Posted 2023-10-01 12:23 PM (#632140 - in reply to #632133) Subject: RE: convertible top pivot bolt.
Thank you. The parts manual illustration dosen't show the actual bolt but it would be used to attach support # 23 58 336
and # 23 58 333 adjustor link to the body. This is the up/down adjusting point for the top frame. one each side. There is also a fore/aft adjustment that uses the same bolt, one each side for a total of four bolts per top. 6006 224 perhaps?
