Location: Lower Mainland BC | "Work" is an interesting word. The carbs on that manifold are Carter WCFBs for an S26 Desoto Adventurer, Front 2635S and S26 Adventurer, Rear 2636S. They would fit on any Carter WCFB-related 4 bbl manifold but function as hoped? Maybe not.
The jetting, etc. would likely be wrong. Jets, etc. can be changed if you have the time and patience to trial and error/success it to the point that you are happy.
1822 204 is the casting number which is rarely the part number (I can't find a 1822 204 intake manifold)
Only the rear carb has a choke plate. Regardless, they will both need to be rebuilt.
https://images.craigslist.org/00T0T_dRZcqiruJiB_0CI0nB_1200x900.jpg
Edited by 56D500boy 2023-12-28 10:09 AM
