| Hey folks first not sure if I can post this because what I need is outside the Forward Look years. I have a Chrysler RV2 A/C compressor. I have feeling this thing had been replaced at some time or another. Reason being I took it off a trunk at a bone yard.
I either need a complete unmolested 10 ton hold the front end down Chrysler RV2 cast iron slug. Or I need the oil pump spring and ball and the key way for the crank shaft where the front pulley goes on. Reason I think it has been remaned is because these are missing. I wont say the name of rebuilder source but looking around online I have found it is more than common for that little spring and ball being left out. Tends to cause oiling issues.
If anyone has something I would appreciate. If this is outside the parameters admin feel free to delete and sorry.
But thanks anyway. |
Location: Ohio | Have several of the later RV2 A/C compressors and associated parts.
Can check for whatever parts you’re interested in.
Send a PM with email to send you pictures.
| pm sent |
