Battery cable size
cdstl
Posted 2022-06-05 10:06 AM (#621925)
Subject: Battery cable size
I'm going to get some new battery cables made and I was wondering what size do you guys recommend. 1956 Savoy, 277, 3 speed
Thanks
Posted 2022-06-05 11:50 AM (#621926 - in reply to #621925)
Subject: RE: Battery cable size
500020002000500100100100100
There are three large cables in play here.
1. The negative ground cable from the battery to the block (probably near the left bank head)
2. The positive cable from the battery to input side of the starter solenoid on the inner fender
3. The starter cable from the starter solenoid to the starter.
As for size (diameter/gauge), I think the general answer is bigger is better but colour is important too (in my opinion)
I like the ground and starter cables in black. I am running the OE ground cable but I had a 1/0 gauge starter cable made up for $16.
As for the positive cable, I chose a pre-made 2 gauge red one from NAPA (which happened to have a 12 gauge fused link that I used to power my electric choke (via a second solenoid))
https://www.delcity.net/store/Top-Post-Battery-Cables-with-Leads/p_8...
Edited by 56D500boy 2022-06-05 11:56 AM
ronbo97
Posted 2022-06-05 1:05 PM (#621927 - in reply to #621925)
2000200025
cdstl - 2022-06-05 10:06 AM I'm going to get some new battery cables made and I was wondering what size do you guys recommend. 1956 Savoy, 277, 3 speed Thanks
For a 12V system, 4ga should be fine. Anything more is overkill. Napa should be able to set you up with the correct length. And yes, go with black. The red cables look out of place on a car of our era.
Ron
Posted 2022-06-05 6:01 PM (#621937 - in reply to #621927)
20001000500100100252525
Most new cars use 4 gauge but they have gear-reduction starters. For straight-drive starters, I would stay with 2 gauge.
cdstl
Posted 2022-06-06 9:16 AM (#621947 - in reply to #621925)
Subject: Re: Battery cable size
Thanks guys
Posted 2022-06-06 11:16 AM (#621954 - in reply to #621925)
50005000200010002525
On cars with heat sink problems, I usually use 0 AWG.
