| Where can I find interchange info on 60 to 64 Chrysler. I'm looking for if door hinges,sub frames , and leaf springs interchange between 61 Plymouth and 63 300? |
https://www.ebay.com/itm/32nd-Hollander-Parts-Interchange-Manual-195... |
Location: Tacoma, WA | I still use the Hollander set I got from Hollander https://hollanderinterchange.net/catalog/product_info.php?cPath=21&p... $52 brand new 2-volume boxed set. I don't have them with me right now, but I will try to check later. It probably doesn't list sub-frame, can't remember hinges, but it lists leaf springs for sure.
I'm not aware of anything on-line, but I suggest you could use the Stengel Bros application chart in a roundabout way to plug in and compare two leaf spring applications https://www.stengelbros.net/Leaf-Springs_c_177.html On QUICK look (I could be wrong), it appears the spring has a 4" difference in length.
Edited by Dave L. 2018-09-28 1:06 AM
From the Hollander Interchange:
Door hinge upper and lower do interchange.
V8 sub frames interchange, 6 cyl. do not.
Leaf springs no interchange, Plymouth spring is 2" shorter than Chrysler. |
| Thanks I will invest in a Hollander book. What about finding mopar part number part ID. I have a chance to get alarge amount of vintage NOS mopar parts. Where can I go to find out what the part numbers are? |
http://jholst.net/300resource/index.php
The interchange section contains only the indexes, so you'll have to flip between various parts manual years to compare part numbers. |
If the parts are in boxes or are tagged, you have the part number but the number found on the part itself (like a cast number) is not always the part number.
This site has a part number search but it's nowhere near complete, kinda hit/miss:
http://www.mymopar.com/index.php?pid=99 |
Location: northern germany | 57chizler - 2018-09-28 12:18 PM
Only the 122" wb cars, not the big ones. |
| Thanks for the part# info, What cars are the longer subs and what cars are the smaller ones? |
Location: northern germany | Apollo 61 - 2018-10-04 7:41 PM
1960/61 Chrysler Windsor/Newport, all Desoto, all Dodge, all Plymouth (118"/122" WB) short subframes with different anchor points. All other unibody fullsize (126" WB) large. |
