Oil drain plug
Todd
Posted 2021-08-04 12:08 PM (#614021)
Subject: Oil drain plug
Hi folks.
I currently have a 1/2 - 10 screw in my 1960 313cui. But I don't find such an oil drain plug in any shop. Can I screw in a 1/2 - 20 without any problems?
Posted 2021-08-04 1:52 PM (#614022 - in reply to #614021)
Subject: Re: Oil drain plug
500020002000500100252525
Are you sure it isn't 1/2-13?
Todd
Posted 2021-08-05 9:30 AM (#614032 - in reply to #614021)
Absolutely. Exactly 10 mm...........
ronbo97
Posted 2021-08-05 10:28 AM (#614033 - in reply to #614021)
Subject: RE: Oil drain plug
2000200025
Todd - 2021-08-04 12:08 PM Hi folks. I currently have a 1/2 - 10 screw in my 1960 313cui. But I don't find such an oil drain plug in any shop. Can I screw in a 1/2 - 20 without any problems?
NO. If you do, you'll cross-thread it resulting in leaks, as well as difficulty removing it in the future. You need to verify the diameter and pitch before proceeding. 10mm?? Chrysler Corp did not use metric anything back then.
Ron
Posted 2021-08-05 12:46 PM (#614037 - in reply to #614021)
20001000500100100252525
Original thread for a '60 is 5/8"-18.
(Plug.PNG)
Attachments Plug.PNG (50KB - 95 downloads)
Todd
Posted 2021-08-06 8:21 AM (#614054 - in reply to #614021)
I have to apologize to you guys. I misinterpreted the screw designation completely. You are absolutely right. I need a 1 / 2-20 screw approx. 10 mm long and you can find one in every shop. Sorry again.
Stroller
Posted 2021-09-09 10:54 AM (#614868 - in reply to #614021)
1001001002525
Parts store check the Dorman plugs.
