Location: Southern Sweden - Sturkö island | Hypothetically I'd say that it will be doable, but the PowerFlite pushbutton unit must be modified with the plates from a TorqueFlite pushbutton unit for to get the proper stroke ratios.
However, you will "loose" one gear, which could be the 1st gear that nearly ever is used.
The cable from the TF must of course be used |
