Posted 2022-07-03 4:46 PM (#622568) Subject: Pinion Seal
Hey guys, I was in the process of changing seals when I found out that I had the wrong pinion seal. The numbers on the one in the car are 663602. I'm in the process of searching on the internet a bit so I thought that I'd ask you guys if you had a part number.
Posted 2022-07-03 5:46 PM (#622573 - in reply to #622568) Subject: RE: Pinion Seal
cdstl - 2022-07-03 1:46 PM
663 602 = the pinion seal for the 55-57 8.25" rear diffs. Replacement is SKF 18880 or National 7216
Tony - 2019-06-18 4:58 PM
I just compared the measurements for National 7216 and SKF 18880, the measurements are identical except that the 7216 still uses leather instead of rubber.
