Location: Muskego, WI | I know that the 318 poly v8 changed crank flanges and bell housing dowl pin locations after 1962, is the same true for big blocks (RB)? |
Location: northern germany | After 1961, not 62. Yes, big blocks too. |
Location: Muskego, WI | Thanks Sid! To be clear, was it just the crank flange that changed for the big blocks, or did the dowel pin locations change as well? |
Location: Alaska | The crank flange is the only change on the 62 and newer big blocks. The later bells will bolt to the early blocks. |
