What frame fits 59 Dodge 2 door
jwheath68
Posted 2023-09-18 10:12 PM (#631928)
Subject: What frame fits 59 Dodge 2 door
My frame is rusted in half, will be looking for a replacement, since these are already very scarce, what other vehicles have the same frame as the Dodge 2 door hardtop, I've heard all Dodge models use the same for that year but have no confirmation, also heard the 59 desoto was possibly the same, what about 57-58 Dodge? Plymouth perhaps? Thanks.
Posted 2023-09-18 11:17 PM (#631929 - in reply to #631928)
Subject: RE: What frame fits 59 Dodge 2 door
50002000200050010010010010025
I am honestly shocked but it looks like the base door shells for a 1959 Dodge 2 dr hardtop (Special Club Coupe) and convertibles (Convertible Coupes)
are the same as those for the 59 Desoto and 59 Chryslers.
Different than the 59 Plymouth (smaller wheel base)
Edited by 56D500boy 2023-09-18 11:32 PM
(59MoparFrontDoorShellPNs.jpg)
Attachments 59MoparFrontDoorShellPNs.jpg (147KB - 53 downloads)
geoffs60
Posted 2023-09-19 4:33 AM (#631932 - in reply to #631929)
1002525
Yes thats fairly common right thru, subject to moulding holes of course . The plymouths were different because of the exposed door handles, swb/lwb were
still the same dimension wise for all, not sure on imperial thou , pretty well everything on the imperials were imperial only.
Geoff
Posted 2023-09-19 3:16 PM (#631944 - in reply to #631928)
Subject: Re: What frame fits 59 Dodge 2 door
You should be able to use any Dodge based frame under your car from '57-'59. However, keep in mind that the way the upper control arms mount are completely different in 1959. Also, the rear springs are a different length in 1957, from the later cars. So if you swap to an earlier frame, you'lll need to get the UCA's, and/or rear springs too. To be clear, you can get a frame from any 4dr sedan, 4dr hardtop or 2dr hardtop. The 4dr hardtop may have one mount that is moved slightly, I don't remember for sure, but should be easily modified, regardless.
Dodge based cars:
'57-'59 Dodge (any model)
'57-'59 DeSoto Firesweep
'58-'59 Chrysler Windsor
If you want to have a frame that is exactly like the one you currently have, you will be limited to 1959.
Edited by Powerflite 2023-09-19 3:21 PM
jwheath68
Posted 2023-09-19 10:22 PM (#631947 - in reply to #631928)
Ok, thanks fellas, that's what I was looking for
58coupe
Posted 2023-09-20 11:38 AM (#631955 - in reply to #631928)
100050010010025
The Desoto firesweep 58-59 should have the same frame also since it is actually a Dodge under the skin.Also any frame that was for a 6 cylinder will have different welded in motor mounts which means more work to change.
