Location: Newark, Texas (Fort Worth) | https://www.ebay.com/itm/1957-Desoto-Firesweep-Parts-Lot-Chrysler-Pl...
349896?hash=item287b2eb308:g:fNoAAOSw0VRcqXTG&vxp=mtr
1957 Desoto Firesweep Parts Lot Chrysler Plymouth Dodge TAKE ALL LOT!!. This is a nice lot of 1957 Desoto parts. I do not know if some of these items work as I have no way to test. I do know all or most parts are original.therefore this lot is being sold as is where is without warranty. The chrome pieces are in excellent condition. Perfect for a DESOTO Restoration or Enthusiasts. Here is a list of the parts in lot to the best of my knowledge. I will ship via FedEx same or next business day. Will not ship to Hawaii, Alaska or Puerto Rico.Thank you for your Bid
PARTS LIST FOR 1957 DESOTO FIRESWEEP
QTY: Part number: Description:
1 P/N 1686746 11206 chrome Front Hood Crest winged emblem
1 P/N 1624990-11225 Main Chrome Hood Ornament
1 Chrome Firesweep Emblem no P/N
1 P/N 2299521 DP CD AACY Chrome Side Mirror
2 Chrome Rear Fender pointed Trim pcs.no P/N
4 P/N 1575912 Chrome window Handles
3 P/N 1575917 Chrome Inside Door Handles
1 P/N 1770909 Dash knob with star
1 P/N 1770905 Dash knob with star
1 P/N 1779184 Dash knob no star
1 Chrome Turn Signal Piece with threaded end, No P/N
1 Chrome Steering Column piece with threaded end possibly for windshield wipers no P/N
2 P/N 3131009 Chrome Headlight Trim Rings
1 headlight inner mounting ring No P/N
2 All Glass sealed beam GE headlights No P/N
10 assorted small lights, some in sockets, tail and Brakes I assume. No P/N
1 Enclosed light. License plate or something. Unit says Griffin/ Shelby Miss. 232 SAEL-62
2 circular metal pieces. Perhaps caps for something. No P/N
1 P/N VRX 9L1642333 30-40 amp Chrysler Voltage Regulator Auto-Lite P/N VRX-6201A 12 Volt neg. Ground
1 P/N VRp-4004F-2 Voltage Regulator
7 tail Light Cover consisting of 2 large size all red, 2 medium size red with clear center, 2 small size all red. 1 larger oblong shaped red with clear bottom, says SAE STBL 67
2 rear semi pointed clear light covers no P/N
1 Push/Pull dash mechanism with H on knob. Unit says Cole made in USA Boston no P/N
1 small electrical part (possibly for ignition or something) numbers on bottom read 1689592, 8K537562, 185-648, 712
1 P/N G-122 Shurhit products inc. Condenser new in box
1 black metal piece possibly for master cylinder or brake pedal. (Not to sure) unit has plunger type rubber piece and moves like a Diaphragm, and a nipple on top ( Piece just to the right if the 2 voltage regulators)
2 Spartan 12v Horn Assembly’s 1B Hi / 2B Lo
2 P/N’s 657 & 658H Delco Remy Horn Assembly’s
3 inside Arm Rests poor condition 2 have leather material other is missing material.
1 battery terminal/ Ignition piece. Not to sure. Has red positive wire attached in pictures.
1 Ranco Type H16 Mechanism with copper pipe pieces, heater perhaps...
1 Ranco Type HN Mechanism with copper tubes
1 P/N’s or Numbers on unit are MO-764, 1G8, M26095 Carter Carburetor with Steel fuel line and fittings still attached. Working condition unknown.
1 3 13/16” Airotor Heater blower and motor assembly and coupler (Torrington Manufacturing, Conn USA
1 Delco Remy 208 6-Wire Distributor Cap (not sure of condition)
1 P/N 2444241 CH412 2495531 12v ignition Coil (condition unknown)
1 P/N 1115378 6v ignition Coil with mounting bracket. (Condition Unknown) |
