Location: So. Cal | New stuff is just extruded sections that you have to bend around the corners and glue together at the bottoms. The only good molded ones are used. Get a used one from the Eastern or South-Eastern US. They are typically rotted out in the Western states.
The good news is that you can get it from any 4dr or 2dr Dodge or Plymouth sedan from '57-'59. So there should be plenty out there available. Dorsey (Oldwood) is a good person to contact for one.
Edited by Powerflite 2023-08-01 9:26 PM
