Posted 2023-04-13 8:04 AM (#628894) Subject: 1961 Chrysler Windsor 383 6.3 litre
Hi I am looking for help with finding an electronic ignition preferably with an integral coil in the unit are their any available that will fit the 383 engine I have looked at the large red cap HEI type and it looks as though it will clash with the rocker cover
I would rather not go with the type that has a control box separate as I have had issues with failure on my Dodge
I would consider the type that fits in the original distributor I am running a single points distributor currently
Any help suggestions appreciated thanks Phil
Posted 2023-04-24 4:56 PM (#629110 - in reply to #628907) Subject: Re: 1961 Chrysler Windsor 383 6.3 litre
Powerflite - 2023-04-13 5:44 PM
I sell these brackets to mount an HEI module to the bottom of a Mopar electronic distributor. http://www.designed2drive.com
^^^^ This is by far the best option. Looks just about fatory original, performs well, and you can get generic GM HEI modules everywhere if you have a failure on the road. Pretty sure Walmart stocks them . . .
