Location: Ohio | Factory Dual Quad Intake set-up with Carter carbs
Intake Part # 1827899
Date code: J 197
Used on the following engines
> 1958 with 350
> 1959-62 with 383
Carter Carbs
Both have Part # 3251S and Date Code L1
$1200.00 Plus Shipping
Have many more pictures can email. Send PM if interested
Edited by Space Trukin Wagon 2024-05-06 3:33 PM
Attachments ---------------- Intake_Dual-Quad-1d.jpeg (231KB - 71 downloads)
Location: Lubbock, TX | Just fyi, those carbs are meant for single 4bbl applications in 1962 I believe. Correct 2x4 carbs for that manifold are 2633s and 2634s. Best of luck with the sale!
~Peter |
Location: Ohio | Actually the 3251-S carb is correct for the 1962 413 engine as I have already confirmed the part numbers. However, as everyone knows locating correct dual quad carbs for specific years is difficult and can be expensive.
Its just the set-up planned to use on a car that has now changed direction. The nice thing about Carter carbs is that the bodies are the same and can be rebuilt to other specs.
Open to selling the intake and carbs separately depending on what someone is looking for. |
