Location: Winston Salem, N.C. | wanted fuel pump for 1958 318" engine with 2 bbl.
(I have a good one for 1956 270" but dont know if the two will interchange.
thanks
Jerry Whitfield
winston salem, NC
reply here or 336-749-5922 | |
Location: Lower Mainland BC | From Allpar: "The 318 is the most common version of the A engine, produced from 1957 through 1967 when it was replaced in all markets by the LA 318. Only Plymouth used this 318 in 1957 and 1958, but it was shared with the other Chrysler divisions from 1959 on. It displaces 5.2 L; 317.9 cu in (5,210 cc) and has a 3.91 in (99.3 mm) bore and the 3.31 in (84.1 mm) stroke."
So 1958 Plymouth 318 fuel pump (?)
A 1958 Plymouth V8 without air con wanted a 1843 287 fuel pump. With air con, a 1843 400:
https://www.ebay.ca/sch/i.html?_odkw=1843287+1958+Plymouth+fuel+pump...
https://www.ebay.ca/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=184...
but a 58 Fury, LD2-D500 and LD3 would want a 1879 296 fuel pump:
https://www.ebay.ca/sch/i.html?_odkw=1879296+fuel+pump&_osacat=0&_fr...
Good luck.
