Location: Winston Salem, N.C. | What years fuel pump will fit on a 1958 318 engine? I have a fuel pump from a 1956 270" engine. If that will not fit, I'll need to get a rebuild kit for the
one on the engine and would be good to know what years to search for.
thank you
Jerry Whitfield
winston salem |
Location: Newark, Texas (Fort Worth) | Seems the right pump fits a lot of engines...
https://www.ebay.com/p/Fuel-Pump-Carter-M2504/169031945?iid=14292645... |
Location: Peoples Republic of Oregon | All of the pumps listed on the ebay link are for A-LA engines which is what Jerry needs.
Jerry asked about a 270 which is an Dodge Hemi or Poly, and although similar, not exactly interchangeable.
FWIW, the A-LA pump is a direct replacement for the DeSoto Hemi engines.
'Direct replacement' means it fits and works, not that it is correct for a restoration of any kind. |
