NOS 55-56 Plymouth Carburetor, DeSoto Hemi Distributors
Posted 2020-09-02 2:16 PM (#602845)
Subject: NOS 55-56 Plymouth Carburetor, DeSoto Hemi Distributors
500020002000500100252525
One distributor is for a '55 Firedome 291, and the other for a '53-'54 276. Both are dual point and the shafts spin freely, without a lot of play. $50 each.
One NOS Carter 2bbl carburetor, number 2274-SA for a '55-'56 Plymouth. Been sitting a long time so it's dirty, but looks like it has never been used. $60.
(Extra Parts.jpg)
Attachments Extra Parts.jpg (224KB - 178 downloads)
Posted 2020-10-24 4:37 PM (#604885 - in reply to #602845)
Subject: Re: NOS 55-56 Plymouth Carburetor, DeSoto Hemi Distributors
I picked up a bunch more distributors that I won't likely use. They are all the same price at $50 each.
1785139 IBM-4101 '57 Dodge truck 354 or 331 hemi single
1688647 IBJ-4301A '56 Plymouth, Dodge poly single
1605148 IAZ-4003B Late '54 Dodge 241 hemi dual
1641740 IAZ-4003G '55 Dodge, Plymouth poly dual
1383757 IAZ-4003 '53-'54 Dodge 241 hemi dual
Also various 331, 354, 392 hemi distributors & 315 Dodge Truck poly distributor. These are $75 each.
I also have:
1626657 IAZ-4003D '55 Dodge Custom Royal 270 hemi dual
1641956 IAZ-4003F '55 Dodge Custom Royal 270 hemi dual (not sure of difference between this and the previous one)
that I am planning to keep, but you might be able to talk me out of it if you need it.
Posted 2020-10-24 7:04 PM (#604890 - in reply to #602845)
More parts as well.
A used '54-'55 Dodge 2bbl carburetor $25
Dodge hemi single crank pulleys. I think 1 is 315 and the other two are 270. $25 each.
Heat riser valves, not stuck. $25 each
Edited by Powerflite 2020-10-24 7:11 PM
(Dodge 2bbl Top.jpg)
(Dodge 2bbl Bottom.jpg)
(Dodge Crank Pulleys Heat Risers.jpg)
Attachments Dodge 2bbl Top.jpg (190KB - 138 downloads)
Attachments Dodge 2bbl Bottom.jpg (205KB - 130 downloads)
Attachments Dodge Crank Pulleys Heat Risers.jpg (197KB - 136 downloads)
