Location: Milwaukee Wisconsin | I have some tail light housing gaskets I purchased from quirley / formerly goers and the round seal to body is way too large in diameter also the shape of inner stepped curves are all wrong . anyone every use these on there 59 dodge ?....... or may know of some one else repopping them ? Thanks ! john
Edited by dodge59 2022-09-15 9:30 PM
Location: DFW, TX | Have you considered purchasing neoprene / foam rubber in bulk and making your own? Might be a viable and inexpensive solution. For example: https://www.amazon.com/stores/page/7146F6F4-B150-4AD3-AD1A-32D97D661... |
Location: Milwaukee Wisconsin | Thanks for the good idea ! |
| Go grab your wife’s yoga mat. They make a good lens gasket if you don’t want to get into too much trouble just cut enough out for what you need. There are cheapie yoga mats that are not fire retardant. I even used one to make the gasket between the heater plenum and fire wall on my 56.
Del S |
Location: SWITZERLAND | Do you mean this gasket? Look at, best fitting for ever, as custom made, but not cheap. Then more useful items in this thread for your DODGE! - SERGE - Rear Lamp Gasket: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=23691&start=53
Edited by sermey 2022-09-22 4:38 AM
Location: Newcastle Australia | The gaskets I purchased were the same. Too big in diameter.
I initially cut the gasket and removed a small piece of the rubber to make it fit better. Supaglue will glue the ends back together.
I ended up purchasing some O ring rubber and making my own gaskets. I think I used 7.5mm neoprene and cut it to length. Works well but doesn't give that strong delineation between the chrome and the body that Serge mentioned. |
Location: Milwaukee Wisconsin | I knew I wasn't the only one that bought these gaskets from quirley that were not made correctly . and I was probally not the only one that told them they did not fit but he keeps selling them. anyway, good idea about cutting them and I did think about doing that but they still don't fit correctly in the groove . |
Location: Milwaukee Wisconsin | <p>apparently for 59 dodge there were 2 different styles of tail light/ back up housings ... look at the bases . no wonder why my gaskets don't fit properly . pic is not my housings their for reference.</p>
Edited by dodge59 2022-10-08 7:11 PM
(Dodge tail light.JPG)
Attachments ---------------- Dodge tail light.JPG (213KB - 75 downloads)
Location: SWITZERLAND | Here again, the self-centering gaskets, as custom made, best for the Dodge Rear Lamps. Not squeeze. Profile A5, Material NBR, about 90 shores, -40 - 100 deg. You will not find any better ones! Getting from industrial suppliers, so called "piston wipers" (?), at various dimensions. If all Dodge 59 owners would purchase these, could get a reasonable price. Unfortunately I am not a dealer. - SERGE -
Edited by sermey 2022-10-08 9:15 PM
(Rear Lamp Gasket Profile.jpg)
(Rear Lamp Gasket.jpg)
Attachments ---------------- Rear Lamp Gasket Profile.jpg (51KB - 74 downloads) Rear Lamp Gasket.jpg (75KB - 81 downloads)
Location: Newcastle Australia | Looks like my cluttered work bench. I ended up getting a full set of the housings on the right. That gives more surface area to provide a seal to the body. |
