1957 /58 Plymouth ? carb no.
coronetx2
Posted 2018-12-22 1:57 PM (#575649)
Subject: 1957 /58 Plymouth ? carb no.
100252525
I just picked up a dual carb intake/ carbs and air breathers
Carb tag no. are 2631 S and 2632 SA
Just wondering if anyone can tell me what there off.
And how to tell if the air cleaners are originals or repops.
Supposed to be off 57/58 Plymouth Thanks for any help
Phil
finsruskw
Posted 2018-12-22 2:56 PM (#575653 - in reply to #575649)
Subject: Re: 1957 /58 Plymouth ? carb no.
2000100100252525
Section 14-30-1 here
http://www.jholst.net/55-58-parts-manual/fuel.pdf
Would be a good place to start your research
Edited by finsruskw 2018-12-22 2:58 PM
coronetx2
Posted 2018-12-22 3:38 PM (#575655 - in reply to #575649)
100252525
Thanks
Intake has casting F- 17 -57
So if I am reading correctly F should be June
Posted 2018-12-22 5:24 PM (#575656 - in reply to #575649)
Subject: RE: 1957 /58 Plymouth ? carb no.
500020002000500100100100100
coronetx2 - 2018-12-22 1:57 PMCarb tag no. are 2631 S and 2632 SA ....Supposed to be off 57/58 Plymouth Thanks for any help
2631 S = 1821 709 =1957/58 318 Plymouth Fury front
2632 S = 1821 710 = 1957/58 318 Plymouth Fury rear (not mention of "A" but presumably it's the one with the choke).
(57FuryCarbPNs.jpg)
(57FuryCarbPNs_2.jpg)
Attachments 57FuryCarbPNs.jpg (156KB - 134 downloads)
Attachments 57FuryCarbPNs_2.jpg (215KB - 151 downloads)
coronetx2
Posted 2018-12-22 6:05 PM (#575660 - in reply to #575649)
100252525
Thanks Dave
I believe you are correct no choke on the 2632 S rear carb
Originally went to get a 318 cast iron 4 barrel intake
But ended up getting this 2×4 intake carbs linkages fuel line and filter and oval air cleaners
Have to go back and take off the single 4 barrel next weekend also got a single 4 air cleaner
Posted 2018-12-22 6:19 PM (#575661 - in reply to #575660)
I know nothing. Nothing.
But regarding air cleaners, apparently the 57 and 58 Furys are different:
57:
58:
REFERENCE THREAD: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=49450&...
coronetx2
Posted 2018-12-25 6:14 AM (#575786 - in reply to #575649)
100252525
Went yesterday and got the single 4 barrel intake .
I came of a 58 Belvedere 4dr ht
