| A newbie to the forum here. I’ve been a Mopar nut my whole life and recently caught the wing car bug. I picked up my first piece of Virgil’s art and have a funky fender tag I need help breaking down. The car is either a 57 or 58 Coronet. The core support hood and grill are missing but it has a 354 short block under the hood. The body code on the fender tag is only three digits long and I’m not sure what to make of it. Any help would be greatly appreciated.
Attachments ---------------- B3B7A957-FA3C-4094-9C70-DA4E72F1BCEB.jpeg (35KB - 236 downloads)
Location: Lower Mainland BC | 65alive - 2020-10-04 9:40 PM
I am certainly not an expert but based on what I can see from that very small photo (you can up load photos up to 250Kb, i.e. 1024 x 768 is better), I would have to guess that a) the car is likely a 1958 because the 1957s had four digit body codes and b) it was built in/around Oct 1957 (as a 1958).
If there is anything left to indicated how many headlights there were and it shows 4 then you are for sure looking at a 1958.
Regardless, a 354 was a Chrysler engine, not a Dodge engine. 1957 was the last year that Dodges had double rocker (wide) heads (i.e. hemis) until 1964. And those engines were 325s and were stamped KD 500 - 1nnnn. There were a few 57 Dodges that got 354s but they would be in four digit code bodies and were called D501s.
In 1958, the double rocker Dodge engine was no longer available so a 354 definitely is out of place as a factory engine. It could have been added after the car left the factory.
I can't really read the cowl tag that well other than I think I see 293 at the left side. 293 = Torqueflite transmission (cast-iron A-466).
Post a better photo of the tag and some photos of the front and rear of the car.
This is the best I can do with what you've posted:
(Possible58DodgeCowlTag.jpg)
Attachments ---------------- Possible58DodgeCowlTag.jpg (76KB - 232 downloads)
| Thanks so much for the help. The serial number on the engine comes up as a 57 poly but it has been converted to a hemi at some point. The body code is 332, that’s the main part of the tag I’m curious about. I’ll try to upload a better pic. Thanks again.
Edited by 65alive 2020-10-05 9:02 AM
Attachments ---------------- A9CB81D1-DBA0-43F3-8298-6D0455342894.jpeg (124KB - 235 downloads)
Location: Lower Mainland BC | 65alive - 2020-10-05 5:50 AM
Again, I am not the expert (that's LD3_Greg, Lancer Mike, Chrycoman and lately frwl (Igor)) but in the meantime, I do know how to use the search function and cut and paste. That lead me to these:
Chrycoman - 2017-07-23 3:47 PM
Body - 333
3 - Dodge
3 - Coronet V8
3 - 4dr Sedan
and
Lancer Mike - 2015-05-16 8:25 PM
BDY 362 = Dodge, Custom Royal, Lancer Coupe
and in response to a 335 tag:
Lancer Mike - 2019-12-05 5:22 PM
it appears to be built on or around April 16, 1958, Hamtramck, Dodge Main Dodge, Coronet, Lancer Convertible
And in response to a 363 tag:
Chrycoman - 2018-08-07 8:43 AM
363 -
3 - Dodge
6 - Custom Royal
3 - 4 door sedan
So based on those four, I have guess that your 332 = 1958 Dodge, Coronet V8, 2 dr Lancer (hardtop). *BUT* I could be wrong.
Greg? Mike? Bill?
Edited by 56D500boy 2020-10-05 3:06 PM
| Right on. So it looks like 1958 cars have a 3 digit body code rather than a four digit like the 1957s?
Edited by 65alive 2020-10-05 11:23 AM
Location: Lower Mainland BC | 65alive - 2020-10-05 8:22 AM
Apparently. And for some reason, no one seems to have fully documented the 58 Dodge codes.
For the 1957 Dodges, I built on info from LD3_Greg to do a visual body code documentation on the 57 Dodges (first credit goes to Greg and Neil Vedder (RIP)).
The non-D500 57 Dodges:
http://www.forwardlook.net/forums/forums/thread-view.asp?tid=74413&...
The 57 Dodge D500s:
http://www.forwardlook.net/forums/forums/thread-view.asp?tid=74433&...
And as they are discovered:
*SOMEBODY* should do the same for the 1958s. (I hope that is NOT me!)
Supposedly there are only 15 (not 19 like 1957) different models. How hard could it be??
Edited by 56D500boy 2020-10-05 12:40 PM
(58DodgeBodyCodeTemplate.jpg)
Attachments ---------------- 58DodgeBodyCodeTemplate.jpg (219KB - 237 downloads)
Tag code 293 = Sales code 193 = Torqueflite Transmission
Tag code 312 = Sales code 302 = Power Brakes
Tag code 362 = Sales code 312 = Radio Accessory Group: Backup Lights, Heater and Defroster, Left Outside Rear View Mirror, Inside Prismatic Mirror, Radio Music Master
Tag code 382 = Sales code 314 = Appearance Accessory Group: Plastic Steering Wheel, Electric Clock, Rear Quarter Stone Shields, Wheel Covers
Tag code 487 = Sales code 467 = Solex Tinted Glass at All Windows and Shaded Windshield
Tag code 605 = Sales code 625 = Delivery Route – by Truck
SHEDULE: A 1028 10054 Scheduled on October 28, 1957 as a 54th car that day
BODY: 332 = 1958 Dodge Coronet Lancer 2 Door Hardtop
PAINT: 3ZUZ = Light Gold roof, fins and lower color; Sunshine saddle color
TRIM: 123 = Black & White (or Black & Tan) Standard Coronet Trim
1958 DODGE BODY STYLE CODES:
CORONET
331 = 2door Sedan
333 = 4door Sedan
332 = Lancer 2door Hardtop
334 = Lancer 4door Hardtop
335 = Lancer Convertible
371 = Suburban 2door Station Wagon, 6P
372 = Sierra 4door Station Wagon, 6P
373 = Sierra Spectator 4door Station Wagon, 9P
ROYAL
353 = 4door Sedan
352 = Lancer 2door Hardtop
354 = Lancer 4door Hardtop
CUSTOM ROYAL
363 = 4door Sedan
362 = Lancer 2door Hardtop
364 = Lancer 4door Hardtop
365 = Lancer Convertible
374 = Sierra 4door Station Wagon, 6P
375 = Sierra Spectator 4door Station Wagon, 9P
(Trim 123 probably.jpg)
Attachments ---------------- Trim 123 probably.jpg (149KB - 236 downloads)
Correction:
Tag code 293 = Sales code 293 (not a 193) = Torqueflite Transmission |
And Tag code 384 (not a 382) = Sales code 314 |
Tag code 293 = Sales code 293 = Torqueflite Transmission
Tag code 384 = Sales code 314 = Appearance Accessory Group: Plastic Steering Wheel, Electric Clock, Rear Quarter Stone Shields, Wheel Covers
Attachments ---------------- 0.jpeg (124KB - 224 downloads)
Okay. My bad. I should have included frwl (Igor) as one of the experts. Sorry. I won't let that happen again.
Two things
1. Neil Vedder once said in reference to a 58 Dodge 2dr hardtop with a 352 code:
d500neil - 2013-06-14 1:12 PM
Juha, the 1958 V/8 Coronets have BDY codes of 33X....the Royals are 35X.
In your car's case, the third digit is a "2", so that confirms the 2-door hardtop models.
So that fits with what you are saying above. I also found a 333 code that Chrycoman confirmed as a 4 dr Coronet sedan. Again, fits in your list.
2. I am pretty sure that if you find a 58 Dodge IBM card, the transmission column will be 32 so 322 = Powerflite, 323 = Torqueflite, etc. And through the magic of a Dodge engineers mind, these become 292 and 293 on the cowl tag.
Found already: Transmission code is a 293 (29x)…
Also:
BODY CODE 352 = Royal Lancer 2 Door Hardtop – it is confirmed with lettering BLACK ROYAL in the right lower corner of the sheet…
Don’t understand – why is it Black? The paint code shows same colors as on the example above…
(2(2).jpg)
Attachments ---------------- 2(2).jpg (86KB - 242 downloads)
This is really Black Royal (1AAA)...
(1(1).jpg)
Attachments ---------------- 1(1).jpg (194KB - 231 downloads)
Dave: you may begin a 1958 Dodge body codes thread … I will support you with cowl tag pictures…
This is a Coronet Convertible (Body Code 335)
Transmission code 293 is on the place…
The Eggshell and Mint paint scheme (code 3XEX)…
(1(1).jpg)
Attachments ---------------- 1(1).jpg (240KB - 235 downloads)
The power steering 301 and power brakes 302 as well... |
| That’s exactly the info I was looking for. You guys are amazing! Thanks, that gives me something to chew on. My poor car is pretty stripped down, I’m not sure if she can be saved :/.
Attachments ---------------- B0190233-6F23-4D34-861D-8BD2D48363F7.jpeg (109KB - 238 downloads)
Location: Lower Mainland BC | 65alive - 2020-10-05 12:36 PM
Yikes. From that photo, it would appear that the car is sitting on the ground (not on its wheels). That will mean rot in the floor and trunk pans (all fixable) BUT ALSO frame rust/rot. That is a death knell. (Sorry)
You might want to walk (RUN!!?) away.
Edited by 56D500boy 2020-10-05 4:30 PM
(58DodgeInNeedOfMajorTLC.jpg)
Attachments ---------------- 58DodgeInNeedOfMajorTLC.jpg (56KB - 231 downloads)
| Ya, I think it’s more of a project than I want to tackle as far as restoration goes. It will end up being used for parts. Thanks again for all the help with the tag. |
Location: The Mile High City | If it is a 1958 Dodge (which it is), it is a car worth saving! Here's all my information on codes (see attachment). Disclaimer - my list is a work in progress! Some information in there may be conjecture, particularly the TRM codes...
Attachments ---------------- Copy of 1958 Dodge Decode for sharing revised 100315.xlsx (17KB - 256 downloads)
Location: The Mile High City | Igor, thanks for posting those! I am sure the production broadcast sheet is for the Gammel Dodge. I think the IBM punch card is for my Coronet! |
| Thanks for that additional info Lancer Mike. What’s the interchange between 2 door an 4 door cars? I assume the doors are different... maybe I find a decent four door as a donor??? |
Location: The Mile High City | Basically, they used the same front clip. However, the bodies of two doors and four doors are really different: there are no easy exchanges. The green house is different, the roofs are different, the rear quarters are different, the doors are different. Inside, the dashboards are the same, but there are a bunch of differences rolling back from there. Thank goodness, drivetrains and frames are the same for Dodge, for everything except the convertible, which means the floor pans and trunk pan should basically be the same. Long story short, there are a lot of parts you can use, but you are best off getting a parts car that is a coupe, if you can find one.
Edited by Lancer Mike 2020-10-05 11:54 PM
| Got ya. That’s what I was afraid of, I have a 68 Polara 2 door that’s in the same boat. Luckily it’s in nearly perfect shape so I shouldn’t need a parts car :). |
Hello Mike! Cannot open this file and read the text...
Check your email, please... |
Location: Lower Mainland BC | frwl - 2020-10-06 7:07 AM.
Igor: Do you have Microsoft Office Excel on your computer? You need Excel to open Mike's file.
I have downloaded and opened and saved the file. It has a mind blowing amount of info about the 1958 Dodge codes.
Dave: Thanks for the hint; I have Microsoft Office Excel program
But still cannot open…
