive | ||
phins |
Elite Veteran Posts: 1172 Location: bradenton florida | i just took this one off my 58 to put the correct one on. i think it for a 59 and up. nothing wrong with it. i can take some better pics now that it's out of the car. Edited by phins 2008-02-11 9:40 PM (steeringpump2.jpg) (pspumpx.jpg) Attachments ---------------- steeringpump2.jpg (32KB - 157 downloads) pspumpx.jpg (28KB - 143 downloads) | ||
Rebels-59 |
Board Moderator & Exner Expert 10K+ Location: .Norfolk..Mafia.. ,England UK | Thanks GARRY... I will check the one fitted on my 59 to Compare.. But it may be a Couple Days, As i get Home Late from Work.. I was Hoping someone in the UK may have one , OR hopefully IAN may know of something, As i am Not sure How much the Shipping would be as the Pump will be Quite Heavy.. But IF it is the correct one and i cannot find a pump overhere, I will Have it.. Any Chance you could weigh it and find out a shipping cost.. Thanks Clive | ||
Expert 5K+ Posts: 7498 Location: northern germany | if its just leaky, why don't you just seal it up??? its mostly the large housing O ring. easy to fix and cheap. | ||
Rebels-59 |
Board Moderator & Exner Expert 10K+ Location: .Norfolk..Mafia.. ,England UK | I was going to go for another Pump, As when i drove it in America , I noticed the Steering was a Little Notchy when the Engine was just over Idle driving in the Multy Storey Carpark. This is what made me Check and tighten the Belt, But i did notice the End Shaft Wheel what the Belt runs on had some End Play. And if you sort of Jurked it, It did have a little Knock within the Play.. So i am guessing the Bearing has Gone and Probably Damaged the End " O Ring " ,, I have Never rebuilt a Power Steering Pump, So Replacement Seemed the easy option.. But i am Open to Any Idea,s OR Advice.. The Leak may not be that bad. The car has sat idle since End october and you know how bad oil spreads and makes things look worse than they really are.. And i only topped up the Oil ONCE in America and drove 1800 Miles.. Well 800 after i toppped it up.. | ||
Rebels-59 |
Board Moderator & Exner Expert 10K+ Location: .Norfolk..Mafia.. ,England UK | I MUST be Deaf and Blind , as i can,t hear Or see anyone Recommending Or Helping Here... Do they do a Rebuild Kit.. I will Add some PIC,s shortly.. | ||
Rebels-59 |
Board Moderator & Exner Expert 10K+ Location: .Norfolk..Mafia.. ,England UK | Here are the Pic,s of the Pump fitted to My 383cu in.. (59 C Pump.JPG) (59,C Pump.JPG) (59.C Pump.JPG) (59C pump.JPG) Attachments ---------------- 59 C Pump.JPG (74KB - 153 downloads) 59,C Pump.JPG (81KB - 148 downloads) 59.C Pump.JPG (86KB - 148 downloads) 59C pump.JPG (81KB - 159 downloads) | ||
Board Moderator & Exner Expert 10K+ Posts: 13066 Location: Southern Sweden - Sturkö island | Clive, is this what you look for? http://cgi.ebay.com/ebaymotors/Mopar-reman-p-steering-pump-1960-69-... | ||
Rebels-59 |
Board Moderator & Exner Expert 10K+ Location: .Norfolk..Mafia.. ,England UK | wizard - 2008-02-16 6:40 PM Clive, is this what you look for? http://cgi.ebay.com/ebaymotors/Mopar-reman-p-steering-pump-1960-69-... Thanks for the Link Sven I have Emailed the seller for some Clarification. But the Inlet pipe is located Lower, But may still Fit.. Just waiting for a Reply | ||
Rebels-59 |
Board Moderator & Exner Expert 10K+ Location: .Norfolk..Mafia.. ,England UK | phins - 2008-02-12 2:36 AM i just took this one off my 58 to put the correct one on. i think it for a 59 and up. nothing wrong with it. i can take some better pics now that it's out of the car. Garry,, Have you ANY Better PIC,s.. I have posted some of my Pump Above.. Yours does seem to be the Same , But need to see where the Pipes Enter and Exit,, Also did you manage to find a Shipping Cost to England.. Also want do you want for the Pump also.. CLIVE | ||
Rebels-59 |
Board Moderator & Exner Expert 10K+ Location: .Norfolk..Mafia.. ,England UK | Rebels-59 Coronet - 2008-02-16 7:01 PM wizard - 2008-02-16 6:40 PM Clive, is this what you look for? http://cgi.ebay.com/ebaymotors/Mopar-reman-p-steering-pump-1960-69-... Thanks for the Link Sven I have Emailed the seller for some Clarification. But the Inlet pipe is located Lower, But may still Fit.. Just waiting for a Reply Got this Reply back from the Listed Ebay Auction.. Hi Clive, No this is not correct for a 1959 Chrysler as per my parts book but thanks for asking. Jack So still Looking , Hopefully Garry will visit the UK Region soon and get back to me .. | ||
phins |
Elite Veteran Posts: 1172 Location: bradenton florida | pics of pump off of car (IMG_1971 [800x600] [50%].JPG) (IMG_1972 [800x600] [50%].JPG) (IMG_1973 [800x600] [50%].JPG) (IMG_1975 [800x600] [50%].JPG) (IMG_1974 [800x600] [50%].JPG) Attachments ---------------- IMG_1971 [800x600] [50%].JPG (38KB - 145 downloads) IMG_1972 [800x600] [50%].JPG (41KB - 145 downloads) IMG_1973 [800x600] [50%].JPG (36KB - 147 downloads) IMG_1975 [800x600] [50%].JPG (38KB - 142 downloads) IMG_1974 [800x600] [50%].JPG (40KB - 139 downloads) | ||
Rebels-59 |
Board Moderator & Exner Expert 10K+ Location: .Norfolk..Mafia.. ,England UK | Many Thanks GARRY... It looks to Be the Correct Pump, But i will Double Check on Saturday as i am Flat Out at work until then.. Did you manage to get a Shipping Quote for Me.. The Brackets can be Removed to cut down on the Weight.. PLEASE let me know as soon as possible, As it may have to be Sent Surface mail cos of the weight , And that may take 4 weeks for Delivery.. Thanks Clive | ||
Rebels-59 |
Board Moderator & Exner Expert 10K+ Location: .Norfolk..Mafia.. ,England UK | Garry.. The Pump seems Correct.. EXCEPT The Bracket is All Wrong and my Bracket has 2 Bolts at the Back of the Pump, Where as in your Last PIC you can see yours only has 1... So does anyone Know if this pump is still Compatible............ I checked my 59 Chrysler Pump Against my 59 Dodge Pump and they are IDENTICAL.. | ||
phins |
Elite Veteran Posts: 1172 Location: bradenton florida | i can drill another hole in the back if you like | ||
Rebels-59 |
Board Moderator & Exner Expert 10K+ Location: .Norfolk..Mafia.. ,England UK | phins - 2008-02-24 3:46 PM i can drill another hole in the back if you like Thanks .....LOL If you look at this PIC.. Mine has a Extra bolt in the Centre.. So that bracket is slightly longer with 2 bolts.. So shouldn,t be a problem really... Has anyone Else fitted this pump to my type of bracket ???????????? (01.jpg) Attachments ---------------- 01.jpg (40KB - 137 downloads) | ||
phins |
Elite Veteran Posts: 1172 Location: bradenton florida | i haven't seen any pics of your pump | ||
Rebels-59 |
Board Moderator & Exner Expert 10K+ Location: .Norfolk..Mafia.. ,England UK | phins - 2008-02-24 3:57 PM i haven't seen any pics of your pump Scroll up on this Page.. There are 4 PIC,s.....( just below your original 2 )..... But the Pump is still fitted to the Engine.. | ||
phins |
Elite Veteran Posts: 1172 Location: bradenton florida | i saw them but i can't see the back , like you were talking about. i can include my mounting bracket, the shipping would be the same. its a flat rate box | ||
