Location: .Norfolk..Mafia.. ,England UK | Can anyone Identify these Antenna,s , I bought them recently as a set , I am going to Fit them to my 59 Dodge, As they are Similar i believe to the Original.. I am needing the Coax wires and T-Piece Joiner if anyone can Help....
Also the Rubber Base Seals are Tappered and Handed for Left and Right.. So you get the Correct Tilt of the Antenna once Fitted !!
Edited by Rebels-59 Coronet 2007-08-28 6:34 PM
(dad4_1.JPG)
Attachments ---------------- dad4_1.JPG (22KB - 231 downloads)
Location: .Norfolk..Mafia.. ,England UK | They Extend to about 6-8 Feet.. Are Extremely high But do look Great...
Here is the Boss of a 59 Dodge .. ( well so i was Told. ) ???
(cc0d_1.JPG)
Attachments ---------------- cc0d_1.JPG (14KB - 226 downloads)
Location: bishop, ca | Cleave, I wouldn't drill into MY 1959 Dodge, to install those aftermarket antennae bases, unless their mounting-holes would have the same
spacing, between their studs (and then I still woont do it!) as the correct OEM bases may have.
BTW, has your ship left port, yet?
Location: .Norfolk..Mafia.. ,England UK | The Base,s Appear to be the Same Size... the Coax hole and Front Mounting hole are in Opposite Locations Only... SO if i ever Find Correct Dual Antenna,s I will be Able to Use the Same Drill Holes...
Also here in the UK,, I doubt ANYONE would know the Difference, Except a Select Few.. |
Location: .Norfolk..Mafia.. ,England UK | d500neil - 2007-08-28 11:15 PM
Apparently YES... Due to Dock September 5th... believe when i see it though..
And NO i Ain,t telling Nobody the Name of the Ship... Too many Wise Cracks been mentioned Already... LOL |
Location: Scottsdale, AZ | Those are nice Clive, my car doesn't have them and ones I seen are pretty expensive for the pair. Maybe someday. Holes can always be welded in. Jay |
