| Why do it allow me to use the starter when the engine is running?
Have tried to change the neutral switch on the tranny but with the same result. Could it be something wrong on the starter or starter solenoid?
Or in the tranny that doesnt work?
Any ideas?
/Kent
Edited by Torqkent 2021-03-07 6:01 AM
![](/forums/profile/get-photo.asp?memberid=2543&type=profile&rnd=479) Board Moderator & Exner Expert 10K+
![5000](http://forwardlook.net/forums/images/decorations/multiple/5000.gif) ![5000](http://forwardlook.net/forums/images/decorations/multiple/5000.gif) ![2000](http://forwardlook.net/forums/images/decorations/multiple/2000.gif) ![1000](http://forwardlook.net/forums/images/decorations/multiple/1000.gif) ![25](http://forwardlook.net/forums/images/decorations/multiple/25.gif) ![25](http://forwardlook.net/forums/images/decorations/multiple/25.gif) Location: Southern Sweden - Sturkö island | There is (should be) a vacuum switch on the manifold that cuts the starter Circuit when there is vacuum in the engine. Either the switch is malfuntion. or the switch has been bypassed/bridged |
![5000](http://forwardlook.net/forums/images/decorations/multiple/5000.gif) ![25](http://forwardlook.net/forums/images/decorations/multiple/25.gif)
| If you really want to get rid of that every happening switch to a non push button start ignition switch(plymouth desoto).
no vacuum switch needed.
I know when it fails, people complain about burning up their starters, tearing up flywheels and stuff because it sticks. |
![](/forums/profile/get-photo.asp?memberid=7567&type=profile&rnd=604) Expert 5K+
![5000](http://forwardlook.net/forums/images/decorations/multiple/5000.gif) ![2000](http://forwardlook.net/forums/images/decorations/multiple/2000.gif) ![2000](http://forwardlook.net/forums/images/decorations/multiple/2000.gif) ![500](http://forwardlook.net/forums/images/decorations/multiple/500.gif) ![100](http://forwardlook.net/forums/images/decorations/multiple/100.gif) ![100](http://forwardlook.net/forums/images/decorations/multiple/100.gif) ![100](http://forwardlook.net/forums/images/decorations/multiple/100.gif) ![100](http://forwardlook.net/forums/images/decorations/multiple/100.gif) ![25](http://forwardlook.net/forums/images/decorations/multiple/25.gif) ![25](http://forwardlook.net/forums/images/decorations/multiple/25.gif) ![25](http://forwardlook.net/forums/images/decorations/multiple/25.gif) Location: Lower Mainland BC | Torqkent - 2021-03-07 2:10 AM
Any ideas?
Yup. As wizard suggests, something is wrong with the vacuum switch that is there to stop you from being able to engage the starter when the engine is running.
Read through this thread:
http://www.forwardlook.net/forums/forums/thread-view.asp?tid=74501&...
![](http://www.forwardlook.net/forums/forums/get-attachment.asp?action=view&attachmentid=208571) ![](http://www.forwardlook.net/forums/forums/get-attachment.asp?action=view&attachmentid=193785)
Edited by 56D500boy 2021-03-07 10:43 AM
![5000](http://forwardlook.net/forums/images/decorations/multiple/5000.gif) ![5000](http://forwardlook.net/forums/images/decorations/multiple/5000.gif) ![2000](http://forwardlook.net/forums/images/decorations/multiple/2000.gif) ![1000](http://forwardlook.net/forums/images/decorations/multiple/1000.gif) ![25](http://forwardlook.net/forums/images/decorations/multiple/25.gif) ![25](http://forwardlook.net/forums/images/decorations/multiple/25.gif) Location: Southern Sweden - Sturkö island | As I recall it, the "N" has like two steps, Neutral and then push further to engage the starter. I think this is a totally cool way to start the car and I would fix the problem or even make it better. |
![5000](http://forwardlook.net/forums/images/decorations/multiple/5000.gif) ![2000](http://forwardlook.net/forums/images/decorations/multiple/2000.gif) ![2000](http://forwardlook.net/forums/images/decorations/multiple/2000.gif) ![500](http://forwardlook.net/forums/images/decorations/multiple/500.gif) ![100](http://forwardlook.net/forums/images/decorations/multiple/100.gif) ![100](http://forwardlook.net/forums/images/decorations/multiple/100.gif) ![100](http://forwardlook.net/forums/images/decorations/multiple/100.gif) ![100](http://forwardlook.net/forums/images/decorations/multiple/100.gif) ![25](http://forwardlook.net/forums/images/decorations/multiple/25.gif) ![25](http://forwardlook.net/forums/images/decorations/multiple/25.gif) ![25](http://forwardlook.net/forums/images/decorations/multiple/25.gif) Location: Lower Mainland BC | wizard - 2021-03-07 10:04 AM
Agree on all counts. As shown in the photo, the Neutral slider has an extra tang that engages the button on the neutral starting switch. Just pushing the neutral button enough to take the transmission out of drive or reveres doesn't go far enough for that tang to contact the button, you have to push the button further in to do that.
There are several NOS 1770 093 vacuum switches out there on eBay, etc. like this one:
https://www.ebay.com/itm/NOS-Mopar-1770093-Switch-/124470729849
![5000](http://forwardlook.net/forums/images/decorations/multiple/5000.gif) ![5000](http://forwardlook.net/forums/images/decorations/multiple/5000.gif) ![2000](http://forwardlook.net/forums/images/decorations/multiple/2000.gif) ![1000](http://forwardlook.net/forums/images/decorations/multiple/1000.gif) ![25](http://forwardlook.net/forums/images/decorations/multiple/25.gif) ![25](http://forwardlook.net/forums/images/decorations/multiple/25.gif) Location: Southern Sweden - Sturkö island | Thanks' Dave, so practically, the vacuum switch is just an extra safety. |
