I picked up a '57 Chrysler with a 8 3/4" rear axle, the rear axle bearing was seized up, so I set about rebuilding it.
When I reassembled it I noticed there was no end play and no tapered bearing axle shims installed... might be the reason the bearing was froze up.
Does anyone have tapered bearing rear axle shims for these early 8 3/4 rear axles for sale?
Does anyone reproduce them?
I know I can always make them, but hoping to purchase one instead.
Thanks in advance for any assistance, Mark |
Location: Newark, Texas (Fort Worth) | Some Part numbers for you:
N/A Repair Kit, Borg Warner/Auburn unit. see note below.
Shim Packages
P4452027 1-3/4? pinion Shim Package
P4452026 1-7/8? pinion Shim Package
Ring Gear Bolts
P4529486 71 and later (also 4131255, pkg. of 10)
P5249163 70 and earlier.
https://www.jalopyjournal.com/forum/threads/mopar-8-3-4-differential...
Shim Package:
Chrysler numbers:
1-3/4" pinion -> P4452027
1-7/8" pinion -> P4452026
http://www.mymopar.com/Mopar8_75RearEndGuide.htm
Axle flange, shim 2881314 see flange kit see flange kit
Axle bearing service kit: Chrysler # 3683966, one axle.
BCA differential kit: 1-7/8", # RA-301, 1-3/4", # RA-300.
BCA axle mounting flange repair kit: Left # A-7-LK, Right # A-7-RK.
C/R axle mounting flange repair kit: Left # A7-LK, Right # A7-RK
http://www.crazysmopar.com/tech_rearax.html
Location: So. Cal | I would call Big M Automotive. John can get you the shims you need. |
Location: Colorful Colorado skier on the license plate | I have some outside axle shims. Do you know what you might need in measured thickness? you can also PM me.
Rick |
Location: Colorful Colorado skier on the license plate | I have some outside axle shims. Do you know what you might need in measured thickness? sorry posted twice.
Edited by RICKYMOPAR 2021-02-22 4:41 PM
Location: Minnesota | WooHoo! Rick’s got some shims coming my way! Thanks again!
And thanks to everyone who took the time to reply, you are all appreciated!
It’s not the first time fellow forwardlook members have saved my backside. |
