Posted 2022-07-27 2:54 PM (#623234) Subject: 1956 Savoy battery hold down
Hey Guys,
I'm trying to determine if there should be a bracket that bolts onto the inner fender for the battery hold down. I have a picture of the spot where there are 4 holes as well as the bracketry that I have. Any info would help.
Posted 2022-07-27 3:38 PM (#623239 - in reply to #623234) Subject: RE: 1956 Savoy battery hold down
cdstl - 2022-07-27 11:54 AM
The short one should bolt to the inner fender. The longer one hooks into the radiator side edge of the metal part of the battery tray.
Posted 2022-07-28 6:37 AM (#623251 - in reply to #623234) Subject: Re: 1956 Savoy battery hold down
Yes, that much I figured out. I have 4 sets of holes on the inner fender which led me to believe that there may have been a bracket there at one time. I suppose that another set of holes were drilled when a different size battery was installed, much like the situation that I have now. I'll get the hold down figured out for my current battery after I fix the rusted out sheet metal underneath.
Posted 2022-07-28 11:03 AM (#623252 - in reply to #623251) Subject: Re: 1956 Savoy battery hold down
As far as I know, there were only two sizes of batteries in 1955-56 era Mopars. Group 24 in the junior cars (Plymouth and Dodge) with 6 cylinders and small V8s and Group 27 in the senior cars (Desoto and Chryslers) with the larger V8s.
