| Hey, im thinking about to change from 2bbl stromberg to the 4bbl carter i think it is. Will My car be more responsive om gas and rum smoother or is it just a waste of money?
/Kent |
Location: Alaska | You may notice a small power increase at higher rpm but if you drive it that way often you will certainly burn more gas. As far as running smoother, there should be little or no difference unless your old carb. was not working correctly. |
Location: Lower Mainland BC | Torqkent - 2021-01-29 12:32 AM
Hey, I'm thinking about to changimg from 2bbl Stromberg to the 4bbl Carter i think it is. Will My car be more responsive on gas and run smoother or is it just a waste of money?
Too make more power, you need more fuel. To burn more fuel, you need more air. To bring in more air, you need a different intake than what you have. You might also need a higher lift/longer duration cam. Then once you have all that fuel and air in there, you will need to bump the timing (more advance) to make use of the extra fuel and air and then you need to get rid of the additional exhaust gases quicker so you need to add dual exhaust if you don't have that already.
You won't be saving fuel because you will be having so much fun putting your throttle foot down that you will be burning more fuel than before, even around town, when, in theory, you are only using 2 of the 4 bbl venturis to deliver the fuel. (You'll tip in the throttle to find the other 2 soon enough)
But to get started, at the bare minimum, you will need a 4 bbl manifold for your 325 poly. I think the PN is 1735 774 (or 1735774 when searching with Google or on eBay). There are none being offered on eBay at the moment that I could see this AM.
They have been there but this eBay auction says "Sold Out" (note: 57 Dodges want 57 Dodge intakes, Chrysler, Desoto, or Plymouth will not work):
https://www.ebay.com/p/1023782702
Here *was* a 325 4 bbl that was for sale here 2 years ago:
*IF* you did have a 4 bbl manifold for your 325 poly, the OE power pack 4 bbl was probably a Carter 2532S. I don't see one on eBay at the moment. Even if there was, you would probably need to rebuild it anyway using parts from a website like this:
https://www.carburetion.com/CarbNumber.asp?Number=2532S
OR you could go with a Edelbrock 4 bbl carb and adapter plate (but again, you need that 4 bbl intake manifold). Maybe something like an AVS2 with around 500 cfm capability:
https://www.edelbrock.com/avs2-500-cfm-carburetor-with-electric-chok...
Your existing carburetor is likely to be a Stromberg WW3-149. You might be able to find a NOS carb on eBay (I couldn't find one at the moment). What I did find were rebuild kits, like this one:
https://www.ebay.com/itm/STROMBERG-WW-2BBL-CARBURETOR-KIT-1956-1959-...
but maybe better, this one:
https://www.carbkitsource.com/kits/ck5251.html
Based on the above, the least expensive way forward, perhaps while you look for a 4bbl intake, would be:
1. Dual exhausts with low restriction (but not too loud) mufflers .
2. Rebuild your Stromberg with one of the kits that are out there
3. Tune up (new points, condenser, rotor, cap, plugs and wires)
4. Bump the timing a bit and run a higher octane fuel than you have been say 91 instead of 89, etc.
5. Have fun
All of the above, just my opinion, based on some experience.
Edited by 56D500boy 2021-01-29 8:14 PM
Location: Ferndale, WA 98248 | Having owned two 57 Dodges, one with a 325 2 barrel and one with a 325 4 barrel, I was surprised how much different/better the driving experience was with the 4 barrel. Mind you, its still a 325, so it won't be a hot rod, but it did have much better seat of the pants acceleration.
If I had owned the 4 barrel car first, I would have never bought the 2 barrel. |
| Okej, thanks for all the answers. I Will look with My local parts guy here in Sweden, if its an ok price i Will Go for it. Going for dual exhaust in the Summer and got a Nos distributor with all new and tuned.
1 thing i dont like with the tuneing is that i have no marks on the pulley and No vaacum on the stromberg so im just using an old instrument and by ear. So Hard to Know if all is set the right way |
Location: So. Cal | In general, the single exhaust on these cars is quite restrictive. You'll get the best improvement in power by moving to a free-flowing dual exhaust than anything else. The main reason I always switch to the 4bbl, is the 2bbl stromberg carbs don't last very long before they need to be rebuilt again and they are prone to dribbling fuel down your motor. Mine became so bad before I could get it swapped, that it ended up dumping a lot of fuel past the rings, into my oil while it sat. |
| An update! Got to the local guy and bough intake and carter carb now so will fix this when i get the gaskets. And powerflite thanks for the info and i have feelt like the 2 port is taking alot of gas even when I had a full rebuild (the expensive show finish) from JJ Carbs in California.. may be unluck or just a bad carb.
If I remember I will post an update later in February! |
Location: N.W. Fla. | You bought a 4 bl intake & carb or 2 bl? |
Location: Lower Mainland BC | Mopar1 - 2021-01-30 2:49 PM
I'm not Kent but...
/Kent
Location: Ontario, Canada | Torqkent - 2021-01-29 3:32 AM
/Kent
I have had a lot of experience with both original set ups. The 2bbl will give better off idle full throttle response but will start to bog down at 60-70 mph and run out of gas at late 80s/early nineties. The 4bbl will be slower off idle but will pull much harder as speed increases. The over all fuel economy with the 4bbl is better especially if you run long distances at highway plus speeds.
If set up properly, both systems operate smoothly. The choice is yours!!
Greg |
| I bought a 4bbl intake and a carter 4bbl |
Location: NorCal | Here's my take on the subject....4-barrel carbs usually have smaller primary throttle bores, smaller bores mean higher velocity and higher velocity means better throttle response just off idle and low speed. Since you are running most of the time off of the primary, the smaller bores and higher velocity will actually bring better fuel economy as long as you don't kick in the secondaries too often.
I replaced the original 2-barrel on my '57 325 poly with a small (500 CFM) Carter AFB and noticed much better drivability all around. Also changed the valve cover decals to reflect the change
(Stock AC LH (Small).JPG)
Attachments ---------------- Stock AC LH (Small).JPG (156KB - 174 downloads)
