Not to long ago, I found an image of an Auto Show - somewhere, didn't know where. As I poked around, I discovered that the image was from the 1956 Detroit Auto Show. I then started looking for (and still am looking for) a copy of the 1956 Detroit Auto Show program from February 1956. Somewhere in the middle of looking for stuff, I got in touch with the Detroit Public Library to see what they had related to Dodges at the 56 Detroit show. They said that they had a copy of the program and the image that I had found first as well as one more Dodge image. The second Dodge image is only in black and white but it confirms that the white and oriental coral car in the left side of the colour image was a D500 (which kind of makes sense in a way because the D500 was announced at the end of December 1955). I inquired about obtaining digital copies of the photos and anything pertinent I could get from the program (ended up to be 8 pages, including a map of the layout of the building that the Dodges were in so I could figure out the camera angles for the two "Dodge" shots.
The answer was:
"Thanks for your reply! The second photograph is only in black and white. The ResourceIDs are as follows:
na020111 (color), na050190 (b&w)
A link to the order form is below:
http://d2qp1eesgvzzix.cloudfront.net/uploads/forms/Special-Collecti...
I ended up paying around $51 to get high(ish) (1 Mb) res photos and a pdf of 8 pages from the program.
Many thanks to the folks at the Detroit Public Library (not the first time that I have obtained 56 Dodge info from them (at a small cost)).
In the event that you don't want to purchase high res copies of the photos (which I recommend), using the info and link above, I am posting some low res photos here:
(BTW, I see a 4dr Lancer, a La Femme, a 2 dr post Coronet, a Sierra wagon, a D500 Lancer and the Plainsman concept wagon in those two photos (not taken on the same day))
Edited by 56D500boy 2019-10-01 1:25 PM
(1956DetroitAutoShowProgramCover.jpg)
(1956DetroitAutoShowDairyBuildingLayoutShowingPresumedCameraAnglesForDodgePhotos_Annotated.jpg)
(1956DetroitAutoShowShowingDodgeDisplayArea_Feb1956_small.jpg)
(1956DetroitAutoShowShowingDodgeDisplayArea_withD500_Feb1956.jpg)
(DodgeD500DisplayAtFebruary1956DetroitAutoShow_small.jpg)
(ChryslerDesotoAndDodgeDealers.jpg)
(DodgeDealers2.jpg)
Attachments ---------------- 1956DetroitAutoShowProgramCover.jpg (90KB - 242 downloads) 1956DetroitAutoShowDairyBuildingLayoutShowingPresumedCameraAnglesForDodgePhotos_Annotated.jpg (172KB - 286 downloads) 1956DetroitAutoShowShowingDodgeDisplayArea_Feb1956_small.jpg (248KB - 266 downloads) 1956DetroitAutoShowShowingDodgeDisplayArea_withD500_Feb1956.jpg (138KB - 262 downloads) DodgeD500DisplayAtFebruary1956DetroitAutoShow_small.jpg (244KB - 237 downloads) ChryslerDesotoAndDodgeDealers.jpg (116KB - 269 downloads) DodgeDealers2.jpg (33KB - 244 downloads)
Location: Lower Mainland BC | ronbo97 - 2019-10-01 10:26 AM
Wow...nice find ! Do you have similar for 59 ? Anything that shows 59 Dodges ? Ron
Not so far. (I had a quick look just now and came up with some 59 Auto show images but all GM things (Chev, Caddie, etc))
