1959 Dodge Coronet speedo meter
MrSurfHusky
Posted 2021-07-20 7:01 AM (#613622)
Subject: 1959 Dodge Coronet speedo meter
the coronet stopped the speedometer from working. the thread is fine. meter sends sound "tra tra tra". What may be scattered there. If the meter needs to be removed, how does it happen. Do you have any information on this?
* Teemu
58coupe
Posted 2021-07-20 12:41 PM (#613628 - in reply to #613622)
Subject: Re: 1959 Dodge Coronet speedo meter
100050010010025
It sounds like the cable (inside the housing) may have broken. If the odometer is still working then it is not the cable but the speedometer.
