Location: Malmberget, Sweden | Can anyone measure the joint peace in the console for me
The F and G are the same. |
Location: Malmberget, Sweden | If anyone have a pic of the joint bit it would help. |
Location: Ramona, CA | It's about 3 3/8" long. I can probably find a picture of the back side.
(console_trim_joint.jpg)
Attachments ---------------- console_trim_joint.jpg (78KB - 139 downloads)
Location: Malmberget, Sweden | Thanx Nick. My car is in winter storage 150km from me
What the width of the part?
And what is the real name of that part?
Location: Ramona, CA | I'm not sure what the actual name of the part is. The parts book isn't much help. This is from the 1961 book.
(61_console_parts.png)
Attachments ---------------- 61_console_parts.png (21KB - 136 downloads)
Location: Ferndale, WA 98248 | I have a pair of these that will go in my car when I finally do the interior this spring. I can't see a part number on them. They are indeed exactly 3 3/8 inches long. And 1 3/4" across. You can see their contour in the end view photo below. Each bend is about 1/4" from the side. The high bend on the left is 9/16" of the table top, the low bend on the right is 7/16" off the surface.
The shop working on my car is called Heavy Metal Custom Shop, because they can fabricate almost anything from metal. If you'd like, I can take one of my pieces to them and get an estimate on how much it would cost for them to fabricate a pair of these for you. They would also have my front and rear consoles to test fit them to. Getting the inner clips just right will probably be the most difficult (expensive) part of the job.
(300G console trim - end view.jpg)
(300G console trim - end view 2.jpg)
(300G console trim - back side.jpg)
(300G console trim - inside clips.jpg)
Attachments ---------------- 300G console trim - end view.jpg (171KB - 144 downloads) 300G console trim - end view 2.jpg (123KB - 155 downloads) 300G console trim - back side.jpg (139KB - 140 downloads) 300G console trim - inside clips.jpg (117KB - 143 downloads)
Location: Ramona, CA | Great pictures, saves me digging up mine. It looks like those tabs were part of a continuous extrusion that they ground off the excess. |
