Location: Lower Mainland BC | I just emailed Sven and said "I was wondering why there were so many "new" posts that are showing up on the forum. Just figured it out.
Instead of having yesterday or Thursday's posts as 2023-03-30 or -31 they have been posted by the operating system as 2023-08-30 or -31, August, NOT March.
I posted today in one thread and it came up correctly as 2023-04-01 so it was just the last posts of March that are screwed up.
Hopefully you or someone else can fix this (??)"
Location: So. Cal | Look at Mope's last post and my last post in this thread, which is 4 posts above his!
http://forwardlook.net/forums/forums/thread-view.asp?tid=78381&post...
Location: SWITZERLAND | In the thread "Wanted to buy or barter a copy of a 56 Dodge broadcast sheet" I added a blank 56 IBM Card. The reply didn't appeared at the end, but somewhere up - even after some attempts. |
Location: Southern Sweden - Sturkö island | The administrator Dave informs that we had a glitch a couple of days ago. He'll fix it by and by.
New posts should be ok |
Location: Lower Mainland BC | wizard - 2023-04-02 1:04 AM
Sweet bye and bye I think.
I believe the posts that were made on April 28, 29 and 30th were the ones that were affected, i.e. changed to 2023-08-28, - 29 and -30 instead of 2023-04-28, etc.
These incorrectly dated posts will continue to clutter up the "new post" section until 2023-08-31 unless Dave fixes the problem before then.
Can't be too difficult.
Location: Southern Sweden - Sturkö island | Meanwhile, click on forums and the posts active today Dave, then more posts will show up |
Location: Lower Mainland BC | wizard - 2023-04-07 1:31 PM
I click on Search - posts in the last 24 hrs. Same exact result as your suggestion. All the 2023-08-28, 29, 30, etc posts show up as New and Active and they will continue to do so until Dave the Administrator uses his magic keyboard to fix the problem.
Something like:
FIND "2023-08-"
REPLACE WITH "2023-04-"
should fix the problem.
Sure would be nice if Dave changed the dates of the posts made on April 28, 29 and 30th from the incorrect August 28, 29 and 30 to the correct April dates.
It is annoying (to me and maybe others) to see the wrong date show up as "new" posts.
Can't be that hard to fix?
Location: Southern Sweden - Sturkö island | I cannot know why Dave hasn't fixed the glitch yet.
Best if some more guys send him an email...... |
Location: Lower Mainland BC | wizard - 2023-04-25 6:32 AM
How do I get Dave's (the Administrator's) email? I will be more than willing to request the required date change.
Location: WHEELING,WV.>>>HOME OF WWVA | one might give the consideration that david has a life outside FL and might be a really busy man
as life happens! ------------------------------------later |
Location: So. Cal | The best way to contact him is on facebook. |
Location: Connecticut | I sent Dave the code to update the database tables to the correct date. But, yeah, he's busy with family life, so he will probably get to it when he gets a chance. Ron |
Location: SWITZERLAND | ronbo97 - 2023-04-26 4:04 AM I sent Dave the code to update the database tables to the correct date. But, yeah, he's busy with family life, so he will probably get to it when he gets a chance. Ron As you have the code, Ron, then you could do it!?! It needs some basics on software and programming you should have as moderator, and let Dave in peace with his family. - SERGE - Adds-on: As moderator, Ron, you can delete these threads and mail to the authors to re-enter them. Initial problem may be not solved, but Dave (56D500boy) happy with!
Edited by sermey 2023-04-26 3:45 AM
Location: .Norfolk..Mafia.. ,England UK | sermey - 2023-04-26 7:38 AM
Only Admin can Update the Database or make Amendments,, Regional and Board Moderators do Not have access to do it,,
Clive,,
