57Plymouth front boby mount?
HemiSportFury
Posted 2024-03-04 4:24 PM (#634044)
Subject: 57Plymouth front boby mount?
Does anyone have a picture of the front body mount on a 57 Plymouth? Not the one under the front radiator support, the one at the base of the firewall. It is the one with the conical washers. I'm getting ready to put the body back on the frame and I want to be sure I get it correct. And there is only one rubber for it, correct?
Thanks!
Edited by HemiSportFury 2024-03-04 6:19 PM
Posted 2024-03-04 10:38 PM (#634047 - in reply to #634044)
Subject: Re: 57Plymouth front boby mount?
5000
yeah it has that cone shape spacer at the top
Posted 2024-03-05 1:35 PM (#634051 - in reply to #634044)
50001000500
Hemisport: Could you take some pictures for us? Thanks! I'm looking to get some body bushings and was told 1957 C#3Vy car mounts in rubber or poly wouls work. Thanks again.
HemiSportFury
Posted 2024-03-05 6:46 PM (#634058 - in reply to #634051)
Here is the hardware for the front mount. I'm not sure about the order it is assembled or which end is up. That's where I could use some help. I got rubber insulators on Ebay that are very close to the originals.
HemiSportFury
Posted 2024-03-05 6:52 PM (#634059 - in reply to #634058)
(20240305_163241.jpg)
Attachments 20240305_163241.jpg (78KB - 30 downloads)
HemiSportFury
Posted 2024-03-05 10:21 PM (#634062 - in reply to #634044)
The parts are laid out in what I think is the correct order on the upper part of the stud. Then that goes through the body mount and on the bottom side is the rubber isolator, the large cone washer, the frame mount, large washer and nut. I think?
There probably is another large washer between the bottom of the rubber and the large cone washer.
Edited by HemiSportFury 2024-03-05 10:26 PM
HemiSportFury
Posted 2024-03-07 6:43 PM (#634119 - in reply to #634062)
After carefully looking at the witness marks on the washers and rubber, this is the only way I go see the parts going together. If this is wrong speak now or forever hold your peace.
Edited by HemiSportFury 2024-03-07 6:53 PM
(Body mount.jpg)
(Body mount 2.jpg)
Attachments Body mount.jpg (226KB - 30 downloads)
Attachments Body mount 2.jpg (249KB - 29 downloads)
