1956 firedome rear pinion seal
NYFDX
Posted 2020-09-20 4:15 PM (#603383)
Subject: 1956 firedome rear pinion seal
Having trouble finding one. The part number on the seal is 1404504 which cross references to a national 7216. I ordered the national seal but it’s too small.
Next I ordered what I thought was the correct item from Old Mopar parts using the mopar part number out of the parts manual but again the seal is too small.
The ID is 2 1/8 inches and the OD is 3 1/4 inches.
There was an older thread on this which listed some part numbers but I had no luck with them.
I think the national 6845 might work but I cannot locate one.
Any info is appreciated.
Edited by NYFDX 2020-09-20 4:30 PM
Shep
Posted 2020-09-20 7:26 PM (#603386 - in reply to #603383)
Subject: Re: 1956 firedome rear pinion seal
20001000100100100252525
Check with Birnbaum's, I think I saw this listed. The Firedome had the larger pinion shaft.
Posted 2020-09-20 8:25 PM (#603387 - in reply to #603383)
Subject: RE: 1956 firedome rear pinion seal
500020002000500100100100100
From a previous 56 Desoto pinion seal thread:
http://www.forwardlook.net/forums/forums/thread-view.asp?tid=69195&...
57chizler - 2018-07-23 10:20 AM
All these seals match your dimensions:
TROSTEL 52440
CR 501655
NATIONAL 6845
CR 335F24
Precision 413469
CR 336F24
Posted 2020-09-20 9:52 PM (#603388 - in reply to #603387)
Searching on the shaft and bore sizes at the SKF website turns up a 21336
http://www.skfextranet.com/crsealsfinder/datasheet.aspx?s=21336
https://www.vsm.skf.com/us/en/products/21336
https://www.skf.com/group/products/industrial-seals/power-transmissi...
https://www.motionindustries.com/products/sku/01315628
https://www.amazon.com/SKF-21336-Small-CRWH1-Diameter/dp/B00CLIS84Y
SKF 21336 LDS & Small Bore Seal, R Lip Code, CRWH1 Style, Inch, 2.125" Shaft Diameter, 3.35" Bore Diameter, 0.438" Width
Edited by 56D500boy 2020-09-20 9:53 PM
NYFDX
Posted 2020-09-21 9:16 AM (#603411 - in reply to #603383)
Thanks all.
From the previous thread this is what I need
https://hagensautoparts.com/cdn/611/796/61179622920fd3e0e646d710c7bb...
Unfortunately since I have a wagon they are hard to come by.
All the referenced part numbers above turn up as a dead end.
NYFDX
Posted 2020-09-21 2:39 PM (#603423 - in reply to #603383)
Think I found one appreciate all the input
Posted 2020-09-22 2:26 PM (#603478 - in reply to #603423)
NYFDX - 2020-09-21 11:39 AM
So for future reference, what did you find exactly?
