58 Plymouth
anth61
Posted 2019-04-21 8:51 PM (#581221)
Subject: 58 Plymouth
hi guys,
so i changed the points, plugs etc..went to start it, it cranked but didn't start, turned car off but was still cranking, keys out and still cranking.
i quickly disconnected the battery.
I wouldn't had thought that the points would have anything to do with this problem
1st time I've come across this.
Has anyone experienced this?..
Any tips on diagnosis
cheers...Anthony
58coupe
Posted 2019-04-22 10:28 AM (#581227 - in reply to #581221)
Subject: Re: 58 Plymouth
100050010010025
This has nothing to do with your points. Your starter solenoid was holding it engaged and if it had started normally, would have disengaged like it should. First, find out why it won't run and fix that. You may have to replace the starter solenoid.
Posted 2019-04-22 1:03 PM (#581228 - in reply to #581221)
Subject: RE: 58 Plymouth
20001000500100100252525
I would try it again but, instead of disconnecting the battery, disconnect the small wire from the solenoid to make sure the problem isn't stray voltage. The fact that it didn't start suggests something amiss electrically.
anth61
Posted 2019-04-23 6:36 AM (#581239 - in reply to #581228)
ok..i will try that
many thanks.
