Location: The Mile High City | Not my car, but someone around here might be interested... https://denver.craigslist.org/cto/d/wheat-ridge-1959-dodge-sierra-station/6847939445.html 1959 Dodge Coronet Sierra 6-passenger station wagon for sale. This is a running, driving, stopping project car.
This is a factory big-block wagon... 361 engine. 3-speed Torqueflite transmission. Rare Custom Royal front fascia, emblem, and steering wheel.
I brought this car back from Arizona about 6 months ago. It is a lifelong AZ car, which means the body is pretty dang clean and dry. It's not perfect however; the floors have been patched as they often are, and there is some bubbling in the lower rear quarters. But overall, you will be hard-pressed to find a cleaner body.
This wagon sat idle for a VERY long time before I acquired it. In the last six months, I have gone about getting the car on the road; new plugs, wires, rebuilt carb, valve cover gaskets, oil change and fuel pump. I dropped the fuel tank and professionally welded-in a patch, and flushed it thoroughly. Four 14 x 5.5" rims were located, then blasted and painted. Four new tires. New master cylinder, all six wheel cylinders, and rubber brake hoses. The car now starts, idles smoothly, shifts well and stops. Unfortunately the brake pedal pulses; the drums need to be turned, but I have not done that yet.
Visually this was someone's "Kustom" at one time. I'm not a fan really but it's a look that's easily changed. Wagon was originally white and green.
Interior is somewhat disassembled and is rough. All of the interior trim - door panels, etc - is in the trunk area.
To repeat, this is a project car. A very rare one... Can be driven while you work on it.
Asking $8500/OBO.
(00101_g5t0YFq9Rda_1200x900.jpg)
Attachments ---------------- 00101_g5t0YFq9Rda_1200x900.jpg (145KB - 487 downloads)
