60 - 61 dodge speedo cluster are they different
moparl
Posted 2024-03-13 3:43 AM (#634184)
Subject: 60 - 61 dodge speedo cluster are they different
100252525
Hi just enquiring on 1961 dodge phoenix speedo cluster is it the same as 1960 dodge pioneer ,phoenix, they look very similar, mine has a frosted see thru lens any information will be greatly appreciated
Thanks
Alan Smith
Sunny dunedin
New Zealand
moparl
Posted 2024-03-13 5:55 PM (#634190 - in reply to #634184)
Subject: RE: 60 - 61 dodge speedo cluster are they different
100252525
Hi have figured out 61 dodge milage odometer is different from 60 problem solved
geoffs60
Posted 2024-03-14 4:34 AM (#634194 - in reply to #634190)
1002525
HI Alan, I am sure i have a 61 cluster, biggest snag with the 60/61s is a bounching speedo needle, the speedo shaft runs directly thru the die cast hsg
rather than thru a bush, as they wear the speedo is all over the place.
Geoff
Posted 2024-03-14 5:04 AM (#634195 - in reply to #634184)
Subject: Re: 60 - 61 dodge speedo cluster are they different
50005000200010002525
I've repaired some speedometers using the small tube on the tip of a lead pencil. The pens with refill leads.
Just cut it off, adapt to the shaft and when all looks good secure with super glue.
