Location: Murray Bridge, South Australia | I all I have pulled down the vickers power steering pump and found the bushing has cracked in 2 places ( mopar parts catalouge passenger cars parts list 1955 - 58, part no 19-54-26 on pump 1826 158 ).
It is a brass or bronze type bushing that assists the shaft to stay central. Rest of pump is now rebuilt like new.
Edited by 582drht 2020-09-27 1:29 AM
(1826158PowerSteeringPumpExplodedPartsDiagram.jpg)
Attachments ---------------- 1826158PowerSteeringPumpExplodedPartsDiagram.jpg (146KB - 146 downloads)
Location: So. Cal | If you can't find a replacement, you can have a local machine shop make a new one for you. Carefully measure the shaft diameter very accurately and the diameter of where it goes in. If it is press fit into the housing, make it .001" bigger than what you measure. Give yourself .001 to .002" clearance on the shaft. A good machinist would measure it for you and build it accordingly.
Edited by Powerflite 2020-09-27 11:59 AM
Location: Murray Bridge, South Australia | Thanks Powerflite a machine shop has done it for me now I find one of the cast collets ( Retainers ) 19-54-8 is cracked. DARN DARN DARN |
